    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
      @sjn001tvh said:
      HOW CAN I REMOVE THIS UTILITY FROM MY SYSTEM????
      Are you still using SketchUp 2016 as indicated in your forum profile?
        jasminsreichle Newcomers
        it does not offer the otion to download anything. Not even after signing up for a free profile.
          You download RBZs from the PluginStore and install them using the Extension Manager dialog's install button...
          Restart SketchUp to sync everything...
          LibFredo6 offers support to Fredo's other extensions [which you also need to install].
          You also need the SketchUcation toolset installing,because that does the licensing stuff used by many of Fredo's paid-for extensions.
          Using the SketchUcation ExtensionStore dialog to auto-install other plugins sidesteps the need to down their RBZs... so perhaps install that first, then use it to auto-install the others...
            Scamper4ever Newcomers
            How do I download into sketchup 2023. Did I get scammed? its so stupid. Explain to me NOW!
              prinjke Newcomers
              I have issues loading FredoScale. Message keeps popping up saying it requires LibFredo6 version >= 129 but I have the most recent version.
                stkfig Newcomers
                Hey Fredo6
                I have the 3 seat JointPushPull plugin, but my old work laptop graphics card died and it will not let me open SketchUp to release the seat on the old machine and IT has taken the laptop away from me.
                Is there a way to remotely release that seat from the old laptop?
                Tim
                  See this topic which covers license management vis SketchUcation.com
                  If the defunct device had an old licensing setup then you might not be able to do it this way...
                  In which case PM Fredo or Rich with a list of the licenses to be released and will probably be able to help you...
                  However, it'll be quicker to do it yourself, if you can...
                    leranong Newcomers
                    Hi there!
                    SketchUp Pro 2023.
                    I tried yo install libfredo (the latest version),and RoundCorner (the latest versionm) but something went wrong. it is shown that it is installed in the Extension Manager but nothing is displayed. I found that I have to install ExtensionStore, I did it, but nothing changed. the message that I need to install the latest version of libfredo always appears, but it has been already installed. I've read that many people has the same issue but i haven't found the answer how to repair it. Please help me!
                      @leranong
                      While we wait for Fredo to reply...
                      Being unable to read installed files is often a clue to an incorrect installation of SketchUp.
                      You don't need to reinstall it, but do the following... which will not impact on any customization thus far...
                      Close SketchUp.
                      Find its installer exe file [usually in your Downloads folder]
                      Select its icon, right-click > context-menu > 'Run as administrator'
                      When prompted by the dialog that will open choose 'Repair'.
                      When if is completed, retry SketchUp and see if the problems are gone.
                      Installing a complex app by double-click its installer's exe file to 'Run' it, is not the same as doing it as I describe; even if you have admin powers the results will vary unpredictably - often messing up permissions.
                      Also make sure you have the latest versions of Fredo's exensions, his LibFredo, and the SketchUcation Tools [for licensing] installed and SketchUp restarted to sync everything...
                        leranong Newcomers
                        @tig said:
                        @leranong
                        Close SketchUp.
                        Thank you for trying to help me, appreciate it. But it doesn't work for me, the problem is repeated - these files can't be opened. I did what you said and also tried to uninstall everything and reinstall - but nothing helps. It seems that the only way is to reinstall my Windows))))))
                        • fredo6F Offline
                          This seems to be a Sketchup problem, already reported by users and independent from LibFredo6.
                          Usually, it is related to permissions.
                          A clean installation of Sketchup with admin rights is what is recommended.
                          • fredo6F Offline
                            NEW RELEASE: LibFredo6 v14.3a - 30 Mar 24
                            LibFredo6 14.3a includes changes related to:
                            • Future compatibility
                            • Various bug fixes and adjustments
                            • fredo6F Offline
                              NEW RELEASE: LibFredo6 v14.3b - 31 Mar 24
                              LibFredo6 14.3b includes changes related to:
                              • Correction for Check Plugins for Update (due to the migration of the Sketchucation forum)
                              S 1 Reply Last reply Reply Quote 0
                                santiagoyagogil @fredo6
                                Buenas, de manera repentina me han dejado de funcionar los complementos de Fredo.
                                He podido averiguar que no se cargan las Libfredo, las he instalado de nuevo varias veces
                                pero no consigo que funcione. Me sale este mensaje en la consola de ruby
                                Que instalado varias veces le LibFedro y el Sketchup. Pero sigo igual.
                                Algunas idea de como solucionarlo.
                                fredo6F 1 Reply Last reply Reply Quote 0
                                • fredo6F Offline
                                  fredo6 @santiagoyagogil
                                  @santiagoyagogil
                                  You seem to have problems with the loading of binaries.
                                  I suggest that you go to the Plugin directory and delete the Fredo6_!LibFredo6 folder. Then, resinstall LibFredo6 v14.3b.
                                  For Sketchucation ExtensionStore, I also suggest that you upgrade to version 4.4.0, even if you run SU2023.
                                  • fredo6F Offline
                                    NEW RELEASE: LibFredo6 v14.3d - 21 Apr 24
                                    LibFredo6 14.3d includes changes related to:
                                    • Correction for bugs for LordOfTheToolbars
                                      Buenas Fredo.
                                      El problemo lo tenia en dos equipos. en uno de ellos lo he solucionado dando todos los perminos a la carpeta y archico donde me daba el error de acceso denegado
                                      Pero en otro equipo de un compañero. Le sigue saliendo el Libfredo6 binary not loaded. Aunque si que le carga el resto de extensiones de Fredo. Pero no puede
                                      ejecutarlas.
                                      Que puede ser que no carge las libfredo6 Binary? donde esta ese archivo?
                                      Saludos
                                      TIGT 1 Reply Last reply Reply Quote 0
                                        TIG Moderator @santiagoyagogil
                                        @santiagoyagogil
                                        If the previously posted massage, it says 'Access denied' - so then the file is there, but access to 'run' it is stopped by your permissions for that folder.
                                        I suggest you open the C:/Users/santi/AppData/Local/Temp folder and right-click > context-menu > Properties > Security > Edit and ensure that all entries listed have 'Full control' permissions set.
                                        These should trickle down to all enclosed files and subfolders.
                                        Apply to all and close.
                                        It might take a few minutes.
                                        Try SketchUp again...
                                        Si el mensaje publicado anteriormente dice "Acceso denegado", entonces el archivo está ahí, pero el acceso para "ejecutarlo" está detenido por sus permisos para esa carpeta.
                                        Le sugiero que abra la carpeta C:/Users/santi/AppData/Local/Temp y haga clic derecho > menú contextual > Propiedades > Seguridad > Editar y asegúrese de que todas las entradas enumeradas tengan configurados los permisos de "Control total".
                                        Estos deberían llegar a todos los archivos y subcarpetas adjuntos.
                                        Aplicar a todos y cerrar.
                                        Puede que tarde unos minutos.
                                        Prueba SketchUp de nuevo...
                                        • fredo6F Offline
                                          fredo6 @TIG
                                          @santiagoyagogil
                                          it might also be a problem of Sketchup installation.
                                          Did you install with 'Run as Administrator'?
                                          S 1 Reply Last reply Reply Quote 1
                                            Gracias . Solucionado.
                                            Era un tema de permisos. al final al poner todas las entradas de permisos en "on" de la carperta Temp se ha solucionado el problema.
                                            Saludos
                                            [Thank you . Solved.
                                            It was a permissions issue. In the end, setting all the permissions entries to "on" in the Temp folder solved the problem.]
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 109
                                            • 110
                                            • 13 / 110
