    Kitchen
    21 Posts 8 Posters 937 Views 8 Watching
    • Gus RG Offline
      Gus R
      A kitchen remodel I designed and slapped together this morning and rendered in D5 Render. As usual with architecture this isn't a final design. Just practice.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • Gus RG Offline
        Gus R
        • Gus RG Offline
          Gus R
          Dog isn't floating this time. Got the god light going.
          • Rich O BrienR Online
            I like the last one the most. The bit and pieces around the kitchen are great. Maybe a small bit of regularity to the plate stack.
            Are you considering shelving Thea?
            • Gus RG Offline
              Gus R
              Rich, the plates can't budge since it's from their library and I don't know how to edit those. I was thinking about random placement of plates however. Obviously it's a simple fix.
              I knew Thea might come up. I'll keep using Thea since it's a different kind of renderer. It has a lot of fine details you can't get in D5 Render and I like the materials editor and how it works with Skatter. I also feel kind of loyal to the original creator. However, they really need to do something about displacement that doesn't require triangulation or dividing surfaces and even then it doesn't work very well.
              • ntxdaveN Offline
                ntxdave
                @gus r said:
                I knew Thea…… I like the materials editor and how it works with Skatter.
                How do you do that. I use Twilight Render which I think is based on Thea and probably has a material editor that is much like I (do no know that for sure).
                Press F1...thank me later
                • Gus RG Offline
                  Gus R
                  Twilight doesn't work with Skatter proxies. Don't remember if I tested it with non proxies but I can imagine the geometry would be overwhelming.
                  • ntxdaveN Offline
                    ntxdave
                    Yes, I use the proxies all of the time.
                    • Gus RG Offline
                      Gus R
                      Guess I forgot. Something I'm doing more frequently.
                      • Gus RG Offline
                        Gus R
                        Designed another layout for the kitchen and added more bells and whistles. I rendered this at 8K. It really doesn't take very long.
                        This is a cropped portion of the original 8K rendering which was a png output.
                        • ntxdaveN Offline
                          ntxdave
                          These look really good to me. 👍 👍
                          • ntxdaveN Offline
                            ntxdave
                            @Gus R, I just copied this info about the Skatter plugin:
                            Combine Skatter with Other Plugins
                            The Skatter Plugin is compatible with many other Sketchup plugins, including V-Ray, Thea Render, and Twilight Render. By combining Skatter with these plugins, you can create even more realistic and stunning landscapes.
                            I like the fact that this allows you to use proxies so that it does not bring SU to its knees. 👍
                              The last ones are a vast improvement 👍 Interiors are a whole new ball game 😉 I find a white ceiling gives light a whole lot more bounce. That is why ceiling's in the real world are almost always white.
                              • Gus RG Offline
                                Gus R
                                I can't stop!
                                • ntxdaveN Offline
                                  ntxdave
                                  This last one is kind of blurry IMO on my iPad.
                                  • Gus RG Offline
                                    Gus R
                                    It's the depth of field. Only the range is focused.
                                    • ntxdaveN Offline
                                      ntxdave
                                      Gotcha! 👍
                                      • tuna1957T Offline
                                        tuna1957
                                        Really like that last image with D.O.F. 👍
                                          Magic, my use of language is challenged to come up with more than that and wow. 👊
                                          • gullfoG Offline
                                            gullfo
                                            where is the dogs water dish? 😄
                                            Glenn
                                            http://www.runnel.com
