    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      Grey24601
      I love this extension but I am having issues with it.
      I have updated to 13.5a. I have flattened the model using scale with a value of 0 and now I can not edit groups without them randomly appearing in the model. Any ideas FREDO??
      FREDOBUG.skp
        Davidekcek3347 Newcomers
        Does anybody knows how to crack Librfredo6 extensions?
        • V Offline
          Vander
          I don't recall this behavior when we last used this to flatten a DWG.
          Attached is the SKP file with the Original DWG Component on the Left and the Box Scaled DWG Component on the Right. When i click into the Scaled Component and try to enter the Trash Can Component (Circled in Red) the whole Component jumps to a different location as though the Axis is Changed. Also there is no Z axis shown in the scaled Component. Any Idea on why this happens? Our Workaround was to use Flatten to Plane from Eneroth. But this requires going into the individual Sub Components and Flattening. We don't want to Explode Everything and we want to keep the DWG Layers intact.
          Dropbox
          (www.dropbox.com)
          FYI: Here is the link to a post about different ways of flattening a Component via the Sketchup Forum.
          Looking for extension to create 2d projections
          SketchUp Community (forums.sketchup.com)
          John (Vander, Zvan2000)
            timbcarter
            Just bought Fredo Scale because I had a paneled design for a stair balustrade and I needed to
            skew it for the grade and then had to give it a radius on the upper section. Skewing worked well
            but the free bending doesn't seem to handle any ornamentation in the panel. It works on single plane
            flat panels but when there is a design ( 2D same as plane ) it pulls off part of the design while bending
            and then fails to complete the bend. I actually got it do do it once but all other attempts failed. I tried
            as a component and exploded and selected, still no luck. It also doesn't seem to work as shown in a
            tutorial I saw. Also the Box Plane shearing after using it I tried to make copies of the skewed panel
            and when I did it suddenly reverted back to the original shape. It did that several times and I finally got a
            copy that didn't revert. So things seeming pretty buggy to me at this point. Another comment about the
            bend, It would help if you could actuate a bend using a precise "bulge" distance like SU uses for arches.
            It's more usable for architectural purposes.
            I do love what it was trying to do
              dgannonennis
              Great plugin, thanks.
              When box stretching is it possible to input a measurement if you know the value rather than trying to stretch to the exact value?
              • fredo6F Offline
                You can show the dimension dialog by pressing TAB.
                  betofg90
                  I want to pay fredo pluggins bundle but im using a cracked sketchup, there's gonna be any problem or not?
                    Seb1986
                    Hi guys and girls is it possible to change the dimensions from Pixels to mm in the Fredoscale extensions??
                    I am trying to drag a cabinet from 900mm wide to 955mm the ideal way to do this I would just type in 55mm and it would move it the extra 55mm but this is in pixels and isn't as easy.
                      Show us a screenshot of what you are seeing. Sizing any geometry in pixels doesn't make any sense in SketchUp. Which tool are you using to change the dimensions of the cabinet? When I use Box Scaling I can just enter the desired final dimension.
                      Share the .skp file so we can see what you are working with.
                      Which version of SketchUp Pro are you using?
                        kostiaarh
                        Hello dear Fredo. Can I ask you to make a small edit to your plugin? Could we have more than 2 (3,4,5...N) scale planes in the plugin?
                          antonblam
                          Hello Fredo.
                          I don't know if it happens to anyone else.
                          I have an issue with the box scaling. I scale some geometry by a factor of 0 to make it flat - although it does the job of flattening, suddenly I can't select my geometry by cursor anymore, just by ctrl+A. I see the geometry where it should be, but for some reason I can't select it.
                          Is this a known problem? Is there a fix for that? I checked the version and I have the latest one (3.5a).
                          Thanks a lot in advance.
                          • fredo6F Offline
                            This is not really supported. By the way, you may get the issue with the native scaling.
                            • fredo6F Offline
                              NEW RELEASE: FredoScale v3.6a - 01 Apr 24
                              Requirements:
                              • LibFredo6 v14.3b.
                              • Sketchucation PluginStore v4.4.0.
                              FredoScale 3.5a includes changes for:
                              • Future compatibility
                              Home Page of FredoScale for information and Download.
                              Main post of this FredoScale thread.
                              S 1 Reply Last reply Reply Quote 0
                                seryaul @fredo6
                                @fredo6
                                Boa tarde, fiz a doação de $12, ainda não recebi o e-mail com a ativação do plugin.
                                Aguardo resposta.
                                  rutpin
                                  Hello, I installed the latest plugin but it does not appear in the menu list
                                  TIGT R 2 Replies Last reply Reply Quote 0
                                    TIG Moderator @rutpin
                                    @rutpin
                                    After you downloaded the RBZ did you install it from the Extension Manager dialog ?
                                    Or are you using the SketchUcation Tools' ExtensionStore³ to auto-install it without an RBZ ?
                                    Do you have the latest LibFredo6 installed as well ?
                                    Do you also have the SketchUcation Tools installed [needed for any licensing] ?
                                    Have you restarted SketchUp after the installations to sync everything ??
                                      rutpin @rutpin
                                      TIG Yes
                                        Rich O Brien Moderator @rutpin
                                        @rutpin
                                        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                          DomV12
                                          Hello, all the Fredo extensions work correctly for me but when I want to use FredoScale it tells me that the license has expired. Can someone give me a hand with this?
                                            Rich O Brien Moderator @DomV12
                                            @DomV12 said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
                                            D 1 Reply Last reply Reply Quote 0
                                            • 11
                                            • 12
                                            • 56
                                            • 57
                                            • 10 / 57
