    2.3k Posts 515 Posters 2.8m Views 520 Watching
      @rubenalves74 said:
      For different reasons, from time to time I have to format my PC's disk. How can I then validate the license again?
      Use https://sketchucation.com/webshop/my-licences.php to release seats.
      Make sure your device/s are using Sketchucation Tools 4.3.0
      Sketchucation Tools | SketchUcation
      (sketchucation.com)
      • K
        kixiao9487
        How should I fix this? I've tried redownloading curviloft and my license countless times
        • K
          kixiao9487
          How should I fix this? I've tried redownloading curviloft and my license countless times.螢幕擷取畫面 2023-03-04 182841.png
          • K
            kixiao9487
            我無法裝入我的許可證,它一直顯示我更改了電腦名稱,我已經刪除signature文件無數次仍無法解決問題
              The error message shows that the signature-file is invalid, usually this is because you've renamed your computer.
              It suggests that you erase the signature-file.
              It asks if you want to open the folder containing the file.
              If you answer Y[es] the folder opens and you can erase the file.
              Then you need to reset the license[s] under the Tools > Fred6Collection submenu for that extension > License..., which will then make a new signature-file using the current computer's details...
              • K
                kixiao9487
                I deleted it, but it still doesn't improve when it rebuilds the signature file, "The count IF exited" is always displayed in "SCFLicenseSignature - DO NOT MODIFY OR DELETE"
                  The signature-file name contains text warning you not to delete it.
                  BUT you must delete it if there are problems with its configuration.
                  It's rebuilt to suit the latest set up after redoing the licenses...
                  Your "The count IF exited" quote is not easy to understand,
                  Perhaps it's a problem because English is not your first language ?
                  Is there anything odd about your computer's name ?
                  It should follow the Windows naming recommendations... e.g. no special or foreign characters - this might therefore confuse Ruby when it reads/saves the data ?
                  • K
                    kixiao9487
                    Yes, my computer name was originally in Chinese, I changed it to English and it was resolved, thanks for your help.
                    • V
                      Vanwanar
                      I made a post asking but I think here is where I should be asking my question. Where can I request for my seats on all my fredo plugins to be released? Because I no longer have access to some of the licenses I actived (because of PC formats) and I can't find a place where to release them. Thanks in advance
                      • CadFatherC
                        CadFather
                        some licences do not show the release checkbox, is this a bug?
                        @vanmar have you tried here?
                        SketchUcation | My licences
                        (sketchucation.com)
                          Which ones?
                          • CadFatherC
                            CadFather
                            thanks Dave, it's hit and miss, these ones for example don't show the option
                            ClothWorks
                            ToolsOnSurface
                            FredoSpline
                            RoundCorner
                            Curviloft
                            Curvizard
                              @cadfather said:
                              is this a bug?
                              No, it means either your versions are outdated or Sketchucation Tools is outdated.
                              Consider that on your https://sketchucation.com/webshop/my-licences.php page your have activated on 7 separate devices.
                              Are all these devices running the latest releases? If not then you can't online release if the device holding the seat is not updated. Oly devices running the latest licensing version has online release enabled at https://sketchucation.com/webshop/my-licences.php
                                ClothWorks
                                ToolsOnSurface
                                FredoSpline
                                RoundCorner
                                Curviloft
                                Curvizard
                                • CadFatherC
                                  CadFather
                                  yes but that's not what I mean,
                                  when i try to clear a seat from the SCF License page, the option is missing.
                                  say i want to clear all the seats - it is not possible
                                    @cadfather said:
                                    yes but that's not what I mean, when i try to clear a seat from the SCF License page, the option is missing. say i want to clear all the seats - it is not possible
                                    The option is missing because the device is not running Sketchucation Tools 4.3.0
                                    You have validated licenses on devices that used a version of Sketchucation Tools that didn't have online release at that time.
                                    All devices needs Sketchucation Tools 4.3.0 for it to be releasable at https://sketchucation.com/webshop/my-licences.php
                                    So you need to go to the devices and release the seat or update Sketchucation Tools and Libfredo on those device.
                                    You can't update at an unrelated device and have the online release propagate around to other devices.
                                    • RayWR
                                      RayW
                                      I don't understand this at all. I've been using what I thought was the 'free' basic version of round corner for years. Why all of a sudden do I need a licence for it? I'm a pensioner, SKP is just a hobby for me, I can't afford this.
                                      • cottyC
                                        cotty
                                        Fredo changed the license for some of his plugins in March 2022:
                                        https://forums.sketchup.com/t/more-fredo6-plugins-becoming-paid-extensions/191090
                                        If you use the plugin a lot, approx. 7 USD should not be too much even for a pensioner, right? Fredo has also put a lot of work into the plugins and deserves recognition for it.
                                        my SketchUp gallery
                                        • CadFatherC
                                          CadFather
                                          perhaps i'm missing something, but it seems to happen with latest SKtools and libfredo (which is what I'm running) - for example I have 2 fredospline seats, one of them activated in january and yet it cannot be released.
                                          shouldn't all plugins have a release checkbox in any case?
                                            Yes, if every device the activation happened on is using Sketchucation Tools 4.3.0
                                            You've lots of device activations. Different devices. 7 to be accurate.
                                            Can you say for certainty all 7 are currently running the latest Sketchucation Tools? And is any associatted licensed extension also the latest release?
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 78
                                            • 115
                                            • 116
                                            • 76 / 116
