    2.2k Posts 487 Posters 932.9k Views 492 Watching
    • fredo6F Offline
      Within 4 weeks, the licensing makes randomly 4 attempts to check the license online. If none of them can go through, then you need to revalidate online.
      • N Offline
        numerobis
        Thanks for the clarification. So it can be 4 weeks or anything before? Has it always been like this? Because i had to reactivate every 5 or 7 days the last time i tried it.
          raksiw
          hey i bought fredo join push tool and it said that there's an error in generation in geometry.. what should i do
          • fredo6F Offline
            First, this is not related to Licensing. So better post in the JPP thread in this forum.
            Errors in the generation of geometry are related to your model.
            The best is to
            • Post or PM the model
            • Post the content of the Pink dialog where you see the error (there is an export as txt button.
              Momotaro45
              How can i fix this ?
                Your licensing version is outdated. Please updated Sketchucation Tools and Libfredo
                https://sketchucation.com/plugin/696-sketchucationtools
                https://sketchucation.com/pluginstore?pln=LibFredo6
                We are also performing server maintenance currently but that will be restored shortly.
                  jennnyjiho
                  I purchased the license however it says there is an error in validating License. How should I solve this problem?
                  • TIGT Online
                    Install the latest version of the SketchUcation Toolset.
                    It includes a much newer version of the Licensing system.
                    Also ensure you have the latest LibFredo6 and any extensions installed.
                    Restart SketchUp after the installation[s].
                    Then try validating a license...
                      jfussa19
                      Hi.
                      My user name is jfussa19.
                      I got my full fredo 6 license, however I Have not been able to validate it on my sketchup. I got this screen and then in the explorer I don't find the SCF License. It happens with the whole plugins I got purchased.
                      Can you help me with this?
                      • fredo6F Offline
                        Could you do what is suggested in the message box and advise if this fixes the issue.
                          tenrev
                          Good morning
                          can you tell me if there is a way to reset your licenses
                          I no longer have access to two of my old PCs which are out of order, so I have 4 Fredo6 licenses where the 3 seats are used, I would like to reset everything and be able to reactivate the seats on other PCs
                          I saw the question asked by others but no answer?
                          thank you for your reply
                          biblio3d forum sketchup - artlantis - piranesi
                          http://www.biblio3d.com
                            Please check https://sketchucation.com/webshop/my-licences.php
                            All cureent and future devices will need Sketchucation Tools 4.3.1 installed. This will allow you to manage seat releasing yourself going forward
                              tenrev
                              great thank you, I had just installed version 4.3.1 and I'm not going to restart sketchup sorry, the main thing now it works, thank you again for the quick response
                                ramonbastos
                                but I cant find the option to do that on https://sketchucation.com/webshop/my-licences.php like you mentioned
                                If the device was activated using Sketchucation Tools < 4.3 then you won't see checkboxes at https://sketchucation.com/webshop/my-licences.php
                                Go to the device and upgrade Sketchucation Tools
                                  jaroslavz
                                  Can you reset my 3 stucked seats, please? Thank you very much:
                                  fredo scale
                                  Seat ID: 99818; HW ID: ZB1653811604.0U; Date of activation: 21/05/2023
                                  Curviloft:
                                  Seat ID: 117152; HW ID: QW1685472429.0E; Date of activation: 28/08/2023
                                  Seat ID: 140165; HW ID: UH1651220680.0W; Date of activation: 10/01/2024
                                  • fredo6F Offline
                                    fredo scale
                                    Curviloft:
                                    This is done now.
                                      sorin3dstudio
                                      Hello ,
                                      I have the same problem as many other users, I changed the computers name and now I cant use Fredo tools, I dont remember my former computer name and also I cant rename it because I have other programs installed...
                                      I need to understand if I have any option to fix this problem.
                                      Sorin
                                        Sorin
                                        Follow the advice in the alert.
                                        Close SketchUp
                                        Delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file at C:\Users\SomeName\AppData\Local\SCF Licenses
                                        Open SketchUp
                                        Try activating
                                        If that fails use the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu to open the console and copy/paste the text into your reply here
                                          marypacheco08
                                          Hi how are you I have a question:
                                          To use all the fredo tools, also to use round corner and curviloft what are the license that I need to get, this one SCFLicense??? or how many others?
                                            SketchUcation | Cart
                                            (sketchucation.com)
                                            https://i.imgur.com/LcadleC.png
                                            • 93
                                            • 94
                                            • 95
                                            • 96
                                            • 97
                                            • 109
                                            • 110
                                            • 95 / 110
