    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 687.0k Views 151 Watching
      That is not a very helpful post !
      Please explain how it doesn't work, SketchUp version, all error messages, Ruby Console output etc, and confirm that you have the latest versions of the extension, and LibFredo6, and the SketchUcation toolset installed [for the licensing] and that you have restarted SketchUp to sync everything.
        satori0904 Newcomers
        nice to meet you
        I bought the app the other day
        An error occurred in the app and I can no longer use it.
        sketchup2022
        fred corner 2.6
        LibFredo6 13.7
        Sketch Ucation 4.3.0
        is using
          nice to meet you
          sketchup2022
          fred corner 2.6
          LibFredo6 13.7
          is using
          • fredo6F Offline
            Could you upgrade to LibFredo6 v13.9. This should solve the problem.
              Hello
              upgrade LibFredo6 v13.9
              I tried it, but it didn't improve.
                Your profile says you are using SketchUp 2017 Make on Mac. Is that correct? What version of Mac OS?
                • fredo6F Offline
                  @satori0904
                  Based on the picture you posted, it seems that this is not a problem of installation, but a problem while using the plugin.
                  Not sure, because your screenshot does not show the button palette, but it is likely that you have the Edge Filter not properly set.
                    Hello
                    thank you all
                    After reinstalling Sketchup, it worked.
                    Thank you very much!
                    • 8 Offline
                      8 perf 0 Newcomers
                      Ok, I guess add me to the list of users who can no longer use Fredo plugins. Running 2017 Make, on mac os 10.14. All the newest sketchucation/ fredo dependencies installed.
                      Every last Fredo plugin now comes up with a license error as having expired back in early February.
                      Am I to understand that there are absolutely NO free options on these plugins anymore? Even the ones I have donated to and been using with zero problems for over 5 years? No other plugins downloaded from Sketchucation seem to have this issue. What changed and why?
                        @8 perf said:
                        Every last Fredo plugin now comes up with a license error as having expired back in early February ...
                        ... What changed and why?
                        Not all of Fredo's extensions require a paid license but a few of them do. FredoCorner became a "paid" extension quite a while back. Some others became "paid" extensions as of March 1st of 2022. There are loas of other extensions from Fredo6 as well as others that are still available at no charge. Fredo puts a lot of effort into keeping his extensions up to date and fixing things. The amount he's charging for the licenses is trivial. You certainly can choose to use other extensions if you don't find it worthwhile investing anything into your hobby.
                        • N Offline
                          NEKOEMPIRE
                          hey, this is extreamly useful but for some reason a window pops up saying "an error occured in the ruby code"
                          how do i fix that?
                          Ruby Code issue
                            Share the .skp file so we can see your model and help you sort out the issue.
                            • 8 Offline
                              8 perf 0 Newcomers
                              To be specific, Curviloft, Joint Push Pull and the original Round Corner are the ones I use or used to use. All three were developed and running just fine, for my uses anyway, long before SU 2017. I was using them without issue just 6 months ago, still on SU 2017.
                              Ever since Trimble took over from Google and switched to a subscription model, a lot of us hobbyists felt left behind. I dont use it professionally, and only now a few times a month for personal projects, so a high subscription price is out of the question. Anyone still using 2017 now no longer has access to the extension warehouse or the 3d warehouse via the app. This hurts. Something about a security flaw prompted this but I can still visit the website. I get it.
                              The three plugins I mentioned work just fine on 2017 but i understand the development of newer/ better to keep pace with the upgrades in the master program are necessary. What I dont understand is cutting off access to the older, less sophisticated versions for the older version of SU 2017. Having donated back in the day for plugins designed for a free program, now being asked to buy a license to keep using them, hurts. A lot.
                              What's so wrong with a free/ hobbyist license? Treat the hobbyists right and maybe when they decide to go pro, they bring you and your programs with them to the commercial licensed platforms.
                              • bintoitinoB Offline
                                bintoitino
                                I've had an error since about a month ago, I can't use FredoCorner, I have a license!
                                When I try to use the plugin it gives me this error: INVALID: No good Edges at FACE
                                I'm using it in the same way I've been using it for ages, I don't understand why this is happening.
                                Tried with different versions of SketchUp itself, and different files, always the same.
                                I tried a clean install of everything and nothing changed.
                                Can someone help?
                                  Have you installed the very newest versions of the extension itself, LibFredo6 [for support] and the SketchUcation toolset [for the licensing], and then restarted SketchUp ?
                                  This might fix things...
                                    bintoitino
                                    Yes, I made a clean install of everything, didn't help.
                                      Perhaps Fredo will chip in ??
                                        bintoitino
                                        I hope so, I'm desperate for this plugin!
                                        • fredo6F Offline
                                          Watch the Edge Prop Filter in the palette. You seem to select only smooth edges. Just set it to Plain edges.
                                            bintoitino
                                            And it was that simple... I tried to reset to factory settings but that didn't change...!
                                            Thank you!! Now I can keep working!! Love your plugins!
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 19 / 23
