    2.3k Posts 509 Posters 1.4m Views 514 Watching
      Mike0815
      Hi, just purchased the License and got the mail within seconds. I stored the SCF file from the mail in "my software data files". Then I tried to activate the license and got this message attached. I erased the files SCFLicenseLog and SCFLicenseSignature - DO NOT... under "user"\AppData\Local\SCF Licenses and stored then the license file in other places e.g. also in the "user"\AppData... but I get always the same message 😞 . can you please help, Michael
        Can you run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command and copy/paste the text into your reply?
          Mike0815
          thanks for the fast reply. THis is the text:
          Fredo6 Plugins Information on 2023-09-09 16:13:46 +0200
          • Platform: x64-mswin64_140 - Ruby: 2.7.1
          • Sketchup: 21.0.339
          • LibFredo6: v14.2a
          • LibFredo6 Binary loaded
          • Sketchucation ExtensionStore: 4.3.1
          • SCFLicense: v6.1a - 72
          • Fredo6 Plugins
            Curviloft v1.9a
            Signature File: 2023-09-09 16:00:54 +0200
          Michael
            Close SketchUp
            Delete SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file at C:\Users\SomeName\AppData\Local\SCF Licenses
            Open SketchUp
            Go to Tools > Fredo Collection > Curviloft > License... and activate with license file at https://sketchucation.com/webshop/my-licences.php
            If that still fails trying repairing your SketchUp install by downloading the installer from here...
            https://www.sketchup.com/download/all
            Right click it and choose Run as Administrator and then the Repair option.
              trajanus96
              @marco97 said:
              Hi mr. Fredo,
              I have purchased the license for the basic 8 tools roundcorner, fredospline etc. Because of an unrelated IT issue they had to change the name of my PC and now the licenses are no longer recognised. When I open the window Extensions>>SketcUcation>>SCFLicense : Global Status it doesn't show any of my licenses. When I try and re activate the license I get an ERROR_A0C. I have attached a snapshot of the error, my licenses and the SCFLicense:Global License windows.
              How do I go about solving this issue?
              I had the same problem and found a solution.
              Check the name of your PC. If it is not English, the license file is not recognized.
              It also worked normally after I changed the name of the PC to English.
                growtoon
                'Find and delete the SCFLicenseLog', 'SCFLicenseSignature'
                DO NOT MODIFY OR DELETE file,
                Even if you repeat the process of trying again
                The license is not approved.
                I installed the latest version of Fredo 6,
                I also installed the Sketchucation Extension Store with the latest version, but it is not approved.
                What should I do in this case..
                  Your computer-name must follow the requirements of Microsoft Windows in using only ASCII characters AZaz09 and certain punctuation characters.
                  If your computer -name is non compliant then the licensing system can have problems when trying to check to licensing validity...
                  Please check your computer's name for compliance.
                  If necessary rename your computer and delete the SCF license file, as already directed.
                  Then try re-validating your licenses...
                    TXABIA
                    Dear Fredo6,
                    I have just reset my PC. Before I reset the PC I released all licenses.
                    When I tried to validate the licenses after PC reset I saw that most of them remained taken. I tried to release them from https://sketchucation.com/webshop/my-licences.php but no checkbox available to do so.
                    I would appreciate if you can full release all my seats from all computers so I can start the process once again from scratch.
                    ID Extension Name License Type Duration (days) Created (DD/MM/YYYY) Email
                    68197 RoundCorner RoundCorner Perpetual License Unlimited 21/06/2022
                    68198 JointPushPull JointPushPull Perpetual License Unlimited 21/06/2022
                    68199 Curviloft Curviloft Perpetual License Unlimited 21/06/2022
                    68200 FredoScale FredoScale Perpetual License Unlimited 21/06/2022
                    68201 TopoShaper TopoShaper Perpetual License Unlimited 21/06/2022
                    68202 Curvizard Curvizard Perpetual License Unlimited 21/06/2022
                    68203 VisuHole VisuHole Perpetual License Unlimited 21/06/2022
                    68204 ToolsOnSurface ToolsOnSurface Perpetual License Unlimited 21/06/2022
                    Regards
                      Seats released. Please update your device/s to Sketchucation Tools 4.3.1 to enable online release at https://sketchucation.com/webshop/my-licences.php
                      • hapipo1103H Offline
                        hapipo1103
                        To the person in charge.
                        I requested the release of my Fredo Corner license seat on August 31, but have not received any response. I have changed my computer without releasing it and I am having trouble activating it.
                        Since it is my mistake, I will purchase the license again if necessary, but it seems that some people have had their license sheets released in similar situations.
                        The Sketchucation Tools on my device has been updated to 4.3.1. Is it possible for me to release the seat by doing some manipulation? I have looked through this topic but am not sure what to do. Could you please give me some advice?
                        ID 22881 Fredo Corner.
                        Sheet ID 18480; HW ID: JC1622412112.0M; Activation Date: 31/05/2021
                        Sheet ID 24493; HW ID: OG1647077960.0H; Activation Date: 12/03/2022
                        Seat ID 27820; HW ID: TU1649253600.0J; Date of activation: 06/04/2022
                        Thank you in advance.
                          Anne O Grady
                          I have released the seats for you
                          Regards
                          Anne
                          • I Offline
                            immsaavedra Newcomers
                            how do I send my friends a license seat of my fredo plug-in? I have 2 seats available but I have no idea how to generate another seat
                            • fredo6F Offline
                              Just send the Purchased License file (the one you received by email). It has 3 seats attached, and thus 2 remaining.
                                hapipo1103
                                Hello Ann.
                                I was able to activate it.
                                Thank you very much.
                                  jas001
                                  I just bought licences for 8 Fredo extensions . I am trying to validate licenses for each of them within sketchup (sketchucation 4.3.1 ). I am getting error message always)
                                  Computer name mismatch. It is advised to erase the signature file and revalidate.
                                  Please help.
                                    gamjasjy6010 Newcomers
                                    Hello, Fredo.
                                    I just bought 8 plugins and haven't used any licenses yet. Is it possible to get a refund? I'm using 8 of them so I'm going to use them one by one.
                                    Thank you.
                                      @gamjasjy6010 said:
                                      Hello, Fredo.
                                      Thank you.
                                      Sorted via email
                                        RACCODAC1123
                                        FREDO, i realy need your help. I have a few license from you, and those functionaly perfect. The last night i change the name of my computer, and all license are gone, no one can open, say my trial period is end, and the messagge is some wrong with the name of the computer, can you help me.
                                        • H Offline
                                          HaloEnrique98
                                          Hello Sr. Fredo, could you release all my licenses for my plugins? I had the error of changing the name of my pc and now I only have a few seats left that I will use soon, it would be very helpful, thank you πŸ˜„))
                                            Clarar khan Newcomers
                                            @nofi said:
                                            Hii,
                                            I just made the purchase forbitlife fredocorner extension, but i didn't get any email related to it.
                                            Hi friend
                                            If you haven't received an email confirmation for your BitLife FredoCorner extension purchase, it's essential to check your spam folder and reach out to their customer support for assistance.Free Fire name
                                            • 84
                                            • 85
                                            • 86
                                            • 87
                                            • 88
                                            • 114
                                            • 115
                                            • 86 / 115
