    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    597 Posts 120 Posters 2.2m Views 120 Watching
    • fredo6F Offline
      You can have as many camera as you wish, but in sequence.
      You can set each camera to fade out at the transition with the next one (orange underline of the camera object in the timeline).
      What I say is that the interpolation is done between 2 cameras, not 3 cameras.
      In your case, you probably need to set fade-out transitions.
      The best would be that I see the model.
      • ntxdaveN Offline
        ntxdave
        Fredo, just curious if you have looked at integrating D5 Render with Animator?
        Press F1...thank me later
        • fredo6F Offline
          New Release: Animator - v3.8a - 25 Dec 22
          Requirement: LibFredo6 v13.6
          Maintenance release
          • Bug fixing
          • Extension of validity
          See plugin home page of Animator for Download of RBZ from the PluginStore.
          See Main Post of the Animator thread for more information.
            ARS2Rust
            WHEN I USE ANIMATOR WITH VRAY, I CANNOT GET IT TO USE MY EXTERNAL GPU. SINGLE FRAMES HIT THE eGPU BUT NOT THE ANIMATION FRAMES FROM ANIMATOR.
            THOUGHTS?
            PARK WARNE
            • fredo6F Offline
              THOUGHTS?
              For the time being, Animator uses the direct API to VRay, which is not triggering GPU calculations.
                thalisongil
                how to transform any frame from fredo animator plugin in a new scene inside sketchup? I’ve been create a animation with some frames using the fredoanimator. How can I to transform any frame from fredo animator in a new scene in my sketchup?
                My objective: If i get to create these scenes, i'll to render with Enscape using the batch render,so.. If i create all these scene i can generate a "Property Brothers" effect. I gotcha this with the Keyframe Animator, but, this plugins doens't has a lot options like the fredo animator.
                (sowwy for my grammar errors, i'm brazilian and i'm not fluency 😄 )
                • fredo6F Offline
                  For object animation, it does not really make sense, since scenes would not capture the object movements.
                  And if you just need a camera animation, then create your scenes manually. Sketchup will animate the transition between scenes and you can even record the whole animation to a MP4 file.
                    rclubb
                    @fredo6 said:
                    THOUGHTS?
                    Are there any plans for getting this to work with GPU rendering? I love the plugin and I would happily pay to have a version that would utilize the GPU.
                    I'm currently in the middle of a render with V-Ray that is going to take 17 hours for a 14 second clip with 211 frames at 785x800 resolution. Is there any way to cut down the time without killing any more of the quality? This is just for a test, I would like to render a much higher resolution.
                    My specs:
                    HP OMEN 30L
                    Ryzen 9 5900x
                    RTX 3090
                    • fredo6F Offline
                      No immdiate plan. Actually, I don't know yet how to do it and even if it is possible.
                        Gelombaasue
                        Antes que nada, muchas gracias por el plugin. La verdad es que es el mejor y el más completo que he encontrado para sketchup. No obstante, estaría muy bien que agregarán una opción para que de alguna manera las animaciones (o fotogramas) se puedan "guardar" directamente en sketchup y que más tarde uno pueda visualizarlas aún no teniendo el plugin (algo parecido a lo que hace el plugin keyframe), de este modo se tendrían más opciones para renderizar en cualquier motor de render que funcione con sketchup
                          apdapd Newcomers
                          看不到图标
                            apdapd Newcomers
                            @apdapd said:
                            看不到图标
                            • fredo6F Offline
                              Please upgrade to the latest version of LibFredo6.
                                rown2000
                                Hello Fredo, is there a possibility of using twilight render when making a video instead of vray?
                                thanks, great job.
                                • ntxdaveN Offline
                                  ntxdave
                                  Yes, that is an option. I am not on my laptop right now so I can generate a screenshot.
                                  You can add Twiligt Render to the section where you generate the video.
                                  Again, sorry I cannot give you a screenshot.
                                    Teunvanlith Newcomers
                                    Hello Animators,
                                    I am doing a lot of animations for a project in construction.
                                    Slowly I am understanding the tool better and better.
                                    In a small project I am working on right know I have something that made me very happy, but I don't understand when it happens.
                                    I copied a group which is animated. When I copied this file just next to it and play the animation both elements move. Which is great for enhanced workflow.
                                    But when I copy another element that is also animated, it doesn't copy the animation. See pictures.
                                    I tried everything but can't find the difference in the files or settings. Can somebody pleas tell me when it copies the animation and when not. I would love to copy with the same animation!
                                    Thanks in advance!
                                    Does copy animation
                                    Does not copy animation
                                    • fredo6F Offline
                                      Difficult to tell ithout having the model.
                                      Be careful however with groups (versus Components). A freshly copied group behaves as a component, until you enter it. Then the group becomes unique.
                                      Anyway, I am not sure you can copy an animation by copying a group. If this works, then it is by accident or unless you activate the Kinematics 'All instances', but hich orks for components only.
                                      • fredo6F Offline
                                        New Release: Animator - v3.9a - 30 Dec 23
                                        Maintenance release
                                        • Gordon GreenwoodG Offline
                                          Gordon Greenwood
                                          Hi All
                                          i have the latest animator, and also the full version of the Video generator, i use a good windows system with good processore, however?
                                          i only do small movements ( not multiples) and small frame rates 161/200 max generate at 25 per second. i managed to do two small videos, then it wont let me make new videos, i have unloaded and reloaded all of the software rbz and also video editor, the paths are correct? but after a couple of videos BOOM wont work anymore? HELP
                                            rown2000
                                            hellow, sorry I don´t know how add twilight to the section where i generate the video. the option is not present. only can see Natural and Vray in SU 2017, in SU 2023 don´t install vray, only twiligt.
                                            thanks you
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 29
                                            • 30
                                            • 24 / 30
