    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 726.0k Views 99 Watching
    • panixiaP
      panixia
      Thank you so much, Fredo! β˜€
      • O
        optimaforever
        I panicked too. Lost 2 hours at noon trying to figure out where was the problem.
        There was !!Lordofthetoolbars folder in my sketchup plugin folder, I am in admin mode and yet the LOT plugin is not loaded at boot.
        I had updated all my plugins and scripts as asked by SU and with the Sketchucation toolbar.
        No idea of the culprit.
        And then, I had an idea.
        What if the FredoLib wasn't correctly updated? No red flags whatsoever from SU nor SKU toolbar but, what if I FORCE UPDATE FredoLib?
        I just did that and TADAAAH LOT is back with its toolbars. πŸ˜„
          What if you open the Sketchucation Extension Store and click on the red button at the top? If there are extensions from Sketchucation that need updating, they would be shown there. I did that earlier today and it showed a couple of Fredo6's extensions needed updating. I clicked on Update All and now it loks like this:
          • O
            optimaforever
            [attachment=0:3nz2sv2x]<!-- ia0 -->Screenshot - 10_31_2023 , 8_16_36 AM.png<!-- ia0 -->[/attachment:3nz2sv2x]
            Precisely.
            I did that and it updated several things, including LibFredo.
            Therefore I wans't suspecting LibFredo but it was actually the problem.
              I open that window two or three times a month to see if there are any extensions that need updating. I also have Fredo's Check Fredo6 Plugins for Update setup so that it offers to check every 15 days. As you know, Fredo is very active with making updates and bug fixes to his extensions so it's worth keeping your installation of them up to date. The last LibFredo6 update occurred in late August.
              • O
                optimaforever
                Indeed, Fredo keeps updating his plugins but I must reckon his update check window bugs me more than I find it useful. I never push the check update button as I prefer SU or Extension store toolbar way of warning for updates. Now you make me realize, I wrote 999 days before the next update check πŸ˜„ Very nice idea, thanks Dave! πŸ˜„
                What I'd suggest to Fredo is to include LibFredo as a mandatory download when updating all his plugins. Anyway it takes an additional fraction of seconds these days with the download speeds. Anyway you need to reboot SU so...
                  Studiospectre
                  Unfortunately my menu bar is still completely gone 😞
                  I think I'll finally upgrade from 21 to 23 or even 24 and port everything over, I think I'm going to be forced to eventually. I know I'm whining but it's such a pain to move over all your plugins and extensions. Such is life.
                  Anyhow, Thanks Fredo, you do amazing work.
                    Try restarting SketchUp.
                    What version of SketchUp are you currently using? Your profile says 2015.
                    SketchUp 2024 isn't available yet.
                    ... but it's such a pain to move over all your plugins and extensions.
                    It shouldn't be. After installing the new version of SketchUp, install the current version of the Sketchucation Extension Store, sign in to Sketchucation with it, and install your extension bundle. That will install the most current versions of your extensions from Sketchucation.
                    • panixiaP
                      panixia
                      Naa.. It works fine in 2021 (tbh it works way better than it does on 2023 due to the 23 UI limitation).
                      You probably messed up the install.
                      Make sure to download and install this:
                      LibFredo6 | SketchUcation
                      (sketchucation.com)
                      THEN download and install this:
                      LordOfTheToolbars | SketchUcation
                      (sketchucation.com)
                      Reboot Sketchup and you toolbars will show up again.
                        maximumselfish
                        Personal Commands => menu still not working. New personal command creation is not available.
                          SCMC Newcomers
                          This tool looks awesome! However, I can't drag any icon to any palette. Can someone kindly enlighten me?
                          • T
                            thanoscy
                            Thank you for the update. (probably there is a type mistake the release is until 31.10.2024 and not 31.10.2023..
                            Thank you again!
                              MrWip
                              Everything is back to normal for me, thanks a lot Fredo !
                              http://www.wip-archi.com
                              • B
                                Blns Newcomers
                                (sketchucation.com)
                                (sketchucation.com)
                                My toolbars still aren't activated... 😞
                                I tried to instell the extension in the second link you posted, but it still has an expiration date at 31.10.2023, is this the problem?
                                • C
                                  carlosmgilp
                                  Hello how are you.
                                  My version of 2.5a expired.
                                  When will there be a new update?
                                  Or how can I solve this problem.
                                  Thank you.
                                  • cmeedC
                                    cmeed
                                    Hi All,
                                    I have recently updated to SU2023 and this is my first time hearing about a UI limitation and it having a negative effect on LOTB.
                                    Since updating LOTB and SU, my personal buttons I've created, have stopped working. They are greyed out as if the extension/plugin is not associated with it.
                                    When I 'edit' or create 'New' the next window that pops up should show all the extensions/plugins to associate with the icon/button - as you see, this is Blank. even when i search...
                                    Is the UI limitation in SU2023 my problem ? or me doing it wrong? or something else, otherwise its working as expected.
                                    Cheers in Advance
                                    • fredo6F
                                      SU2023 has introduced a radical change of the UI technical framework (migrating to Qt).
                                      As a result, all features related to Menu commands and Clear Screen cannot work and are disabled in SU2023.
                                      Sorry for that. I don't think there will be a solution for the future, as there is no longer any API to access menus and screen visual elements.
                                      • panixiaP
                                        panixia
                                        I posted a workaround a few pages before
                                        403 Forbidden
                                        (sketchucation.com)
                                        • cmeedC
                                          cmeed
                                          @fredo6 said:
                                          This is indeed sad news! LOTB has speeded up my work. Its quick, easy and (was) very adapatble. I am still a keen fan and will be a tester if ever you need help with further developments.
                                          Cheers for all your hard work
                                            rv1974
                                            my 2 cents: Just make ONE large vertical (say 6X30) palette, add separators\line breaks where needed - so everything is in one place perfectly organized on the 2nd monitor. No need in extra menus or palettes (maybe except history). the rest is shortcuts and tool search
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 27
                                            • 28
                                            • 17 / 28
