    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 951.0k Views 155 Watching
    • fredo6F
      @tonytony321 said:
      Hope you can solve my problem, thank you.
      When you upgrade to LibFredo6 v13.2a, it is important you restart all instances of Sketchup.
      In the worse case, could you you restart your computer and it should make it.
      • I
        igorassis
        @tonytony321 said:
        Hi Fredo, thank you for the contribution to the community.
        My JPP doesn't start properly. It has no response when I click all of the icon from the toolbar.
        • I am using SKP 2022 on window 10. All fredo plugins are up to date.
        • I have already purchased the plugin bundle and activated the license for those plugins that I am using.
        • Fredo scale/ tools on surface/ round corner are all working properly.
        • Lib Fredo settings in tab - Window also not working except for set peferred languages.
        Any chance I can use a previous version for now?
        im having the same problem, i tried restarting, reinstalling and this is still happening,
        Error; #<NameError; undefined method `notify_by_otpicker' for class `Traductor;;FaceSelector'>
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `method'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `initialize__'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6faceselector.rbe;35;in `initialize'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `new'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `init_face_selector'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;151;in `initialize'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `new'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `action__mapping'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `call'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `launch_action'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;240;in `launch_action'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;87;in `launch_action'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;135;in `block in declare_command'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1464;in `command_invoke'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1444;in `block (2 levels) in build_config_commands'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
          antonblam
          Hey Fredo, I've ran into a problem.
          I duplicated a group a several times and tried to PudhPull them from the outside, as the extension allows. The problem is that the extension sees them as components and treats them accordingly.
          Do you have the solution for that?
            @igorassis
            Do you have the latest version of LibFredo installed ?
            Do you have the latest version of the SketchUcation toolset installed [v4.2.9] which has the up to date SCF licensing system ?
            Both are available from the PluginStore - restart SketchUp after installation to sync everything
            • fredo6F
              That's a known issue: Freshly copied groups behave like components. I may fix it for JPP.
              In the meantime, just enter (double-click) each group to make them unique.
                rv1974
                I wish Follow Push Pull will be able to remove geometry nicely a-la 3ds max (like shown on attached picture)
                • fredo6F
                  JPP currently does not delete faces. So, no holes and no clear. This would be complex to do, essentially because JPP is multi-face.
                  • C
                    cdurkin
                    Despite how awesome this plugin is. I'm wondering?? is there a way to further the functionality by allowing the push-pull options to push-pull only lines into planes and maybe even guide points into lines? Perhaps there is already, but I have studied the tools fairly extensively and don't see a way to do this. Adding these features would make these already game-changing tools even better!
                    Let me know if this is possible, in the works, or if not could it be possible to add it as a feature(s) in the near future updates of the tool?
                      @cdurkin said:
                      ... to push-pull only lines into planes ...
                      There's a plugin that can extrude edges to faces already.
                      What version of SketchUp are you using? Please complete your profile.
                      • N
                        natia556
                        Hı, I can't add it as a plugin to sketchup 2023 😳
                          Why? What are you doing to install it? Did you also installed the required LibFredo6? Did you also install the required Sketchucation ExtensionStore tool?
                          What version of SketchUp are you really using? Your profile indicates a nonexistant version.
                            seasdes
                            I noticed that JPP treats group copies as components. Is there a way to overcome this without having to enter each copy. I am running the latest version of JPP. and SU V21
                            Using Sketchup Pro 2019
                            • fredo6F
                              It's a change I need to make. No workaround for the time being, exect than to make the groups unique manually.
                                seasdes
                                Ok thanks
                                  Artem Svetozarov
                                  Hey everyone
                                  Could you help me solve the issue? I can’t run push&pull plugin in any way
                                  It was installed from sketchucation store plugin. I restarted the program, restarted the computer, reinstalled the last version of fredolib - the same problem.
                                  There is a toolbar, but the buttons do not react and when I click on them these errors appear
                                  Nevertheless for example the fredo scale plugin works correctly
                                  Fredo6 Plugins Information on 2023-05-03 12:12:13 +0300
                                  • Platform: x64-mswin64_140 - Ruby: 2.7.2
                                  • Sketchup: 22.0.316
                                  • LibFredo6: v13.9a
                                  • LibFredo6 Binary loaded
                                  • Sketchucation ExtensionStore: 4.3.1
                                  • SCFLicense: v6.1a - 72
                                  • Fredo6 Plugins
                                    LordOfTheToolbars v2.4a
                                    FredoGuides v2.4a
                                    FredoScale v3.5a
                                    FredoTools v4.3a
                                    JointPushPull v4.6a - licensed FULL
                                    RoundCorner v3.3a
                                    Signature File: 2023-05-02 13:53:09 +0300
                                    JointPushPull: 2023-05-03 12:11:11 +0300
                                    Error: #<NoMethodError: undefined method wdlg_from_key' for Traductor::Wdlg:Class> c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:37:in check_instance_displayed'
                                    c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:in invoke' c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:147:in invoke_quick_launcher'
                                    c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:121:in block in startup' c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1469:in command_invoke'
                                    c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1449:in block (2 levels) in build_config_commands' c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in block in add_command'
                                    c:/users/a_sve/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/controller_lordofthetoolbars.rbe:133:in `block in new'
                                  • E
                                    euflypig
                                    My Fredo6 Joint Push Pull control is nowhere to be found on my SU (Sketchup 2020) Mac (OS Ventura). All my Fredo6 plug ins usually show up under Tools > Fredo6 Collection. However, I cannot get the Joint Push Pull (nor the FredoSpline) to show up.
                                    I've tried uninstall and reinstall them again in my extension manager, both Joint Push pull and FredoSpline appear to be "signed" written in green, but either one show up in tools. The other extensions all work fine (Fredo6 Roundcorner, Curviloft, FredoScale, TopoShaper). I have the Fredo6Bundle2022 license purchased.
                                    Does anyone have any solution?
                                      Is LibFredo6 and the Sketchucation Extension Store up to date? You need to make sure you have the current versions of both installed. Then restart SketchUp.
                                      • W
                                        whddnjs8474
                                        I can't see the icon image when using the joint push pull
                                        W 1 Reply Last reply
                                        • fredo6F
                                          Could you check that you have uptodate versions of
                                          • LibFredo6
                                          • Curviloft
                                          • fredo6F
                                            NEW RELEASE: JointPushPull Interactive v4.7a - 10 Jul 23
                                            JointPushPull Interactive 4.7a is a major release includingone fix and one evolution:
                                            • Fix for Groups in multiple instances. Now, only the selected group(s) will be processed. They will be made unique on the fly.
                                            • Preservation of special curves (circles, arcs, polygons). Whenver possible, JPP reassigns the special status the type of curves.
                                            IMPORTANT: JointPushPull 4.7a requires LibFredo6 14.1 or above
                                            See plugin home page of JointPushPull for Download of JointPushPull.
                                            Main Post of the JointPushPull thread on this forum
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 28 / 31
