    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 769.2k Views 175 Watching
      lgrahm
      After installing SketchUp 2023 I find that Extrude Edges By Rails to Lattice will freeze.
      It will let me select profiles and rails, but when the dialog box says Extrusion Type it will freeze and I have to restart SketchUp.
      /Lars
        I'll test it and come back...
          Works fine for me...
          What is the form you are trying to make ?
          What are the settings ?
          Are you sure you're picking the profile, then two rails etc, in the correct order...
          Can you post some screenshots or even the SKP [purged] with settings used...
            lgrahm
            This is the step where I´ve been having trouble. But now I've found out that it doesn't necessarily freeze forever. Sometimes when I wait for some five minutes it will "unfreeze" and run. Another way to work around is to leave SketchUp and go to some other app and then return again - and Voilá - the tool will run.
            So I guess it's more of a problem with my computer than with the software.
            Many thanks for taking your time, TIG!
              lgrahm
              This is the SketchUp-file where I've been experimenting with Extrude Edges by Rails to Lattice.
              If anyone wants to proof check the file.
              /Lars
              Test extrude tools.skp
              • BoxB Offline
                This is it in Real Time
                  Tried your file and EEbyRailsToLattice works just as I'd expect with hardly any time lag etc...
                  Just like Box who pipped me to the post !
                  • BoxB Offline
                    One thing I see from your screenshot is that you must have the display settings way above normal, the text doesn't fit in the box and the tiny crosses are huge.
                    How this may be affecting things I don't know.
                      lgrahm
                      Thank you Box and TIG for help and efforts
                      I suppose the configuration of my computer is the problem. And since the computer is managed, there is very little I can do. But at least I know where the problem lies and fortunately I've also found a workaround.
                      /Lars
                        s2044842 Newcomers
                        Hello,
                        Every time i try to download the plug-in, this comes up, and I get nothing. Do you know what is wrong with my software?
                        I am currently using SketchUp Pro 2022
                          Your browser's settings are incorrect.
                          You do not download & open an extension's RBZ file, only a SKP will open OK with SketchUp.
                          Your browser's download options are set wrong, a RBZ will never open in SketchUp.
                          Change the browser's file-associations for RBZ files in your browser's setting to 'download'.
                          Then simply download it onto your computer - typically into your Downloads folder.
                          You now need to install the RBZ in SketchUp.
                          Open SketchUp and use its Extension Manager's dialog's Install button, find the RBZ in the file-browser which will open, and SketchUp then installs it for you, automatically putting files and related subfolders into the correct locations in your Plugins subfolder.
                          Restart SketchUp to sync everything...
                            jamalaldin
                            Thank you all
                              RIQUELMETORO Newcomers
                              Does this plugin work in Sketchup 2022?
                              I have tried installing it, no errors appears, but the plugin doesn't show up in the toolbar, and it doesn't appear in the list of plugins to add to the toolbar.
                              Thank you.
                                It should work fine in all current versions of SketchUp.
                                How did you install it ?
                                Use the native Extension Manager > Install... button, on its RBZ, downloaded from the PluginStore...
                                Restart SketchUp after installation to sync everything...
                                • N Offline
                                  nicolasberthier
                                  Hello,
                                  I have installed the plugin in the last 2024 version. But nothing happens, it is marked as installer but won't show up anywhere.
                                    It has a toolbar and also submenu entries under Extensions > Extrusion Tools...
                                    Have you restarted SketchUp to sync everything ?
                                    It works fine in newer versions of SketchUp.
                                    If you start SketchUp with the Ruby Console previously activated, do you see any error messages ?
                                      I know this is an oldie but I occasionally dig it our for certain tasks. Seems to be a few errors on some tools.
                                      Error:
                                      #<NoMethodError: undefined method `position' for nil:NilClass>
                                      C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ExtrudeTools/extrudeEdgesByRailsToLattice.rb:1017:in `block (2 levels) in make_shell'
                                      C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ExtrudeTools/extrudeEdgesByRailsToLattice.rb:1015:in `upto'
                                      C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ExtrudeTools/extrudeEdgesByRailsToLattice.rb:1015:in `block in make_shell'
                                      C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ExtrudeTools/extrudeEdgesByRailsToLattice.rb:980:in `upto'
                                      C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ExtrudeTools/extrudeEdgesByRailsToLattice.rb:980:in `make_shell'
                                      C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ExtrudeTools/extrudeEdgesByRailsToLattice.rb:644:in `make_mesh'
                                      C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ExtrudeTools/extrudeEdgesByRailsToLattice.rb:235:in `onLButtonDown'
                                      panixiaP 1 Reply Last reply Reply Quote 0
                                        Without knowing exactly the steps and settings it's hard to deduce what happened.
                                        Some temporary cpoints are not getting made, not returning their position and causing the error message.
                                        I just checked it and it worked OK.
                                        But the Temp folder's SketchUp log file does show some missing 'commit_operations', which can cause bugsplat errors etc...
                                        I'll put it on my long 'to-do' list...
                                        Meanwhile make sure you same the model before doing anything complex like this in case there's a splat ...
                                        • panixiaP Offline
                                          panixia @Rich O Brien
                                          @Rich-O-Brien said in [Plugin] ExtrudeTools - Full Set:
                                          I use "extrude edges by rails" all the times. I believe it's the first plugin I ever used and I originally discovered the whole Sketchucation community because of that. Still using it after maybe 15 years. Love it. (Should be a native tool) 😍
                                            Mike Amos @panixia
                                            @panixia
                                            Agreed, it is the most used pplugin I have, flipping between this and Curviloft but Extrude tools has more control over the end result imho.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 29 / 32
