    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 656.6k Views 155 Watching
      cdurkin
      Despite how awesome this plugin is. I'm wondering?? is there a way to further the functionality by allowing the push-pull options to push-pull only lines into planes and maybe even guide points into lines? Perhaps there is already, but I have studied the tools fairly extensively and don't see a way to do this. Adding these features would make these already game-changing tools even better!
      Let me know if this is possible, in the works, or if not could it be possible to add it as a feature(s) in the near future updates of the tool?
        @cdurkin said:
        ... to push-pull only lines into planes ...
        There's a plugin that can extrude edges to faces already.
        What version of SketchUp are you using? Please complete your profile.
        • N Offline
          natia556
          Hı, I can't add it as a plugin to sketchup 2023 😳
            Why? What are you doing to install it? Did you also installed the required LibFredo6? Did you also install the required Sketchucation ExtensionStore tool?
            What version of SketchUp are you really using? Your profile indicates a nonexistant version.
              seasdes
              I noticed that JPP treats group copies as components. Is there a way to overcome this without having to enter each copy. I am running the latest version of JPP. and SU V21
              Using Sketchup Pro 2019
              • fredo6F Offline
                It's a change I need to make. No workaround for the time being, exect than to make the groups unique manually.
                  seasdes
                  Ok thanks
                    Artem Svetozarov
                    Hey everyone
                    Could you help me solve the issue? I can’t run push&pull plugin in any way
                    It was installed from sketchucation store plugin. I restarted the program, restarted the computer, reinstalled the last version of fredolib - the same problem.
                    There is a toolbar, but the buttons do not react and when I click on them these errors appear
                    Nevertheless for example the fredo scale plugin works correctly
                    Fredo6 Plugins Information on 2023-05-03 12:12:13 +0300
                    • Platform: x64-mswin64_140 - Ruby: 2.7.2
                    • Sketchup: 22.0.316
                    • LibFredo6: v13.9a
                    • LibFredo6 Binary loaded
                    • Sketchucation ExtensionStore: 4.3.1
                    • SCFLicense: v6.1a - 72
                    • Fredo6 Plugins
                      LordOfTheToolbars v2.4a
                      FredoGuides v2.4a
                      FredoScale v3.5a
                      FredoTools v4.3a
                      JointPushPull v4.6a - licensed FULL
                      RoundCorner v3.3a
                      Signature File: 2023-05-02 13:53:09 +0300
                      JointPushPull: 2023-05-03 12:11:11 +0300
                      Error: #<NoMethodError: undefined method wdlg_from_key' for Traductor::Wdlg:Class> c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:37:in check_instance_displayed'
                      c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:in invoke' c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:147:in invoke_quick_launcher'
                      c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:121:in block in startup' c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1469:in command_invoke'
                      c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1449:in block (2 levels) in build_config_commands' c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in block in add_command'
                      c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/controller_lordofthetoolbars.rbe:133:in `block in new'
                    • E Offline
                      euflypig
                      My Fredo6 Joint Push Pull control is nowhere to be found on my SU (Sketchup 2020) Mac (OS Ventura). All my Fredo6 plug ins usually show up under Tools > Fredo6 Collection. However, I cannot get the Joint Push Pull (nor the FredoSpline) to show up.
                      I've tried uninstall and reinstall them again in my extension manager, both Joint Push pull and FredoSpline appear to be "signed" written in green, but either one show up in tools. The other extensions all work fine (Fredo6 Roundcorner, Curviloft, FredoScale, TopoShaper). I have the Fredo6Bundle2022 license purchased.
                      Does anyone have any solution?
                        Is LibFredo6 and the Sketchucation Extension Store up to date? You need to make sure you have the current versions of both installed. Then restart SketchUp.
                        • W Offline
                          whddnjs8474
                          I can't see the icon image when using the joint push pull
                          W 1 Reply Last reply Reply Quote 0
                          • fredo6F Offline
                            Could you check that you have uptodate versions of
                            • LibFredo6
                            • Curviloft
                            • fredo6F Offline
                              NEW RELEASE: JointPushPull Interactive v4.7a - 10 Jul 23
                              JointPushPull Interactive 4.7a is a major release includingone fix and one evolution:
                              • Fix for Groups in multiple instances. Now, only the selected group(s) will be processed. They will be made unique on the fly.
                              • Preservation of special curves (circles, arcs, polygons). Whenver possible, JPP reassigns the special status the type of curves.
                              IMPORTANT: JointPushPull 4.7a requires LibFredo6 14.1 or above
                              See plugin home page of JointPushPull for Download of JointPushPull.
                              Main Post of the JointPushPull thread on this forum
                                trajanus96
                                I found the cause of the license error.
                                If set the computer's name to a non-English name, the license will not be recognized.
                                I solved my problem, but the license was applied in duplicate.
                                Fredo, can you retrieve the license for the above two?
                                An error occurred in the process of obtaining the license, and the pre-registered license was applied in duplicate. The computer didn't change and only Seat was used up.
                                I'd like to retrieve the above two licenses.
                                express one's thanks in advance.
                                Thank you. fredo
                                Seat ID: 27003; HW ID: WF1648954173.0G; Date of activation: 03/04/2022
                                Seat ID: 28476; HW ID: KI1649406241.0Z; Date of activation: 08/04/2022
                                • H Offline
                                  hayat eltelbany Newcomers
                                  thanks for sharing
                                  • I Offline
                                    isabellylima
                                    Olå, o plugin não estå sendo instalado no meu sketchup 23, o que eu faço?
                                    Jå inseri e habilitei ele pelas extensÔes, mas não estå aparecendo o plugin dentro do programa ou na bandeja.
                                    SOSSSS preciso dele.
                                      It appears under the Tools menu.
                                      But you also need LibFredo and the SketchUcation toolset downloaded and installed, and then SketchUp restarted to start it.
                                      It is also licensed [can be bought through its Tools submenu limk...], so ensure you have everything in place.
                                      Ele aparece no menu Ferramentas.
                                      Mas vocĂȘ tambĂ©m precisa baixar e instalar o LibFredo e o conjunto de ferramentas SketchUcation e, em seguida, reiniciar o SketchUp para iniciĂĄ-lo.
                                      Ele também é licenciado [pode ser adquirido através do submenu Ferramentas limk...], portanto, certifique-se de ter tudo no lugar.
                                      • thinhphamktsT Offline
                                        thinhphamkts
                                        Please someone help me with retrieve my license for this!!!
                                        I did active fully on 3 seats although I only have 1 desktop and 1 laptop.
                                        The reason was that I did reinstall my desktop and laptop several times due to softwares clashing.
                                        At that time, I did not release or deactivate my seats.
                                        Therefore, all the 3 seats now stayed in my previous installed windows.
                                        I go to license page (attached image) and see that other plugins have "release" button whilst "Joint Push Pull" doesn't have.
                                        Is there anything to reset my license for "Joint Push Pull"?
                                        I am being desperated now. I contacted to SketchUcation support many times but it seeems they don't take it seriously.
                                        Now my license seems to be useless.
                                        PLEASE HELP!!!
                                        • fredo6F Offline
                                          I did reset all seats of your JPP licenses.
                                          You need to revalidate now.
                                            thinhphamkts
                                            WOW,
                                            Thanks a lot! I am really appreciate.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 30
                                            • 31
                                            • 19 / 31
