    D5 Render Work
    95 Posts 12 Posters 10.7k Views 12 Watching
    • Bryan KB Offline
      Top notch interior! World class! ๐Ÿ‘
        @ntxdave said:
        OK, I have a really silly question: when it says live sync, does that ,Ean that everything takes place on your calendar computer/laptop or is this being done on an external device (like an internet device/server)? Yes, this is a silly question that might be answered somewhere on their web site. ๐Ÿ˜ฎ
        Also, I did not see pricing anywhere. Guess I should not be in such a rush when I visit a website.
        Are you talking about D5? If so it is free unless you want a great deal of assets. If so you could go for the pro, which is fairly cheap, at about half the price of Twinmotion. And unlike TM you can pay monthly $30 US a month or $360 anually.
        About synking it is purely that it is a "Bridge" between whatever modelling program you use and D5. Imagine the oputput code of Revit is completly different output code to say the output code of Sketchup.
        • ntxdaveN Offline
          ntxdave
          Thanks for a quick reply. ๐Ÿ‘
          So, I takes it that everything happens on the computer where I am using SU.
          Press F1...thank me later
            I am assuming it is offline synking, I cant say for sure. Somebody else can answer that. I base that assumpion on the fact that I thing online synking would take forever so I am pretty sure the file coverion code is done internally.
            FYI, I had a play with D5 and thought it was pretty good but I had issues with the way it saved, files (When I saved and tried to open it again It had like 5 files that I did not know which file/files to open, did my head in so I uninstalled it.
            • marked001M Offline
              marked001
              Yes, whatever you change in the model is instantly changed in real time in D5. It will also move the camera around in D5 as you move it in SketchUp. Lumion does the same and I'm sure a bunch of others these days.
              Definitely way cheaper than most for the pro. Part of the reason I wanted to try switching. Lumion has moved to a subscription model, as well so if I want to upgrade its like $1200/year vs $380ish for D5.
              http://www.revision21vis.com
              instagram: revi21on
                I think the price of lumion is stupid and not sure in the current climate of render engines thos prices cannot be justified. The other problem I have with Lumion is that I have alway thought it does not render very well and just about everything I have seen on lumion I say "That is a lumion render" It looks slightly comic to me.
                • jo-keJ Offline
                  jo-ke
                  Wow. I like the interior.
                  http://www.zz7.de
                  • ntxdaveN Offline
                    ntxdave
                    I agree. ๐Ÿ‘
                      marked001
                      Thanks guys ๐Ÿ‘
                      instagram: revi21on
                        marked001
                        A few more D5 renders...
                        instagram: revi21on
                          marked001
                          Another quick one from this afternoon.
                          instagram: revi21on
                          • Bryan KB Offline
                            Those interiors are smashing! ๐Ÿ‘
                            • ntxdaveN Offline
                              ntxdave
                              Sure are. ๐Ÿ‘ ๐Ÿ‘
                                Great work! Very realistic renders.
                                  marked001
                                  cafe render...
                                  instagram: revi21on
                                  • ntxdaveN Offline
                                    ntxdave
                                    Nice ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                    I wish I could come up with something like this. ๐Ÿ˜„
                                      marked001
                                      Its all the software! Very easy to get good results.
                                      instagram: revi21on
                                      • ntxdaveN Offline
                                        ntxdave
                                        I meant coming up with the model itself. I donโ€™t seem to be able to design something like this. Yes, once designed the render engines are making it somewhat easier to come up with good renders.
                                        I like your results. ๐Ÿ‘ ๐Ÿ‘
                                          marked001
                                          Well I definitely do not design the majority of the stuff I post. Some when its conceptual and there isn't actually a design or when we're working through a design. But for the most part, these are all other's designs.. in case that wasn't clear.
                                          instagram: revi21on
                                          • ntxdaveN Offline
                                            ntxdave
                                            Thanks for the reply. Where do you find stuff like this (and your other neat scenes/models)?
                                            • 1 / 5
