    2.3k Posts 517 Posters 3.0m Views 522 Watching
      Please visit https://sketchucation.com/webshop/my-licences.php
      Check if that device is now released.
        DC34170
        Perfect ! Thank you very much.
        • C
          cpark0925
          I bought a package of SCF Lincense which includes reoundcorner.
          Can this be transfered to Fredo Corner? or should I buy another one for fredo corner?
            RubenAlves74
            For different reasons, from time to time I have to format my PC's disk. How can I then validate the license again?
              We can't transfer licenses.
                Use https://sketchucation.com/webshop/my-licences.php to release seats.
                Make sure your device/s are using Sketchucation Tools 4.3.0
                Sketchucation Tools | SketchUcation
                (sketchucation.com)
                • K
                  kixiao9487
                  How should I fix this? I've tried redownloading curviloft and my license countless times
                  • K
                    kixiao9487
                    How should I fix this? I've tried redownloading curviloft and my license countless times.螢幕擷取畫面 2023-03-04 182841.png
                    • K
                      kixiao9487
                      我無法裝入我的許可證,它一直顯示我更改了電腦名稱,我已經刪除signature文件無數次仍無法解決問題
                        The error message shows that the signature-file is invalid, usually this is because you've renamed your computer.
                        It suggests that you erase the signature-file.
                        It asks if you want to open the folder containing the file.
                        If you answer Y[es] the folder opens and you can erase the file.
                        Then you need to reset the license[s] under the Tools > Fred6Collection submenu for that extension > License..., which will then make a new signature-file using the current computer's details...
                        • K
                          kixiao9487
                          I deleted it, but it still doesn't improve when it rebuilds the signature file, "The count IF exited" is always displayed in "SCFLicenseSignature - DO NOT MODIFY OR DELETE"
                            The signature-file name contains text warning you not to delete it.
                            BUT you must delete it if there are problems with its configuration.
                            It's rebuilt to suit the latest set up after redoing the licenses...
                            Your "The count IF exited" quote is not easy to understand,
                            Perhaps it's a problem because English is not your first language ?
                            Is there anything odd about your computer's name ?
                            It should follow the Windows naming recommendations... e.g. no special or foreign characters - this might therefore confuse Ruby when it reads/saves the data ?
                            • K
                              kixiao9487
                              Yes, my computer name was originally in Chinese, I changed it to English and it was resolved, thanks for your help.
                              • V
                                Vanwanar
                                I made a post asking but I think here is where I should be asking my question. Where can I request for my seats on all my fredo plugins to be released? Because I no longer have access to some of the licenses I actived (because of PC formats) and I can't find a place where to release them. Thanks in advance
                                • CadFatherC
                                  CadFather
                                  some licences do not show the release checkbox, is this a bug?
                                  @vanmar have you tried here?
                                  SketchUcation | My licences
                                  (sketchucation.com)
                                    Which ones?
                                    • CadFatherC
                                      CadFather
                                      thanks Dave, it's hit and miss, these ones for example don't show the option
                                      ClothWorks
                                      ToolsOnSurface
                                      FredoSpline
                                      RoundCorner
                                      Curviloft
                                      Curvizard
                                        @cadfather said:
                                        is this a bug?
                                        No, it means either your versions are outdated or Sketchucation Tools is outdated.
                                        Consider that on your https://sketchucation.com/webshop/my-licences.php page your have activated on 7 separate devices.
                                        Are all these devices running the latest releases? If not then you can't online release if the device holding the seat is not updated. Oly devices running the latest licensing version has online release enabled at https://sketchucation.com/webshop/my-licences.php
                                          ClothWorks
                                          ToolsOnSurface
                                          FredoSpline
                                          RoundCorner
                                          Curviloft
                                          Curvizard
                                          • CadFatherC
                                            CadFather
                                            yes but that's not what I mean,
                                            when i try to clear a seat from the SCF License page, the option is missing.
                                            say i want to clear all the seats - it is not possible
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 115
                                            • 116
                                            • 75 / 116
