    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • N
      nanni Newcomers
      i need help about license reply back if you seen.
      file:///C:/Users/GF63/OneDrive/%E0%B8%A3%E0%B8%B9%E0%B8%9B%E0%B8%A0%E0%B8%B2%E0%B8%9E/%E0%B8%A0%E0%B8%B2%E0%B8%9E%E0%B8%AB%E0%B8%99%E0%B9%89%E0%B8%B2%E0%B8%88%E0%B8%AD/2022-12-30.png
        Deniscopak
        hello Sir. Please is it still possible somewhere to download Curviloft that work with Sketchup 2016? thanks 1.9a isnt working for my 2016 with libfredo prioe_su2017
        thanks
          This version will work with any version of SketchUp but you'll need the legacy version of LibFredo 6.
            Rougeee
            I also have a rather disconcerting and random issue with this plugin on SketchUp Make 2017.
            This happens most often in the simplest and yet most useful case, that of creating a mesh between 2 contours.
            Thank you for finding a solution because I obviously have a user license and it is a plugin that I use frequently for the realization of artistic sketches and i really need it !
            (just in case, windows 10 64 is up to date, as well as the graphics card (nvidia) drivers and of course the latest LibFredo6)
            Error: #<NoMethodError: undefined methodplates' for nil:NilClass>
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:478:in spline_simple_construct' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:247:in spline_junction_construct'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:in generic_junction_construct' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:in junction_construct'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:369:in prepare_all' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:362:in proceed'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:641:in transition_to_loft' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:334:in activate'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in select_tool' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in launch_loft'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:53:in action__mapping' C:/Users/Alexandre/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/data6.rb:65:in call'
            C:/Users/Alexandre/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/data6.rb:65:in launch_action' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in launch_action'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:91:in block in startup'
            Error: #<NoMethodError: undefined method plates' for nil:NilClass> c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:478:in spline_simple_construct'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:247:in spline_junction_construct' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:in generic_junction_construct'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:in junction_construct' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:369:in prepare_all'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:362:in proceed' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:641:in transition_to_loft'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:617:in notify_edge_picked' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:539:in call'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:539:in notify_action' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:582:in terminate_current_selection'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:279:in execute_validate' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:269:in execute_from_palette'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:217:in notify_from_palette' c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:529:in call'
            c:/users/alexandre/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:529:in block in init_palette' ...
            • fredo6F
              NEW RELEASE: Curviloft v1.9b - 21 Apr 23
              Curviloft 1.9b is a maintenance release which fixes a potential issue whereby Curviloft will be in error due to previous parameters and would not allow to change the parameters (so ending by blocking Curviloft, as reported in the post just above).
              See Plugin Page of Curviloft for Download (or use the Sketchup PluginStore plugin for auto-installation.
              Main post of this thread
                Akavit
                The compatibility section needs to be updated. It claims compatibility with Sketchup version 2014 which is not true unless there's some place I haven't found where old versions can be downloaded.
                  The compatibility section for the main page for Curviloft shows compatibility with SU2014. You need to use the right version of LibFredo6, though.
                  While on the topic of updating, please update your forum profile.
                    Magpius
                    Purchased license, but now getting failed to install
                    https://imgur.com/a/mCORSK8
                    Running 2020
                      Mrkay
                      Hi, I'm using the paid version of Curviloft. I'm puzzled why sometimes (most of the time) it failed to generate the surfaces? It failed on a simple task like on the offset double arc lines. What is the FOLLOW 40° for. There is PLEASE WAIT... but it doesn't do anything.
                      Failed loft
                      Failed loft
                        Are you using Loft by Spline?
                        Share an .skp file in which is fails.
                        • N
                          ncallen Newcomers
                          Hi! I recently used Loft By Spline to loft a series of complex curves and it worked beautifully, I came back to the project after a few weeks and am suddenly unable to complete the action. I get the error message "Error in the construction of the Junctions - Try to change the parameters" instead. Has there been an update or something? In the attached file, the image of the object I successfully lofted is next to the one I'm trying to loft. I can upload the actual .skp file if need be.
                            Please do
                            • H
                              happygonzogmail Newcomers
                              my curviloft is give me an expiring massage before i even use it.what must i do.
                                Install the latest versions of the extension, and LibFredo, and the SketchUcation toolset [which deals with SCF licensing].
                                Restart SketchUp afterwards to sync everything.
                                If you don't have a license you must buy one... then activate it...
                                There are several posts about this on the forum...
                                  AlphaFox
                                  Hello, the toolbar buttons are not appearing, the same thing happens with other plugins in the Fredotools collection, any solution?
                                  • C
                                    ciaran370 Newcomers
                                    I'm having the same issue.
                                    I just downloaded Sketchup 23.1.340, and I have installed:
                                    Curviloft 1.9b
                                    LibFredo6 14.2a
                                    SketchUcation Toolset 4.3.1
                                    (as far as I can tell, the latest versions of everything)
                                    When I attempt to use Curviloft, I get a message that my free license expired on Thursday 30th December 2021
                                    I have tried restarting both SketchUp and my computer, but nothing is working...
                                    Any idea what to try next?
                                      You haven't bought a license and validated it ??
                                        savata
                                        Hello. I'm trying to buy Fredo6Bundle2022-8 on sketchucation.com but it's not successful. Can you contact me? cimsav-at-hotm co
                                          savata
                                          Hello... I want to buy Fredo6Bundle2022 - 8 via sketchucation, but the system does not make me pay. If you give me an IBAN, what if I pay that way?
                                            In what country are you?
                                            What version of SketchUp are you using? You put 2022 Free/Make in your profile but there is no such version.
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 65 / 66
