    [Plugin] LordOfTheToolbars - v4.0a - 22 Sep 26
    529 Posts 101 Posters 588.5k Views 99 Watching
      SCMC Newcomers
      This tool looks awesome! However, I can't drag any icon to any palette. Can someone kindly enlighten me?
      • T
        thanoscy
        Thank you for the update. (probably there is a type mistake the release is until 31.10.2024 and not 31.10.2023..
        Thank you again!
          MrWip
          Everything is back to normal for me, thanks a lot Fredo !
          http://www.wip-archi.com
          • B
            Blns Newcomers
            @panixia said:
            @studiospectre said:
            Unfortunately my menu bar is still completely gone 😞
            I think I'll finally upgrade from 21 to 23
            Naa.. It works fine in 2021 (tbh it works way better than it does on 2023 due to the 23 UI limitation).
            You probably messed up the install.
            Make sure to download and install this:
            LibFredo6 | SketchUcation
            (sketchucation.com)
            THEN download and install this:
            LordOfTheToolbars | SketchUcation
            (sketchucation.com)
            Reboot Sketchup and you toolbars will show up again.
            My toolbars still aren't activated... 😞
            I tried to instell the extension in the second link you posted, but it still has an expiration date at 31.10.2023, is this the problem?
            • C
              carlosmgilp
              Hello how are you.
              My version of 2.5a expired.
              When will there be a new update?
              Or how can I solve this problem.
              Thank you.
              • cmeedC
                cmeed
                Hi All,
                I have recently updated to SU2023 and this is my first time hearing about a UI limitation and it having a negative effect on LOTB.
                Since updating LOTB and SU, my personal buttons I've created, have stopped working. They are greyed out as if the extension/plugin is not associated with it.
                When I 'edit' or create 'New' the next window that pops up should show all the extensions/plugins to associate with the icon/button - as you see, this is Blank. even when i search...
                Is the UI limitation in SU2023 my problem ? or me doing it wrong? or something else, otherwise its working as expected.
                Cheers in Advance
                • fredo6F
                  SU2023 has introduced a radical change of the UI technical framework (migrating to Qt).
                  As a result, all features related to Menu commands and Clear Screen cannot work and are disabled in SU2023.
                  Sorry for that. I don't think there will be a solution for the future, as there is no longer any API to access menus and screen visual elements.
                  • panixiaP
                    panixia
                    I posted a workaround a few pages before
                    403 Forbidden
                    (sketchucation.com)
                    • cmeedC
                      cmeed
                      @fredo6 said:
                      This is indeed sad news! LOTB has speeded up my work. Its quick, easy and (was) very adapatble. I am still a keen fan and will be a tester if ever you need help with further developments.
                      Cheers for all your hard work
                        rv1974
                        my 2 cents: Just make ONE large vertical (say 6X30) palette, add separators\line breaks where needed - so everything is in one place perfectly organized on the 2nd monitor. No need in extra menus or palettes (maybe except history). the rest is shortcuts and tool search
                          AISmebel
                          403 Forbidden
                          (sketchucation.com)
                          Hi. Personally, I still haven't figured out how to use your method ((( Will you have the opportunity to write instructions in more detail for noobs 😆
                          • cmeedC
                            cmeed
                            @rv1974
                            Thanks for the 2cents. Sounds great - Not sure if it helps me with the buttons I’d created for plugins that don’t have buttons. But I do take you’re point about short cuts. I have so many though it’s hard to keep them in my head, especially the ‘used occasionally’ variety. Also I am running out of suitable key combinations ! Ha ha. I tend to keep everything on the left hand side of the keyboard for speed and one hand.
                              rv1974
                              @cmeed
                              My 2c are related to your disappeared menus, custom icons are aside
                              • fredo6F
                                NEW RELEASE: LordOfTheToolbars v2.7a - 02 Apr 24
                                Requirements
                                • LibFredo6: v14.3b or above
                                LordOfTheToolbars 2.7a is a maintenance release for:
                                • Future compatibility
                                Home Page of LordOfTheToolbars for information and Download.
                                Main post of this LordOfTheToolbars thread.
                                • fredo6F
                                  NEW RELEASE: LordOfTheToolbars v2.7b - 07 Apr 24
                                  Requirements
                                  LordOfTheToolbars 2.7b is a maintenance release for:
                                  • SU2024
                                  • Fix for shortcuts
                                  • Visual adjustment for palettes
                                  A 1 Reply Last reply
                                    AISmebel @fredo6
                                    @fredo6 Hello dear Fredo. I would like to ask you if you can expect to repair the "menu" tab in new versions of SU in your future updates?
                                      Hello dear fredo, I am a heavy user of Lott. I upgraded from su2021 to 2024 and noticed some issues. When I right-click on an icon, only the system native icon like 1 will pop up a menu, while most icons like 2 will not pop up a menu. Is this my problem or is it a bug? I hope to receive your help. Thank you
                                      • T
                                        TECHDAVE02
                                        No scroll bars?
                                        can't get to the button at bottom of windows ?
                                        fredo6F 1 Reply Last reply
                                          RLGL
                                          With the 2024 version, I am trying to configure new palettes, how ever the ability to add line breaks, separators etc is missing from the right-click menu.
                                          • fredo6F
                                            fredo6 @RLGL
                                            @RLGL
                                            Do you see the commands if you right-click ON an icon?
                                            R 1 Reply Last reply
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 26
                                            • 27
                                            • 18 / 27
