    Rayscaper Alpha Version Available
    114 Posts 14 Posters 21.8k Views 14 Watching
    • jo-keJ
      jo-ke
      I used the default settings
      http://www.zz7.de
      • pixelcruncherP
        Do you mind mailing me the scene packed with the textures when you have time? You can pack the scene via the "Extensions > Rayscaper > Create Archive" menu. Can you also send me the log file? For some reason, it feels that the denoiser is not activated on your machine.
        I appreciate your help!
        Thanks,
        Thomas
          sashapepperspray
          Is it possible to make that if I insert a light in a component, all instances of the component get a light added?
          • pixelcruncherP
            Yes, improving the light component instances is planned for 1.0. As you already observed, lights don't work if they are part of a group or component.
            Cheers,
            Thomas
            • majidM
              majid
              This would be a nic option and I am wondering if it is possible to keep the intensity the same but use bucket tool to change the color of some?
              I mean if it is applied "inside" the component, all instances change, if applied without opening the component it changes the color of that particular one...
              • pixelcruncherP
                That’s a good idea Majid, I will put it in Rayscaper’s backlog.
                • majidM
                  majid
                  After a while installed the latest version and a, wondering how may I copy the same material texture to the normal map? any copy/apst or drag/drop option?
                  • pixelcruncherP
                    You can drag and drop the same image multiple times from a file browser. But you are pointing out a good worklow improvement here, you should be able to at least right-click and copy/paste. I will put it on the list, and expect it in one of the upcoming releases.
                    • jo-keJ
                      jo-ke
                      in the current render there is an ugly branding. So I can't use the result.drh001.png
                      http://www.zz7.de
                      • pixelcruncherP
                        pixelcruncher Extension Creator @jo-ke
                        Hey @jo-ke - now that Rayscaper is in beta, I started selling discounted beta licenses: https://sketchucation.com/purchase-smart.php?plugin=rayscaper - The watermarks are a limitation of the free version.
                        Cheers,
                        Thomas
                        • 6 / 6
