[Plugin Library] LibFredo6 - v14.6a - 18 Sep 24
Hello,
could you please help me. I intall LibFredo6 versio 13.9a in order to use fredo corner but after that nothing is working of fredo library even the fredo tools...
All plugins that i have install are the latest version in Sketchup 2023.
Any ideas? -
What method are you using to install? Do you also have the current version of the Sketchucation ExtensionStore tool installed?
Please update your profile. It is out of date.
You need to have the latest versions of the extensions/lib and the SketchUcation toolset installed , and SketchUp restarted...
But are you really using SketchUp v2016 ?
It's pretty much unsupported - with v2017 being the outlier...
Perhaps therein lies your problem.
There are legacy copies of Fredo's extensions/lib in the PluginStore, but they will have limited use...
Otherwise update your profile with the correct SketchUp version and we go one step forward... -
Hey,
I did all the required steps for this plug in, purchased the license, but the plug in does not work in any sketchup version. Any ideas why?
Libfredo is a helper library for Fredo extensions. It does nothing on it own.
What extension are you trying to use ?
I suspect one of Fredo's but you've posted in his support Lib thread and not explained your problem very clearly.
You need the latest versions of LibFredo6 and the SketchUcation toolset installing and SketchUp restarting to allow Fredo's extensions to work and get licensed etc... -
Hello, I'm having problems with fredo tools. A few weeks ago curviloft stopped working from one moment to another. I tried updating fredo tools versions, reinstalling, and even reinstalling sketchup. So far I tried SKP 2022 and 2023 and I still have the same problem. I manage to install the plugins but they don't respond. Pleas help
Hello,
Ive just purchased a license for Round corner, love the tool, but when i come to install the sketchucation plug in i keep on getting this error message.
:file does not exist
Can you help with some advice as to what is going wrong?
There was a glitch with the SCF Amazon server.
It first happened yesterday, it was fixed...
Today it seems to have recurred - again it's been fixed...
Hopefully a bit more permanently !! -
Hello, I have an issu with the fredotools.
I tried to use Thrupaint to work my texture on a chair, but I have this "blank" tool bar where I am supposed to see every tool (like 'materials', 'uv painting' etc).
To be precise, on the tool bar of the sketchup app, I can see the "Trhupaint extension", but when I clic on it, I have a gray space that pop just under my sketchup toolbar, but with nothing in it. When I place my mouse on it, I have sometime a little hand that appear, wich means the buttons are here, but I can't see them, so I don't know what I am clicking on. (here is a screenshot to show you)
I hope someone know what I can do...
I have the same issu with round corner, and I don't know why. I have the latest version of the fredotools, and I'm on windows, with sketchup 2020. -
Just upgrade to the latest version of LibFredo6.
Hello,
The license file "FredoCorner.scflicense" does not work for the Fredo6 "RoundCorner" plug-ins.
Can you help me, please?
Kind regardsBonjour,
Le fichier de license "FredoCorner.scflicense" ne fonctionne pas pour le plug-ins "RoundCorner" de Fredo6.
Pouvez-vous m'aider, s'il vous plait ?
Cordialement
@fredpp83 said:
The license file "FredoCorner.scflicense" does not work for the Fredo6 "RoundCorner" plug-ins. Can you help me, please?
You need to install Roundcorner. FredoCorner and Roundcorner are different tools.
NEW RELEASE: LibFredo6 v14.1a - 10 Jul 23
LibFredo6 14.1a includes:
- JointPushPull: Fix about Groups with multiple instances. Now, only the instances selected will be transformed
- JointPushPull: Preservation of special curves (circle, arc, polygon)
- Various bug fixes and adjustments
_____________________________________a
@hairman said:
Hi Fredo6,
I updated Libfredo6 yesterday because of your new FredoSketch extension. First tried with window-Libfredo settings-check for fredo6 plugin updates and was surprised that it said that everything was up to date. Libfredo6 version was 13.6..
When checking with the sketchucation tool it said there was an update for Libfredo6.
Just wanted to give you a heads up..
Thanks for all your work and fantastic extensions!
Herman. -
Hi! Something's not fine after upgrading to latest version of LibFredo6 14.1a with SketchUp 2021. When using any Fredo6 plugin, I have to double click buttons to make them work. Single click gets no effect. Reinstalled all of them and all remains the same. Any info about this?
Thanks in advance.
Did you install SketchUp 2021 correctly? On Windows that requires right clicking on the installer file and selecting Run as administrator. If you didn't or don't remember doing so, get the installer from sketchup.com/download/all and do it. Choose the Repair option when it is presented.
