    2.3k Posts 515 Posters 2.3m Views 520 Watching
      @jorge86barrios said:
      Hello, I bought the joinpush, roundcorner and other licenses that came in a package, I had to format the pc. And now it appears that I already occupy the seats, but it is the same computer that I had to format. How can I solve it?
      Can you release seats at https://sketchucation.com/webshop/my-licences.php ?
      Please run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support command in SketchUp and paste output into your reply.
      • F Offline
        francisquitof
        @fredo I have the license of some of your plugins, all of them are workin but curviloft, a couple of days a message was displayed saying that my license was going to expire, i thoughjt it was a mistake since licences are perpetual, anyways today i wanted to use curviloft and i couldnt, i tried to validate the license but it says that theres an error, i even bought a new one and it doesent work as well, i would like a refund for my last purchase, and help with the activation of my license, this is a tool i use on my everyday workflow.
        • fredo6F Offline
          Could you check that you have uptodate versions of
          • LibFredo6
          • Sketchucation ExtensionStore
          • Curviloft
          • F Offline
            francisquitof
            I have up to date everything, all the other plug-ins work perfectly, only curviloft doesn’t recognize the licenses, both the one a acquired with the bundle and the one I got yesterday separately. The dialog box recommended to erase the file of the license and add it again, I did that and still the same is happening, I was looking for something like a bugsplat report for your plug-ins so you can check what kind of problem I am running into. Any way I will make a screen capture to see if that’s helpful.
            • F Offline
              francisquitof
              I uninstalled and installed again all your plugins as well as the sketchucation store plugin, not from a folder but directly from the store so i can get the latest version, i checked if there were updates available and everything was up to date, I´ll attach screen captures.[img]file:///C:/Users/Usuario/Desktop/Captura%20de%20pantalla%202023-05-22%20225102.png[/img] [img]file:///C:/Users/Usuario/Desktop/Captura%20de%20pantalla%202023-05-22%20225214.png[/img]
              • F Offline
                francisquitof
                Actualization, now any of your plugins are working, all get the same Error_A0C. Whats going on? I need this tools for my work, I´m in the middle of an important project and this is costing me a lot of time that I dont have.
                • F Offline
                  francisquitof
                  @fredo is there any thing I can do to be able to use the plug-ins?
                    junphuc17945
                    Please help me deactive 3 stucked seats :
                    JointPushPull
                    Seat ID: 27969; HW ID: TZ1622599474.0M; Date of activation: 07/04/2022
                    Seat ID: 27981; HW ID: FP1649300044.0M; Date of activation: 07/04/2022
                    Seat ID: 28446; HW ID: BR1622557468.0S; Date of activation: 08/04/2022
                    Thank you so much !!
                      kelly_m
                      El día 3 de mayo del 2023 compre la licencia para el plugin FredoScale de Sketchup, me funcionó y no tuve problemas. El día de hoy descargue windows 11 en mi laptop y resulta que ahora no me acepta la licencia para el plugin y me sale ERROR_AOC. Quería consultar si me pueden dar una solución para este problema por favor ya que acabo de comprarlo y ahora ya no puedo usarlo.
                      Espero una pronta respuesta, muchas gracias
                      Factura de la compra del plugin FredoScale
                      Imagen del error
                        On May 3, 2023 I bought the license for the FredoScale plugin from Sketchup, it worked for me and I had no problems. Today I downloaded windows 11 on my laptop and it turns out that now I do not accept the license for the plugin and I get ERROR_AOC. I wanted to consult if you can give me a solution for this problem please since I just bought it and now I can no longer use it. I hope a prompt response, thank you very much
                        Please run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support command in SketchUp and paste reply.
                        Also follow the instructions in the dialog and delete your signature. Restart SketchUp and try validating again
                        • F Offline
                          francisquitof
                          I’ve been waiting 3 days for an answer and a solution, I really like this plug-ins, but I would have to search for alternatives and won’t recommend them to anyone.
                            I’ve been waiting 3 days for an answer and a solution, I really like this plug-ins, but I will have to search for alternatives and won’t recommend them to anyone.
                            Did you read your original post?
                            403 Forbidden
                            (sketchucation.com)
                            You linked to images on your device which is not possible to display. So it's rather hard to understand your issue when no one can see it.
                            Usually reading through this thread you'll find others with similar issues and advice to fix it. Your error message suggest your computer name has changed but we are still missing basic info like version numbers or SketchUp version.
                              Maybe the fact that you are stillusing SketchUp 2013, or so your profile indicates, has something to do with it.
                              • F Offline
                                francisquitof
                                Update on this problem, I can’t validate any license of plug-ins bought on the sketchucation store, clothworks isn working as well I get the same Error A0_C, it’s not my machine, and I’m using the latest version of sketchup, installed the latest version of sketchucation store plugin, and the latest versions of all the libraries necessary to run fredo plug-ins I’ve even released all the seats. I’ve seen that a lot of people are having this issue, do you know developers know already what could be causing this? It’s not nice having a tool you’ve paid for and not being able to use it. I’m working on a big project right now and this tools could save me a lot of time.
                                  That error message suggests that, "the computer's name and the computer name in the signature file are different".
                                  Have you renamed your computer ?
                                  Have you copied a license file from a different computer ?
                                  Does the name of your computer follow the requirements of Windows ? i.e. no special-characters or accents etc.
                                  You can delete the license files and re-validate the licenses again...
                                  • F Offline
                                    francisquitof
                                    I solved it, I deleted 2 files in the SFC licenses folder, one of them said do not delete, but I had nothing to lose so I did it, then tried to activate the plug-ins again and it worked with all of them.
                                      Darius
                                      Hello,
                                      Bought a licenze for 3 seats and its stopped worked couples days ago. Two other seats are working just fine. What could be a problem ?
                                        @Darius
                                        Look in your licenses page at SketchUcation and see what's reported...
                                        Do you have any error messages to share ?
                                        • F Offline
                                          francisquitof
                                          @darius said:
                                          Hello,
                                          Try validating your license, if it doesn’t allow you and asks you if you want to open the folder where the license are, choose yes, delete everything from there, even the folders that say do not delete, I did that a couple of days ago, then download again all your licenses from your license manager, save them on any place you want, then try to validate again your licenses using the new files you’ve downloaded. That worked for me, I couldn’t validate any license acquired on sketchucation, I asked for help for days but no one answered with a solution.
                                            ChrisTTSI
                                            I've recently had a new PC as the hard drive failed on the old one.
                                            I had purchased a copy of RoundCorner last year and have managed to activate a license on my new PC but cannot release the license attached to my old PC.
                                            Can anyone help with this? There does not seem to be an option anywhere to release or deactivate an old seat.
                                            Thanks in advance.
                                            • 78
                                            • 79
                                            • 80
                                            • 81
                                            • 82
                                            • 115
                                            • 116
                                            • 80 / 116
