    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    597 Posts 120 Posters 2.2m Views 120 Watching
    • G
      Gelombaasue
      Antes que nada, muchas gracias por el plugin. La verdad es que es el mejor y el más completo que he encontrado para sketchup. No obstante, estaría muy bien que agregarán una opción para que de alguna manera las animaciones (o fotogramas) se puedan "guardar" directamente en sketchup y que más tarde uno pueda visualizarlas aún no teniendo el plugin (algo parecido a lo que hace el plugin keyframe), de este modo se tendrían más opciones para renderizar en cualquier motor de render que funcione con sketchup
        apdapd Newcomers
        看不到图标
          apdapd Newcomers
          @apdapd said:
          看不到图标
          • fredo6F
            Please upgrade to the latest version of LibFredo6.
              rown2000
              Hello Fredo, is there a possibility of using twilight render when making a video instead of vray?
              thanks, great job.
              • ntxdaveN
                ntxdave
                Yes, that is an option. I am not on my laptop right now so I can generate a screenshot.
                You can add Twiligt Render to the section where you generate the video.
                Again, sorry I cannot give you a screenshot.
                Press F1...thank me later
                • T
                  Teunvanlith Newcomers
                  Hello Animators,
                  I am doing a lot of animations for a project in construction.
                  Slowly I am understanding the tool better and better.
                  In a small project I am working on right know I have something that made me very happy, but I don't understand when it happens.
                  I copied a group which is animated. When I copied this file just next to it and play the animation both elements move. Which is great for enhanced workflow.
                  But when I copy another element that is also animated, it doesn't copy the animation. See pictures.
                  I tried everything but can't find the difference in the files or settings. Can somebody pleas tell me when it copies the animation and when not. I would love to copy with the same animation!
                  Thanks in advance!
                  Does copy animation
                  Does not copy animation
                  • fredo6F
                    Difficult to tell ithout having the model.
                    Be careful however with groups (versus Components). A freshly copied group behaves as a component, until you enter it. Then the group becomes unique.
                    Anyway, I am not sure you can copy an animation by copying a group. If this works, then it is by accident or unless you activate the Kinematics 'All instances', but hich orks for components only.
                    • fredo6F
                      New Release: Animator - v3.9a - 30 Dec 23
                      Requirement: LibFredo6 v13.6
                      Maintenance release
                      • Extension of validity
                      See plugin home page of Animator for Download of RBZ from the PluginStore.
                      See Main Post of the Animator thread for more information.
                      • Gordon GreenwoodG
                        Gordon Greenwood
                        Hi All
                        i have the latest animator, and also the full version of the Video generator, i use a good windows system with good processore, however?
                        i only do small movements ( not multiples) and small frame rates 161/200 max generate at 25 per second. i managed to do two small videos, then it wont let me make new videos, i have unloaded and reloaded all of the software rbz and also video editor, the paths are correct? but after a couple of videos BOOM wont work anymore? HELP
                          rown2000
                          hellow, sorry I don´t know how add twilight to the section where i generate the video. the option is not present. only can see Natural and Vray in SU 2017, in SU 2023 don´t install vray, only twiligt.
                          thanks you
                          • fredo6F
                            Did you install Twilight in your Sketchup environment?
                              rown2000
                              yes, in SU 2017 I installed twiligh and vray but any can´t see in the video editor of animator.
                              In SU 2023 only installed twiligh, but it also dosen´t work.
                              are there any option to choose the renders motor that we want? setting the motor route manually?
                              thanks, your work is the best
                              • fredo6F
                                If you installed Twilight and it is a compatible version, it should automatically appear in the list of Rendering software in Animator.
                                Can you run Twilight in Sketchup (independently of Animator)?
                                Can you give me the version of Twilight.
                                  jerrylambe
                                  Hi All,
                                  Ref: macOS Sonoma 14.2.1 (23C71)
                                  After Mac (Studio) update along with macOS Sonoma 14.2.1 I can’t seem to get FFmpeg to load, to create videos within Animator. Would rather record inside SU than using screen record etc. Would appreciate any help/ideas? > Love this pLugin.
                                  Many Thanks,
                                  Jerry
                                    rown2000
                                    is Twilight Render V2, Hobby, x64 for Windows. it´s a free version
                                    • fredo6F
                                      There may be a new version of FFmpeg compatible with Sonoma, as this upgrade of MacOS is causing several problems in many software, including Sketchup. Did you download and install a recent version, marked compatible?
                                      I'll check on my side when I have time, although I did not upgrade to Sonoma.
                                        jerrylambe
                                        I think I downloaded the latest version not 100% certain and not sure if it was Sonoma friendly? Doing several presentations (using Animator) at the moment and getting by with Screen Recording - so no rush. Many thanks!
                                        N 1 Reply Last reply
                                        • N
                                          nick2196 @jerrylambe
                                          Is there a way to save the frames as jpg instead of png? I am rendering using vray, and saving as png does not save the background information. I am hoping the animation could show the background so I can show how the exterior looks thru windows.
                                          • fredo6F
                                            New Release: Animator - v4.0a - 02 Apr 24
                                            Requirement: LibFredo6 v14.3b
                                            Animator 4.0a is a maintenance release for:
                                            • Future compatibility
                                            J R Rich O BrienR 3 Replies Last reply
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 25 / 30
