[Plugin Library] LibFredo6 - v14.4c - 18 May 24
Last try this morning:
Repaired SU 2022, deleted Plugins folder, installed just SketchUcation Tools and LibFredo6:
Fredo6 Plugins Information on 2023-08-01 09;42;07 +0100 -------------------------- - Platform; x64-mswin64_140 - Ruby; 2.7.2 - Sketchup; 22.0.354 - LibFredo6; v14.1a - LibFredo6 Binary loaded - Sketchucation ExtensionStore; 4.3.1 - SCFLicense; v6.1a - 72 - Fredo6 Plugins - SCFLicense directory absent
Then installed one random Fredo6 plugin (VisuHole):
Fredo6 Plugins Information on 2023-08-01 09;46;37 +0100 -------------------------- - Platform; x64-mswin64_140 - Ruby; 2.7.2 - Sketchup; 22.0.354 - LibFredo6; v14.1a - LibFredo6 Binary loaded - Sketchucation ExtensionStore; 4.3.1 - SCFLicense; v6.1a - 72 - Fredo6 Plugins Error; #<TypeError; no implicit conversion of nil into String> c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;603;in `exist?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;603;in `licensed?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;331;in `initialize' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;73;in `new' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;73;in `licensed?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;797;in `block in info' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;791;in `each' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;791;in `info' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;368;in `block in populate_support_menu' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
If the SCFLicense folder is missing something is stopping it being created, or found.
Is this folder there ?
C:\Users\javi\AppData\Local\SCF Licenses
Check the permissions to your Local folder allow folders to be added and files made/read...Also look in your Roaming folder and ensure that its contents are writable etc...
Perhaps SketchUp is having an issue with the contents of subfolders in Plugins etc...The folder named exactly "
SCFLicense
" is part of the installation of the SketchUcation extension installation... It contains many vital files and subfolders used in the licensing system.
Is it there ?
C:\Users\javi\AppData\Roaming\SketchUp\SketchUp 2022\SketchUp\Plugins\SketchUcation\SCFLicense
If it's not there please try reinstalling the latest toolset from the SCF Plugin|ExtensionStore [v4.3.1].
That folder is most definitely included in the RBZ installer... -
SCFLicense
Is it there ?
That folder is most definitely included in the RBZ installer...The folders are there, permissions are ok, Roaming folder and its contents are writable.
SCFLicense
" is where it should be:
I've reinstalled SU 2022, started and just installed SketchUcation Tools.
Extensions > SketchUcation > SCFLicense: Global Status...
does nothing.This is gonna be next "X Files" movie...
The above path doesn't contain your licenses. It is extension related.
The path below is where you are experiencing issues...
This folder should have the .txt files and the signature file.
Well, first problem solved: SU now reads my licenses at
C:\Users\Javi\AppData\Local\SCF Licenses
.Fredo6 Plugins Information on 2023-08-01 15;27;29 +0100 -------------------------- - Platform; x64-mswin64_140 - Ruby; 2.7.2 - Sketchup; 22.0.354 - LibFredo6; v14.1a - LibFredo6 Binary loaded - Sketchucation ExtensionStore; 4.3.1 - SCFLicense; v6.1a - 72 - Fredo6 Plugins - SCFLicense directory present > Signature File; 2022-03-30 01;28;02 +0100 > Curviloft; 2022-04-28 20;01;36 +0100 > FredoScale; 2022-04-16 20;20;36 +0100 > JointPushPull; 2022-06-22 20;11;35 +0100 > RoundCorner; 2022-05-11 10;12;30 +0100 > ToolsOnSurface; 2022-04-28 21;50;30 +0100
Second part is still unreachable: if I install a Fredo6 plugin, I get the same error. This is what I get after installing Curviloft:
Fredo6 Plugins Information on 2023-08-01 15;28;54 +0100 -------------------------- - Platform; x64-mswin64_140 - Ruby; 2.7.2 - Sketchup; 22.0.354 - LibFredo6; v14.1a - LibFredo6 Binary loaded - Sketchucation ExtensionStore; 4.3.1 - SCFLicense; v6.1a - 72 - Fredo6 Plugins Error; #<TypeError; no implicit conversion of nil into String> c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;603;in `exist?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;603;in `licensed?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;331;in `initialize' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;73;in `new' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;73;in `licensed?' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;797;in `block in info' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;791;in `each' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;791;in `info' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;368;in `block in populate_support_menu' c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
I'm thinking it's because I have customized Windows paths at Advanced System Setup (even though I haven't had this problem in years):
- C:\Windows\Temp --> D:-WinCache\Windows\Temp
- C:\Users\javi\AppData\Local\Temp --> D:-WinCache\Temp
I think this because in my work laptop, SCF and SCF Licenses are subfolders at
, but in my home PC is SCF is atD:\-WinCache\SCF
and SCF Licences keeps as aC:\Users\Javi\AppData\Local
subfolder. -
It seems I'm in a dead end... "SCFLicense: Global Status" refuses to show, even LibFredo6 is installed or not. Then, the same issues as posted before.