Did you update the Sketchucation Extension Store when you updated LibFredo6? Did you quit and restart SketchUp after updating?
On the topic of updating, please update your forum profile. It's extremely out of date.
I've had v2021 installed since it came out. No problems until this time.
I repaired installation, uninstalled and reinstalled all Fredo6 plugins, SketchUcation Extension Store is v4.3.0. I restarted after repairing. It keeps failing. Thinking about uninstalling SU at all and reinstalling.
*I've checked I can't see the license windows either for any of these plugins
The current version of the SketchUcation toolset [and therefore the licensing system] is 4.3.1
Update to that using the ExtensionStore³ and restart SketchUp... -
Well, I've done this:
- Uninstalled SketchUp and all plugins
- Cleaned registry and checked no left folders were forgotten
- Restarted
- Installed SU 2022
- Installed SketchUcation Extension Store 4.3.1
- Installed LibFredo6 and JointPushPull
...and the same issues: got to double click in Fredo6 plugin buttons to work and when I press on License... button, nothing happens. I'm really lost
I get this in "View Trace log files":
>>>> 1690819617.4827344;top_libfredo6.rbe;171; in `open' DATE / TIME; 2023-07-31 17;06;57 +0100 SKETCHUP VERSION; 22.0.354 RUBY_PLATFORM; x64-mswin64_140 LOG FILE; LibFredo6Trace_22_1690819617466.txt >>>> 1690819617.4824693;top_libfredo6.rbe;171; in `open' LibFredo6; Starting up Fredo6_!LibFredo6.rb >>>> 1690819617.4833517;top_libfredo6.rbe;171; in `open' LibFredo6 Root top directory; C;/Users/Javi/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins >>>> 1690819617.4867444;top_libfredo6.rbe;171; in `open' APPDATA Sketchup directory; C;/Users/Javi/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles >>>> 1690819617.4884648;top_libfredo6.rbe;171; in `open' Temp Files directory; C;/Users/Javi/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles >>>> 1690819617.4887896;top_libfredo6.rbe;171; in `open' LibFredo6 Data directory folder; C;/Users/Javi/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/LIBFREDO6_DATA_Dir >>>> 1690819617.4891112;top_libfredo6.rbe;171; in `open' Default Parameters folder; C;/Users/Javi/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/LIBFREDO6_DATA_Dir/DefaultParameters >>>> 1690819617.489658;top_libfredo6.rbe;171; in `open' LibFredo6; Beginning of loading Cycle***+ >>>> 1690819617.498;top_libfredo6.rbe;171; in `open' LibFredo6 Core; Fredo6_!LibFredo6/Lib6Core successfully loaded >>>> 1690819617.5130002;top_libfredo6.rbe;171; in `open' LibFredo6 14.1a; Effective Load - #0 >>>> 1690819617.6435053;top_libfredo6.rbe;171; in `open' LibFredo6 14.1a; Ruby files loaded [128 ms] >>>> 1690819617.69337;top_libfredo6.rbe;171; in `open' add Command Set Preferred Languages... >>>> 1690819617.7229025;top_libfredo6.rbe;171; in `open' add Command Check Fredo6 Plugins for Update... >>>> 1690819617.7235732;top_libfredo6.rbe;171; in `open' add Command Purge Obsolete files... >>>> 1690819617.724171;top_libfredo6.rbe;171; in `open' add Command Performances... >>>> 1690819617.7247324;top_libfredo6.rbe;171; in `open' add Command View Trace log files... >>>> 1690819617.7253218;top_libfredo6.rbe;171; in `open' add Command About LibFredo6 v14.1a... >>>> 1690819617.7258954;top_libfredo6.rbe;171; in `open' add Command Fredo6 Plugins Information for Sketchucation Support >>>> 1690819617.729547;top_libfredo6.rbe;171; in `open' add Command Plugin Information [Sketchucation]... >>>> 1690819617.7304456;top_libfredo6.rbe;171; in `open' add Command Default Parameters... >>>> 1690819617.731032;top_libfredo6.rbe;171; in `open' add Command Language Translation... >>>> 1690819617.7316;top_libfredo6.rbe;171; in `open' LibFredo6 14.1a; Startup (creating menus and icons) [87 ms] >>>> 1690819617.7360392;top_libfredo6.rbe;171; in `open' Found valid plugin; JointPushPull >>>> 1690819617.7437222;top_libfredo6.rbe;171; in `open' Plugin to Load [0]; ["JointPushPull", "Fredo6_JointPushPull"] >>>> 1690819617.762328;top_libfredo6.rbe;171; in `open' JointPushPull 4.7a; Effective Load - #1 >>>> 1690819617.7658203;top_libfredo6.rbe;171; in `open' JointPushPull 4.7a; Bootstrap Ruby files loaded [3 ms] >>>> 1690819617.7719476;top_libfredo6.rbe;171; in `open' add Command Quick Launcher... >>>> 1690819617.773006;top_libfredo6.rbe;171; in `open' add Command Thickener >>>> 1690819617.774016;top_libfredo6.rbe;171; in `open' add Command Joint Push Pull >>>> 1690819617.7750082;top_libfredo6.rbe;171; in `open' add Command Round Push Pull >>>> 1690819617.7760384;top_libfredo6.rbe;171; in `open' add Command Vector Push Pull >>>> 1690819617.7770388;top_libfredo6.rbe;171; in `open' add Command Normal Push Pull >>>> 1690819617.77803;top_libfredo6.rbe;171; in `open' add Command Extrude Push Pull >>>> 1690819617.779052;top_libfredo6.rbe;171; in `open' add Command Follow Push Pull >>>> 1690819617.7800918;top_libfredo6.rbe;171; in `open' add Command About JointPushPull v4.7a... >>>> 1690819617.7806354;top_libfredo6.rbe;171; in `open' add Command Fredo6 Plugins Information for Sketchucation Support >>>> 1690819617.781276;top_libfredo6.rbe;171; in `open' add Command License... >>>> 1690819617.781851;top_libfredo6.rbe;171; in `open' add Command Trial Period Expiration... >>>> 1690819617.7856922;top_libfredo6.rbe;171; in `open' add Command Plugin Information [Sketchucation]... >>>> 1690819617.7862692;top_libfredo6.rbe;171; in `open' add Command Check Fredo6 Plugins for Update... >>>> 1690819617.787161;top_libfredo6.rbe;171; in `open' add Command Default Parameters... >>>> 1690819617.7877538;top_libfredo6.rbe;171; in `open' add Command Language Translation... >>>> 1690819617.8170905;top_libfredo6.rbe;171; in `open' JointPushPull 4.7a; Startup (creating menus and icons) [50 ms] >>>> 1690819621.4929304;top_libfredo6.rbe;171; in `open' LibFredo6; End of loading Cycle***- >>>> 1690819637.1511135;top_libfredo6.rbe;171; in `open' Lib6_txtmsg; Loading body code from body_Lib6_txtmsg [65 ms] status = true >>>> 1690819637.202284;top_libfredo6.rbe;171; in `open' Lib6G6; Loading body code from body_Lib6G6 [49 ms] status = true >>>> 1690819637.2348042;top_libfredo6.rbe;171; in `open' LibFredo6; Loaded Binary C;/Users/Javi/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU22/bin_body_Lib6G6.so >>>> 1690819637.238742;top_libfredo6.rbe;171; in `open' Lib6FaceSelector; Loading body code from body_Lib6FaceSelector [3 ms] status = true >>>> 1690819637.2419019;top_libfredo6.rbe;171; in `open' Lib6SelMode; Loading body code from body_Lib6SelMode [2 ms] status = true >>>> 1690819637.255253;top_libfredo6.rbe;171; in `open' Lib6Tool; Loading body code from body_Lib6Tool [8 ms] status = true >>>> 1690819637.2560437;top_libfredo6.rbe;171; in `open' Lib6Translate; Loading body code from body_Lib6Translate [13 ms] status = true >>>> 1690819637.2730222;top_libfredo6.rbe;171; in `open' Lib6RoundingProfiler; Loading body code from body_Lib6RoundingProfiler [9 ms] status = true >>>> 1690819637.2738245;top_libfredo6.rbe;171; in `open' Lib6Spline; Loading body code from body_Lib6Spline [17 ms] status = true >>>> 1690819637.280123;top_libfredo6.rbe;171; in `open' Lib6WebHtml; Loading body code from body_Lib6WebHtml [5 ms] status = true >>>> 1690819637.2830093;top_libfredo6.rbe;171; in `open' Lib6Marshall; Loading body code from body_Lib6Marshall [2 ms] status = true >>>> 1690819637.287629;top_libfredo6.rbe;171; in `open' Lib6Algo; Loading body code from body_Lib6Algo [4 ms] status = true >>>> 1690819637.292542;top_libfredo6.rbe;171; in `open' Lib6Contour; Loading body code from body_Lib6Contour [4 ms] status = true >>>> 1690819637.295534;top_libfredo6.rbe;171; in `open' Lib6Offset3d; Loading body code from body_Lib6Offset3d [2 ms] status = true >>>> 1690819637.3007681;top_libfredo6.rbe;171; in `open' Lib6Transform; Loading body code from body_Lib6Transform [4 ms] status = true >>>> 1690819637.3045552;top_libfredo6.rbe;171; in `open' Lib6Mark; Loading body code from body_Lib6Mark [3 ms] status = true >>>> 1690819637.307747;top_libfredo6.rbe;171; in `open' Lib6ParameterManager; Loading body code from body_Lib6ParameterManager [2 ms] status = true >>>> 1690819637.3221846;top_libfredo6.rbe;171; in `open' Lib6EdgePicker; Loading body code from body_Lib6EdgePicker [13 ms] status = true >>>> 1690819637.3277051;top_libfredo6.rbe;171; in `open' Lib6CameraManager; Loading body code from body_Lib6CameraManager [4 ms] status = true >>>> 1690819637.3340962;top_libfredo6.rbe;171; in `open' DATALIB; LibFredo6_datalib60.dat >>>> 1690819637.353655;top_libfredo6.rbe;171; in `open' DATALIB; LibFredo6_datalib61.dat >>>> 1690819637.3897786;top_libfredo6.rbe;171; in `open' DATALIB; LibFredo6_datalib62.dat >>>> 1690819637.4235947;top_libfredo6.rbe;171; in `open' DATALIB; LibFredo6_datalib64.dat >>>> 1690819642.1811182;top_libfredo6.rbe;171; in `open' Lib6Triangulation; Loading body code from body_Lib6Triangulation [6 ms] status = true >>>> 1690819642.1824887;top_libfredo6.rbe;171; in `open' JointPushPull 4.7a; Ruby files loaded [86 ms] >>>> 1690819642.1852403;top_libfredo6.rbe;171; in `open' DATALIB; JointPushPull_datalib60.dat >>>> 1690819642.198856;top_libfredo6.rbe;171; in `open' Lib6FaceSelector; Loading body code from body_Lib6FaceSelector [1 ms] >>>> 1690819642.2151365;top_libfredo6.rbe;171; in `open' Lib6OriginTargetPicker; Loading body code from body_Lib6OriginTargetPicker [15 ms] >>>> 1690819642.2216973;top_libfredo6.rbe;171; in `open' Lib6OpenglPicto; Loading body code from body_Lib6OpenglPicto [6 ms] >>>> 1690819642.2397647;top_libfredo6.rbe;171; in `open' Lib6Opengl; Loading body code from body_Lib6Opengl [17 ms] >>>> 1690819642.2428188;top_libfredo6.rbe;171; in `open' Lib6Triangulation; Loading body code from body_Lib6Triangulation [1 ms] >>>> 1690819642.2462184;top_libfredo6.rbe;171; in `open' Lib6DirectionManager; Loading body code from body_Lib6DirectionManager [3 ms] >>>> 1690819642.263066;top_libfredo6.rbe;171; in `open' Lib6Palette; Loading body code from body_Lib6Palette [13 ms] >>>> 1690819642.2738054;top_libfredo6.rbe;171; in `open' Lib6Input; Loading body code from body_Lib6Input [2 ms] >>>> 1690819642.2913103;top_libfredo6.rbe;171; in `open' Lib6VCB; Loading body code from body_Lib6VCB [2 ms] >>>> 1690819642.3207726;top_libfredo6.rbe;171; in `open' Lib6Marshall; Loading body code from body_Lib6Marshall [1 ms] >>>> 1690819751.0617495;top_libfredo6.rbe;171; in `open' Lib6PluginDialogs; Loading body code from body_Lib6PluginDialogs [28 ms] >>>> 1690819751.0755687;top_libfredo6.rbe;171; in `open' Lib6ChromiumJS; Loading body code from body_Lib6ChromiumJS [11 ms] >>>> 1690819751.1272552;top_libfredo6.rbe;171; in `open' Lib6Onglets; Loading body code from body_Lib6Onglets [8 ms] status = true >>>> 1690819751.128928;top_libfredo6.rbe;171; in `open' Lib6ChromiumWdlg; Loading body code from body_Lib6ChromiumWdlg [51 ms] >>>> 1690819751.1330724;top_libfredo6.rbe;171; in `open' Lib6Vault; Loading body code from body_Lib6Vault [3 ms] >>>> 1690819759.0988104;top_libfredo6.rbe;171; in `open' Lib6WebXTable; Loading body code from body_Lib6WebXTable [22 ms]
