    D5 Render Work
    95 Posts 12 Posters 16.1k Views 12 Watching
    • L
      @ntxdave said:
      OK, I have a really silly question: when it says live sync, does that ,Ean that everything takes place on your calendar computer/laptop or is this being done on an external device (like an internet device/server)? Yes, this is a silly question that might be answered somewhere on their web site. ๐Ÿ˜ฎ
      Also, I did not see pricing anywhere. Guess I should not be in such a rush when I visit a website.
      Are you talking about D5? If so it is free unless you want a great deal of assets. If so you could go for the pro, which is fairly cheap, at about half the price of Twinmotion. And unlike TM you can pay monthly $30 US a month or $360 anually.
      About synking it is purely that it is a "Bridge" between whatever modelling program you use and D5. Imagine the oputput code of Revit is completly different output code to say the output code of Sketchup.
      • ntxdaveN
        ntxdave
        Thanks for a quick reply. ๐Ÿ‘
        So, I takes it that everything happens on the computer where I am using SU.
        Press F1...thank me later
        • L
          I am assuming it is offline synking, I cant say for sure. Somebody else can answer that. I base that assumpion on the fact that I thing online synking would take forever so I am pretty sure the file coverion code is done internally.
          FYI, I had a play with D5 and thought it was pretty good but I had issues with the way it saved, files (When I saved and tried to open it again It had like 5 files that I did not know which file/files to open, did my head in so I uninstalled it.
          • marked001M
            marked001
            Yes, whatever you change in the model is instantly changed in real time in D5. It will also move the camera around in D5 as you move it in SketchUp. Lumion does the same and I'm sure a bunch of others these days.
            Definitely way cheaper than most for the pro. Part of the reason I wanted to try switching. Lumion has moved to a subscription model, as well so if I want to upgrade its like $1200/year vs $380ish for D5.
            http://www.revision21vis.com
            instagram: revi21on
            • L
              I think the price of lumion is stupid and not sure in the current climate of render engines thos prices cannot be justified. The other problem I have with Lumion is that I have alway thought it does not render very well and just about everything I have seen on lumion I say "That is a lumion render" It looks slightly comic to me.
              • jo-keJ
                jo-ke
                Wow. I like the interior.
                http://www.zz7.de
                • ntxdaveN
                  ntxdave
                  I agree. ๐Ÿ‘
                  • marked001M
                    marked001
                    Thanks guys ๐Ÿ‘
                    instagram: revi21on
                    • marked001M
                      marked001
                      A few more D5 renders...
                      instagram: revi21on
                      • marked001M
                        marked001
                        Another quick one from this afternoon.
                        instagram: revi21on
                        • Bryan KB
                          Those interiors are smashing! ๐Ÿ‘
                          • ntxdaveN
                            ntxdave
                            Sure are. ๐Ÿ‘ ๐Ÿ‘
                            • pixelcruncherP
                              Great work! Very realistic renders.
                              • marked001M
                                marked001
                                cafe render...
                                instagram: revi21on
                                • ntxdaveN
                                  ntxdave
                                  Nice ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                  I wish I could come up with something like this. ๐Ÿ˜„
                                  • marked001M
                                    marked001
                                    Its all the software! Very easy to get good results.
                                    instagram: revi21on
                                    • ntxdaveN
                                      ntxdave
                                      I meant coming up with the model itself. I donโ€™t seem to be able to design something like this. Yes, once designed the render engines are making it somewhat easier to come up with good renders.
                                      I like your results. ๐Ÿ‘ ๐Ÿ‘
                                      • marked001M
                                        marked001
                                        Well I definitely do not design the majority of the stuff I post. Some when its conceptual and there isn't actually a design or when we're working through a design. But for the most part, these are all other's designs.. in case that wasn't clear.
                                        instagram: revi21on
                                        • ntxdaveN
                                          ntxdave
                                          Thanks for the reply. Where do you find stuff like this (and your other neat scenes/models)?
                                          • marked001M
                                            marked001
                                            99% of this stuff is paid work so comes from the architect, designer, broker, etc. Sometimes its just a plan and some photo reference of what they want, sometimes plans and elevations and complete finishes.
                                            instagram: revi21on
                                            • 1 / 5
