    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    707 Posts 163 Posters 752.2k Views 163 Watching
    • H Offline
      hank_hogan
      As I wrote, I have Windows 11 Pro. Also I have i7-11800H 2.30GHz, 32GB RAM and RTX 3080.
      Sorry for inacurate profile info, it's just been corrected.
        I can also confirm that Clothworks plugin crashes SketchUp 2022 pro (without any bugsplat info) a moment after I press toggle play button to start cloth simulation
        Lots of additional info is missing. Your input mesh or simulation settings could be the cause.
        In many cases its the simulation settings that cause SketchUp to buckle. Try sharing a simple file that 100% fails on your system.
        • H Offline
          hank_hogan
          At firts I tried default setting suggested by plugin. Then I tried settings presented in plugin's author in manual. All leads to the same effect... but ok, I see I'm in the minority of users with such problem, so it's cause must be on my end. Will keep looking. Thank You all for help.
            As Rich suggested, share the file that shows CLothworks crashing SketchUp so we can try to help you. No point in trying to sort it out on your own when there's help freely available.
              Anton_S
              Thank you for the report!
              Would it be possible for you to share the model with me? You can send me a private message or email to clothworks@sketchucation.com
              Thanks,
              Anton
                For some reason I have no xontextaul menu with right click. Has somethng changed?
                Stay well folks.
                  Anton_S
                  Stay well folks.
                  Make sure you're right-clicking on top level group/component to see the clothworks context menu.
                    Yes mate, got that and the basics. Something wrong with the model. At least that's the only thing I can come up with. Tried a new model and the context menue was apparent. Completed the process fine this time.
                    What can you do when clicknology has a fit of 'sod you'.
                    • F Offline
                      FelipeMagalhaes Newcomers
                      Hello!
                      I'm trying to find a way to simulate a cloth but with rounded corners and not using the Adaptive Grid subdivision, since it really messes up the mesh.
                      Is there someone?
                      Tks
                        @felipemagalhaes said:
                        Hello!since it really messes up the mesh.
                        How does it mess up the mesh? Share your .skp file so we can see.
                        I don't have any issues with the mesh on a cloth with rounded corners and Adaptive Grid.
                        • F Offline
                          [attachment=2:1bx2g7pn]<!-- ia2 -->Screenshot - 2_15_2023 , 2_05_41 PM.png<!-- ia2 -->[/attachment:1bx2g7pn]
                          I found a way to solve my problem.
                          When I was trying to apply the Adaptive Grid, it was messing up the mesh next to the edges by putting too much tension on it. By doing that, in the end of the simulation it was visible some rough distortions (even with more subdivisions applyed).
                          However, by putting some suportive lines on the mesh the Adaptive Grid could spread the subdivision more uniformly, than the problem around the edges was gone.
                          Anyway, thank you for your help.
                          Rough Edges
                          Better edges with suport lines
                            Anton_S
                            [attachment=2:14cvwrh9]<!-- ia2 -->Screenshot - 2_15_2023 , 2_05_41 PM.png<!-- ia2 -->[/attachment:14cvwrh9]
                            Nice find! Yes, adding supportive lines allows you to control the subdivision. This does however suggest some improvements to the subdivision are needed. Thanks for your insight.
                              BottiAgustin Newcomers
                              realmente una locura este plugin. te felicito πŸ‘ πŸ‘ πŸ‘
                                Trying to drape a roof canvas on an AFV, gets squirelly every time lately. Crash #537781
                                As per usual, something basic, can you tell me where I messed up please?
                                I know, barely trust myself to cross the road, sinusitis. Jubbly.
                                  mahsa1995
                                  Hello
                                  I'm trying to make a sheer material drape but the cloth is giving me one face that I can apply material too. (the back face of the material (grey part) How can I have two sided cloth? i hope this makes sense
                                    @mahsa1995 said:
                                    ... but the cloth is giving me one face that I can apply material too. (the back face of the material (grey part) How can I have two sided cloth?
                                    Share the SketchUp model file so we can see what you've got. You should be able to apply the material to both sides.
                                      rebrandrianne
                                      Is it possible to make round objects (group) a cloth? example; making a round cushion?
                                      I now only can work with rectangle groups?
                                      Greetings,
                                      Rianne
                                        @rebrandrianne said:
                                        You can use a circle for the coth. Drape it over a rounded form for a cushion if you want.
                                        Circle as Cloth
                                        • I Offline
                                          i5963c Extension Creator
                                          I acquired a license for ClothWorks, and installed the plugin and activated the license as specified in the instructions.
                                          The plugin appears in the Sketchup menu (also with right click) and the icons are visible in the toolbar.
                                          However, a feature that is apparently linked to the paid license (i.e. 'compressing' the pins) doesn't work. I can only select the set of individual pins, but the Gizmo to manipulate the combined pins is never activated.
                                          I tried already to release the license, uninstall, exit and relaunch Sketchup, reinstall the plugin and re-activate the license. It all doesn't help...
                                          I have the plugin installed on 2 PC's (Windows 10 and 11). It doesn't work on both PC's (the license is valid for 3 devices, by the way).
                                          Any suggestions to fix this issue are highly appreciated. I bought this plugin basically to do some modelling of curtains, and without the feature to compress the pins, this plugin is quite useless to me.
                                            Do you also have the current version of the Sketchucation Extension Store installed?
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 33 / 36
