[Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
@yago brown said:
Error launching Sketchup Pro 2022. Crashes.
"Curviloft: This plugin requires a LibFredo6 version greater than 124. The current version is 67"
How to solve it?Update Curviloft, LibFredo6, and the Sketchucation ExtensionStore tool to their current versions.
The file does exist in the PluginStore !
https://sketchucation.com/pluginstore?pln=LibFredo6
What are you trying to do ?
What error messages do you see ?
Many thousands of people successfully download RBZ files from us every day.
Why are you so different... -
The file does not exist on the site, on the server. And so with many of the plugins.
In 2023 can't you solve such a small problem? Put on Google Drive. -
PS:
I've just found out that there was a glitch on our server yesterday, it prevented a few random users from downloading from the PluginStore.
It's fixed now, so it might have fixed your problem ? -
Hello,
could you please help me. I intall LibFredo6 versio 13.9a in order to use fredo corner but after that nothing is working of fredo library even the fredo tools...
All plugins that i have install are the latest version in Sketchup 2023.
Any ideas? -
What method are you using to install? Do you also have the current version of the Sketchucation ExtensionStore tool installed?
Please update your profile. It is out of date.
You need to have the latest versions of the extensions/lib and the SketchUcation toolset installed , and SketchUp restarted...
But are you really using SketchUp v2016 ?
It's pretty much unsupported - with v2017 being the outlier...
Perhaps therein lies your problem.
There are legacy copies of Fredo's extensions/lib in the PluginStore, but they will have limited use...
Otherwise update your profile with the correct SketchUp version and we go one step forward... -
Hey,
I did all the required steps for this plug in, purchased the license, but the plug in does not work in any sketchup version. Any ideas why?
Libfredo is a helper library for Fredo extensions. It does nothing on it own.
What extension are you trying to use ?
I suspect one of Fredo's but you've posted in his support Lib thread and not explained your problem very clearly.
You need the latest versions of LibFredo6 and the SketchUcation toolset installing and SketchUp restarting to allow Fredo's extensions to work and get licensed etc... -
Hello, I'm having problems with fredo tools. A few weeks ago curviloft stopped working from one moment to another. I tried updating fredo tools versions, reinstalling, and even reinstalling sketchup. So far I tried SKP 2022 and 2023 and I still have the same problem. I manage to install the plugins but they don't respond. Pleas help
Hello,
Ive just purchased a license for Round corner, love the tool, but when i come to install the sketchucation plug in i keep on getting this error message.
:file does not exist
Can you help with some advice as to what is going wrong?
There was a glitch with the SCF Amazon server.
It first happened yesterday, it was fixed...
Today it seems to have recurred - again it's been fixed...
Hopefully a bit more permanently !! -
Hello, I have an issu with the fredotools.
I tried to use Thrupaint to work my texture on a chair, but I have this "blank" tool bar where I am supposed to see every tool (like 'materials', 'uv painting' etc).
To be precise, on the tool bar of the sketchup app, I can see the "Trhupaint extension", but when I clic on it, I have a gray space that pop just under my sketchup toolbar, but with nothing in it. When I place my mouse on it, I have sometime a little hand that appear, wich means the buttons are here, but I can't see them, so I don't know what I am clicking on. (here is a screenshot to show you)
I hope someone know what I can do...
I have the same issu with round corner, and I don't know why. I have the latest version of the fredotools, and I'm on windows, with sketchup 2020. -
Just upgrade to the latest version of LibFredo6.
Hello,
The license file "FredoCorner.scflicense" does not work for the Fredo6 "RoundCorner" plug-ins.
Can you help me, please?
Kind regardsBonjour,
Le fichier de license "FredoCorner.scflicense" ne fonctionne pas pour le plug-ins "RoundCorner" de Fredo6.
Pouvez-vous m'aider, s'il vous plait ?
Cordialement
@fredpp83 said:
The license file "FredoCorner.scflicense" does not work for the Fredo6 "RoundCorner" plug-ins. Can you help me, please?
You need to install Roundcorner. FredoCorner and Roundcorner are different tools.
NEW RELEASE: LibFredo6 v14.1a - 10 Jul 23
LibFredo6 14.1a includes:
- JointPushPull: Fix about Groups with multiple instances. Now, only the instances selected will be transformed
- JointPushPull: Preservation of special curves (circle, arc, polygon)
- Various bug fixes and adjustments
_____________________________________a
@hairman said:
Hi Fredo6,
I updated Libfredo6 yesterday because of your new FredoSketch extension. First tried with window-Libfredo settings-check for fredo6 plugin updates and was surprised that it said that everything was up to date. Libfredo6 version was 13.6..
When checking with the sketchucation tool it said there was an update for Libfredo6.
Just wanted to give you a heads up..
Thanks for all your work and fantastic extensions!
Herman. -
Hi! Something's not fine after upgrading to latest version of LibFredo6 14.1a with SketchUp 2021. When using any Fredo6 plugin, I have to double click buttons to make them work. Single click gets no effect. Reinstalled all of them and all remains the same. Any info about this?
Thanks in advance.
