    Rayscaper Alpha Version Available
    114 Posts 14 Posters 21.8k Views 14 Watching
      OK, where is the material editor available please? I get the toolbar but the plugin does not appear in the extensions drop down menu.
      • pixelcruncherP
        Hey Mike,
        There's a quick start guide on the plugin page: https://sketchucation.com/plugin/2677-rayscaper - Have a look at the quick start video; in case that's not enough, I sent you a message and can help to unblock you.
        Cheers,
        Thomas
        • ntxdaveN
          ntxdave
          I am having a problem installing and implementing the Rayscaper plugin. After the installation, here is the problem I am seeing:
          1. The plugin has been installed
          2. The toolbar does not show up in the SketchUp toolbar
          3. When you try to view the available toolbars, Rayscaper does not show up as an option.
          I also tried closing SketchUp and reopening and the results are still the same.
          What have I done wrong?
          Press F1...thank me later
          • pixelcruncherP
            [attachment=0:2drdux3b]<!-- ia0 -->Rayscaper Install Problem.png<!-- ia0 -->[/attachment:2drdux3b]
            Hey Dave,
            You are right, I can reproduce it here. If you open the Ruby console (Window > Ruby Console) you will see that there's an issue loading Rayscaper when opening SU 2020.
            It's only for SU 2020, which I haven't tested (Only SU 2023 / 2022 / 2021). I'm figuring out what's happening and will provide an update here.
            Cheers,
            Thomas
            • ntxdaveN
              ntxdave
              Thanks for the feedback. I thought I had done something wrong. 2020 is the latest version I have and Rich's model was 2020 so I expected everything to go smoothly. πŸ˜„
              BTW: When I comes time to document the plugin, I would suggest you look at [ur=https://skatter.help.lindale.io/getting-startedl]Skatter Help[/url]. They have a great (IMO) site for learning how to used the features of their plugin. πŸ˜„
              • ntxdaveN
                ntxdave
                I just saw your documentation on the Rayscaper website. You can ignore my documentation comment in my previous post. I think it is headed in a great direction. πŸ˜„ Rayscaper Documentation
                Even though it is still a work in progress, you should have them post a link to it on the SketchUcation plugin page. It would let potential users see where you are headed.
                • ntxdaveN
                  ntxdave
                  On yesterday's post, I should have also included the SketchUp View>Toolbars window that showed that Rayscaper also did not show up there as an option. I am sure you know (found it out) as well but I am showing it here incase others may also be trying it. πŸ˜„
                  • pixelcruncherP
                    BTW: When I comes time to document the plugin, I would suggest you look at Skatter Help. They have a great (IMO) site for learning how to used the features of their plugin. πŸ˜„
                    Edit I would also suggest that you check back to 2017. I see a number of users on this forum that are still using 2017. I would also suggest you post an interior and an exterior render. πŸ˜„
                    Hey Dave,
                    I figured out that supporting SU2020 requires another Rayscaper build (because it requires re-compilation against a different Ruby version). This is a bit more work, can you try it out with SU2021 or higher?
                    Thanks for the pointer to the Skatter docs, that's indeed great documentation. As you already noticed, I started creating my own documentation here: https://rayscaper.com/docs/
                    Yeah, I should post more renders, the problem is that I am not an artist/creator. So my strategy is to keep fixing bugs and making improvements until someone comes along and finds it good enough to create a good render πŸ˜‰
                    Regards,
                    Thomas
                    • ntxdaveN
                      ntxdave
                      @pixelcruncher said:
                      @ntxdave said:
                      Hey Dave,
                      No, 2020 is the latest version I have.
                        https://i.imgur.com/4TfqTPi.png
                        • ntxdaveN
                          ntxdave
                          Nice Rich πŸ‘
                          Do you have an interior and/or exterior model that you could render and post in this thread?
                            Here's an interior render of a guggenheim-ish type scene...
                            Rayscaper is still earlier in development so I'm reluctant to push it. It does have certain shading artifacts that I've let Thomas know about.
                            But overall I think it's very capable. I love the Polyhaven integration.
                            • soloS
                              Is there a shadow catcher material?
                              • ntxdaveN
                                ntxdave
                                Thanks Rich. I as hoping for something like a room or office setting but I understand that it is early in the cycle. Wish it would work with SU 2020.
                                • pixelcruncherP
                                  Not yet, but it's planned, should be there in a couple of weeks.
                                  Here's the planned road map for 1.0: https://rayscaper.com/docs/roadmap/
                                  Cheers,
                                  Thomas
                                  • ntxdaveN
                                    ntxdave
                                    Thanks for sharing the release plans. πŸ‘ πŸ‘
                                    Just hoping I will be able to use with SU 2020 and that it will be something I can afford. πŸ˜„
                                    • pixelcruncherP
                                      Yes, I'm looking into supporting SU2020. It will be part of one of the upcoming releases.
                                      And yes, I plan to offer great software that everyone can afford. Of course with a discount for premium members.
                                      Cheers,
                                      Thomas
                                      • P
                                        pc10pc Newcomers
                                        I'm on SU 21.1.332 and having the same issues with toolbar not showing up.
                                        • pixelcruncherP
                                          @pc10pc said:
                                          Could you check if you can get it via these instructions? If that doesn’t help, send me a private message.
                                          Cheers,
                                          Thomas
                                          • majidM
                                            majid
                                            I watched your YouTube video and seems the engine is great. Just installed and seems I have a problem. Maybe because I have no SCF plugin toolbar installed.
                                            PS: it solved, I installed the SCF plugin and now I have the Rayscraper!
                                            • 1 / 6
