    2.3k Posts 515 Posters 2.2m Views 520 Watching
      brksnr
      @fredo6 said:
      @brksnr said:
      I unfortunately formetted my laptop before I release th licenses and I cannot release them online due to versin being old I guess. I still have that pc but I don't know how can I release my licenses which I know the HWID's Is there any way you can help me out Dear Fredo ?
      You have 4 plugins with 3 seats each.
      I can release all seats, but you will need to revalidate on all your computers.
      I would be glad if you release all my licenses, I will relicense them afterwards.
      • F Offline
        federicocap Newcomers
        Hello, I can not install the license, gives me communication error with sketcupucation
        Buongiorno, non riesco ad installare la licenza, mi da errore di comunicazione con sketcupucation
        • fredo6F Offline
          Done
            You need to whitelist *.sketchucation.com in your firewall/antivirus
              trajanus96
              I have purchased and used an unlimited license. However, an error has occurred recently and authentication is not possible.
                You are using an outdated version of the Sketchucation Extension Store tool. Update to the current version. The current version should show the license manager version as below.
                Are you still using SketchUp 2017 as indicated in your profile?
                  thomascook Newcomers
                  Thanks for this extensions. I will apply them from now on.
                  • hapipo1103H Offline
                    hapipo1103
                    Mr. Fredo, Could you please release all my FredoCorner license seats?
                    Seat ID: 18480; HW ID: JC1622412112.0M; Date of activation: 31/05/2021
                    Seat ID: 24493; HW ID: OG1647077960.0H; Date of activation: 12/03/2022
                    Seat ID: 27820; HW ID: TU1649253600.0J; Date of activation: 06/04/2022
                    Thank you.
                      trajanus96
                      i have updated 6.1a but it still not work.
                        trajanus96
                        The cause of the license error was found.
                        If set the computer's name to a non-English name, the license will not be recognized.
                        I solved my problem, but the license was applied in duplicate.
                        I'd like to retrieve the above two licenses.
                        Thank you. fredo
                        Seat ID: 27003; HW ID: WF1648954173.0G; Date of activation: 03/04/2022
                        Seat ID: 28476; HW ID: KI1649406241.0Z; Date of activation: 08/04/2022
                          Clarar khan Newcomers
                          Hello guys
                          SCFLicense on Sketchucation - a valuable tool for managing extension licensing in SketchUp. Simplifying licensing processes for a smoother and more efficient workflow.Free Fire name style
                            Marco97 Newcomers
                            Hi mr. Fredo,
                            I have purchased the license for the basic 8 tools roundcorner, fredospline etc. Because of an unrelated IT issue they had to change the name of my PC and now the licenses are no longer recognised. When I open the window Extensions>>SketcUcation>>SCFLicense : Global Status it doesn't show any of my licenses. When I try and re activate the license I get an ERROR_A0C. I have attached a snapshot of the error, my licenses and the SCFLicense:Global License windows.
                            How do I go about solving this issue?
                            ERROR_A0C
                            SCFLicense: Global S
license
                            • fredo6F Offline
                              Just follow the instruction and delete the signature file, then revalidate licenses.
                                Mike0815
                                Hi, just purchased the License and got the mail within seconds. I stored the SCF file from the mail in "my software data files". Then I tried to activate the license and got this message attached. I erased the files SCFLicenseLog and SCFLicenseSignature - DO NOT... under "user"\AppData\Local\SCF Licenses and stored then the license file in other places e.g. also in the "user"\AppData... but I get always the same message 😞 . can you please help, Michael
                                  Can you run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command and copy/paste the text into your reply?
                                    Mike0815
                                    thanks for the fast reply. THis is the text:
                                    Fredo6 Plugins Information on 2023-09-09 16:13:46 +0200
                                    • Platform: x64-mswin64_140 - Ruby: 2.7.1
                                    • Sketchup: 21.0.339
                                    • LibFredo6: v14.2a
                                    • LibFredo6 Binary loaded
                                    • Sketchucation ExtensionStore: 4.3.1
                                    • SCFLicense: v6.1a - 72
                                    • Fredo6 Plugins
                                      Curviloft v1.9a
                                      Signature File: 2023-09-09 16:00:54 +0200
                                    Michael
                                      Close SketchUp
                                      Delete SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file at C:\Users\SomeName\AppData\Local\SCF Licenses
                                      Open SketchUp
                                      Go to Tools > Fredo Collection > Curviloft > License... and activate with license file at https://sketchucation.com/webshop/my-licences.php
                                      If that still fails trying repairing your SketchUp install by downloading the installer from here...
                                      https://www.sketchup.com/download/all
                                      Right click it and choose Run as Administrator and then the Repair option.
                                        trajanus96
                                        @marco97 said:
                                        Hi mr. Fredo,
                                        I had the same problem and found a solution.
                                        Check the name of your PC. If it is not English, the license file is not recognized.
                                        It also worked normally after I changed the name of the PC to English.
                                          growtoon
                                          'Find and delete the SCFLicenseLog', 'SCFLicenseSignature'
                                          DO NOT MODIFY OR DELETE file,
                                          Even if you repeat the process of trying again
                                          The license is not approved.
                                          I installed the latest version of Fredo 6,
                                          I also installed the Sketchucation Extension Store with the latest version, but it is not approved.
                                          What should I do in this case..
                                            Your computer-name must follow the requirements of Microsoft Windows in using only ASCII characters AZaz09 and certain punctuation characters.
                                            If your computer -name is non compliant then the licensing system can have problems when trying to check to licensing validity...
                                            Please check your computer's name for compliance.
                                            If necessary rename your computer and delete the SCF license file, as already directed.
                                            Then try re-validating your licenses...
                                            • 84
                                            • 85
                                            • 86
                                            • 87
                                            • 88
                                            • 115
                                            • 116
                                            • 86 / 116
