    Rayscaper Alpha Version Available
    114 Posts 14 Posters 15.0k Views 14 Watching
    • majidM Offline
      majid
      Thanks, Thomas and Dave.
      I wish I had some spare time to do a favor for RS.or lucky to work with you, but am busy making some money to support my family and stay in the Netherlands for the "search year" period. Somehow challenging πŸ˜„.
      • ntxdaveN Offline
        ntxdave
        I wish I had some spare time to help develop RS, as a beta tester ...or lucky to work with you, but am busy making some money to support my family and stay in the Netherlands for the "search year" period. Somehow challenging πŸ˜„.
        Glad you have an income. πŸ˜„ πŸ‘ Was just trying yo help if possible. πŸ˜„
        I hope one of these days I can back to β€œmodeling” and rendering. Would love to be able to try Rayscaper as well. πŸ˜„
        Given the status of TR, I hope Thomas and Fletch & Chris ab work something out. πŸ˜„
        Press F1...thank me later
        • jo-keJ Offline
          jo-ke
          today I started a new test with rayscaper.
          finished render is still grainy and the texture at the picture on the wall messes up.
          http://www.zz7.de
            That render looks very promising!
            There's a regression in the current release; textures are not automatically scaled when converted to Rayscaper. You can manually work around this by setting the scaling in Rayscaper.
            Rayscaper texture scaling.
            Assuming your texture scale in SketchUp is in millimeters, the formulate is: 1 / ((texture_scale_mm / 10) / 2.54 inc/cm). So for this example: 1 / ((1828.8 / 10) / 2.54) = (1 / 72) = 0.013888 = 0.014. So basically the reciprocal of the size in inches.
            Again, I will fix the option to sync this.
            For the grainy noise:
            1. How many samples/px have you configured?
            2. Are you using AI denoise? That should resolve most of the noise.
            Rayscaper render settings.
            Cheers,
            Thomas
            • jo-keJ Offline
              jo-ke
              I used the default settings
              http://www.zz7.de
                Do you mind mailing me the scene packed with the textures when you have time? You can pack the scene via the "Extensions > Rayscaper > Create Archive" menu. Can you also send me the log file? For some reason, it feels that the denoiser is not activated on your machine.
                I appreciate your help!
                Thanks,
                Thomas
                  sashapepperspray
                  Is it possible to make that if I insert a light in a component, all instances of the component get a light added?
                    Yes, improving the light component instances is planned for 1.0. As you already observed, lights don't work if they are part of a group or component.
                    Cheers,
                    Thomas
                    • majidM Offline
                      majid
                      This would be a nic option and I am wondering if it is possible to keep the intensity the same but use bucket tool to change the color of some?
                      I mean if it is applied "inside" the component, all instances change, if applied without opening the component it changes the color of that particular one...
                        That’s a good idea Majid, I will put it in Rayscaper’s backlog.
                        • majidM Offline
                          majid
                          After a while installed the latest version and a, wondering how may I copy the same material texture to the normal map? any copy/apst or drag/drop option?
                            You can drag and drop the same image multiple times from a file browser. But you are pointing out a good worklow improvement here, you should be able to at least right-click and copy/paste. I will put it on the list, and expect it in one of the upcoming releases.
                            • jo-keJ Offline
                              jo-ke
                              in the current render there is an ugly branding. So I can't use the result.drh001.png
                              http://www.zz7.de
                                pixelcruncher Extension Creator @jo-ke
                                Hey @jo-ke - now that Rayscaper is in beta, I started selling discounted beta licenses: https://sketchucation.com/purchase-smart.php?plugin=rayscaper - The watermarks are a limitation of the free version.
                                Cheers,
                                Thomas
                                • 6 / 6