Any idea?
I think this unconventional path is likely your issue...
D:\-WinCache\SCF
TIG and Fredo would be better placed to comment on the nuances of the 'ideal' setup for such scenarios.
D:\-WinCache\SCF
I tried with stock Windows paths (no work) and creating a Windows symbolic link
-->D:\-WinCache\SCF
, so it uses the first one, but really stores in the second one (no work).The strangest is it's been working in SU 2021 for years with this path configuration, and suddenly it doesn't... that's the point.
NEW RELEASE: LibFredo6 v14.2a - 26 Aug 23
LibFredo6 14.2a includes:
- Future compatibility
- Various bug fixes and adjustments
_____________________________________a
I am getting the same error after installing the latest plugin (libfredo) I do not what to do. It cannot install -
Have you tried the installation that's recommended ?
And restarted SketchUp... -
After Installing your tools, it wouldn't work as described and it froze up my regular mesh tools so that they also didn't function. I tried to uninstall it and no matter what I did it still shows up on my Extensions Manager as installed. It have really frustrating not to have a reliable tool that not only will not function properly but then doesn't have an appropriate and reliable method to uninstall. The product may work for others, but for me I just want to get rid of it. HOW CAN I REMOVE THIS UTILITY FROM MY SYSTEM????
Are you still using SketchUp 2016 as indicated in your forum profile?
it does not offer the otion to download anything. Not even after signing up for a free profile.
You download RBZs from the PluginStore and install them using the Extension Manager dialog's install button...
Restart SketchUp to sync everything...
LibFredo6 offers support to Fredo's other extensions [which you also need to install].
You also need the SketchUcation toolset installing,because that does the licensing stuff used by many of Fredo's paid-for extensions.
Using the SketchUcation ExtensionStore dialog to auto-install other plugins sidesteps the need to down their RBZs... so perhaps install that first, then use it to auto-install the others... -
How do I download into sketchup 2023. Did I get scammed? its so stupid. Explain to me NOW!
I have issues loading FredoScale. Message keeps popping up saying it requires LibFredo6 version >= 129 but I have the most recent version.
Hey Fredo6
I have the 3 seat JointPushPull plugin, but my old work laptop graphics card died and it will not let me open SketchUp to release the seat on the old machine and IT has taken the laptop away from me.
Is there a way to remotely release that seat from the old laptop?
Tim
See this topic which covers license management vis SketchUcation.com
If the defunct device had an old licensing setup then you might not be able to do it this way...
In which case PM Fredo or Rich with a list of the licenses to be released and will probably be able to help you...
However, it'll be quicker to do it yourself, if you can... -
Hi there!
SketchUp Pro 2023.
I tried yo install libfredo (the latest version),and RoundCorner (the latest versionm) but something went wrong. it is shown that it is installed in the Extension Manager but nothing is displayed. I found that I have to install ExtensionStore, I did it, but nothing changed. the message that I need to install the latest version of libfredo always appears, but it has been already installed. I've read that many people has the same issue but i haven't found the answer how to repair it. Please help me!
