    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 593 Posters 13.7m Views 595 Watching
    • zivotinjaZ
      zivotinja
      HI Fredo, I cannot use the sketchucation 4.3 plugin it crashes all my SK2021-23. How can I install it using the regular installation process as other plugins? I have paid for ROund Corner and your bundle ~70USD However it does not work.
      • I
        Isarescu
        @fredo6 said:
        @isarescu said:
        After updating to 13.9a nothing works anymore. I see the extensions in the toolbar, I can press the buttons, but nothing happens: Fredo Tools, Joint Push Pull, Fredo Scale, Curviloft, Round Corner.
        Later: after activating again all the licenses, Curviloft and RoudCorner works. Fredo Tools, Curvizard, JointPushPull and FredoScale still don`t work.
        Could you open the Ruby console to see if there are errors.
        Normally you do not need to activate again the license when you upgrade LibFredo6.
        "Error: #<NoMethodError: undefined method wdlg_from_key' for Traductor::Wdlg:Class> c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:37:in check_instance_displayed'
        c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:in invoke' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_fredotools/fredotools.rbe:233:in invoke_quick_launcher'
        c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_fredotools/fredotools.rbe:268:in block in startup' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1469:in command_invoke'
        c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1449:in block (2 levels) in build_config_commands' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in block in add_command'
        c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:in invoke' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:147:in invoke_quick_launcher'
        c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:121:in block in startup' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1469:in command_invoke'
        c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:in invoke' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe:445:in invoke_quick_launcher'
        c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe:291:in block in configure' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1469:in command_invoke'
          dllukac
          Hello
          I just migrated to SU 2023. I have a problem with LibFredo6. I downloaded and installed the latest release, but SketchUp keeps showing an error message:
          "You must install LibFredo6 to run ..."
          I tried to uninstall a reinstall LibFredo, reboot Sketchup, reboot the computer - but an error message pop`s up on SketchUp start.
          No one of the installed Fredo6 plugins are working.
          Thanks for your help.
          • C
            carpinteriaymodulosvalencia
            hola, gracias a todos por permitirnos con sus logros de hacer mas fácil el uso de estas herramientas para un mejor desempeño y en menor tiempo. también quisiera obtener por licencia permanente el plugins fredo scale pero no cuento con ninguna de las formas de pago que mencionan. solo hay una forma de pago con la que cuento y es por medio de la entidad o corresponsal EFECTY
            • P
              PATISTAN
              bastant bueno
              • fredo6F
                What is the message? Could you include a screenshot. Thanks
                • Y
                  Yago Brown Newcomers
                  Error launching Sketchup Pro 2022. Crashes.
                  "Curviloft: This plugin requires a LibFredo6 version greater than 124. The current version is 67"
                  How to solve it?
                    How to solve it?
                    Update Curviloft, LibFredo6, and the Sketchucation ExtensionStore tool to their current versions.
                      The file does exist in the PluginStore !
                      https://sketchucation.com/pluginstore?pln=LibFredo6
                      What are you trying to do ?
                      What error messages do you see ?
                      Many thousands of people successfully download RBZ files from us every day.
                      Why are you so different...
                      • G
                        Gojadri Newcomers
                        The file does not exist on the site, on the server. And so with many of the plugins.
                        In 2023 can't you solve such a small problem? Put on Google Drive.
                          PS:
                          I've just found out that there was a glitch on our server yesterday, it prevented a few random users from downloading from the PluginStore.
                          It's fixed now, so it might have fixed your problem ?
                          • F
                            Filippidi
                            Hello,
                            could you please help me. I intall LibFredo6 versio 13.9a in order to use fredo corner but after that nothing is working of fredo library even the fredo tools...
                            All plugins that i have install are the latest version in Sketchup 2023.
                            Any ideas?
                              What method are you using to install? Do you also have the current version of the Sketchucation ExtensionStore tool installed?
                              Please update your profile. It is out of date.
                                You need to have the latest versions of the extensions/lib and the SketchUcation toolset installed , and SketchUp restarted...
                                But are you really using SketchUp v2016 ?
                                It's pretty much unsupported - with v2017 being the outlier...
                                Perhaps therein lies your problem.
                                There are legacy copies of Fredo's extensions/lib in the PluginStore, but they will have limited use...
                                Otherwise update your profile with the correct SketchUp version and we go one step forward...
                                  justask
                                  Hey,
                                  I did all the required steps for this plug in, purchased the license, but the plug in does not work in any sketchup version. Any ideas why?
                                    Libfredo is a helper library for Fredo extensions. It does nothing on it own.
                                      @justask
                                      What extension are you trying to use ?
                                      I suspect one of Fredo's but you've posted in his support Lib thread and not explained your problem very clearly.
                                      You need the latest versions of LibFredo6 and the SketchUcation toolset installing and SketchUp restarting to allow Fredo's extensions to work and get licensed etc...
                                      • N
                                        nicoreitze
                                        Hello, I'm having problems with fredo tools. A few weeks ago curviloft stopped working from one moment to another. I tried updating fredo tools versions, reinstalling, and even reinstalling sketchup. So far I tried SKP 2022 and 2023 and I still have the same problem. I manage to install the plugins but they don't respond. Pleas help
                                        • F
                                          Flaggmakesart Newcomers
                                          Hello,
                                          Ive just purchased a license for Round corner, love the tool, but when i come to install the sketchucation plug in i keep on getting this error message.
                                          :file does not exist
                                          Can you help with some advice as to what is going wrong?
                                            There was a glitch with the SCF Amazon server.
                                            It first happened yesterday, it was fixed...
                                            Today it seems to have recurred - again it's been fixed...
                                            Hopefully a bit more permanently !!
                                            • 95
                                            • 96
                                            • 97
                                            • 98
                                            • 99
                                            • 115
                                            • 116
                                            • 97 / 116
