    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 155.5k Views 84 Watching
    • OxerO Offline
      Oxer
      With the new version 4.2.4 the issue persists when I select Extensions Menu > SketchUcation > SCF License : Global Status...
      Error; #<LoadError; dlopen(/Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle, 9); no suitable image found.  Did find;
      	/Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle; cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown)
      	/Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle; cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown) - /Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle>
      /Applications/SketchUp 2017/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.2/lib/ruby/2.2.0/rubygems/core_ext/kernel_require.rb;54;in `require'
      /users/User/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;156;in `load_binary'
      /users/User/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;54;in `license_dialog_global'
      /users/User/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;2123;in `block (2 levels) in <module;SCFLicense>'
      SketchUp;1;in `call'
      macOS 10.13.6 & Sketchup 2017
        ramohn
        @rich o brien said:
        Have you cleared your browser cache? [Safari for MAC]
        I don't know if you're talking to me... Yes, I have cleared.
        • W Offline
          wozabee
          Hi guys
          Have been away for some Sketchup for a few years and went to install SketchUcation Tools into my Sketchup 2016.
          It's telling me this latest version of the plugin is incompatible with 2016, and to install v3~
          Is there an archive I can download earlier versions from?
          Also, I hear there was a possible slow-down problem with 3.0~??
          Would v3.1.8 be better?
          Cheers,
          Woz B.
            For v2016 use the newest version 3 of the toolset [v3.1.8]
            • Miner_JeffM Offline
              Miner_Jeff
              Hi @Tig,
              I am looking to download version 3.1 that will work with SU 2016. (I know it's well behind the current SU version. It's what I have...)
              Do you have a link for V3.1?
              Or a trick to download it?
              Many thanks,
              Miner_jeff
                I've sent you a PM...
                • V Offline
                  valerostudio
                  This plugin is being blocked by our Sonic Wall due to being behind an IP in Russia. I've used this extension for years and never had this issue. Did something change recently?
                    [attachment=0:19o3pqh1]<!-- ia0 -->blocked.JPG<!-- ia0 -->[/attachment:19o3pqh1]
                    The IP indicated in the message is shown as being in Germany. I'm not getting the same message when I open it.
                      Gábor
                      Nothing has changed on our side. More than likely your Sonic Wall misidentified the location of our server,
                        Published v4.3.0 with the following changes:
                        • Protection against decrypting RBE
                        • Adjustment in the binary to manage seat release
                        • Refresh of GUI
                        Other memory handling, error handling and bugfixes under the hood.
                        Make sure you update and Happy New Year!
                          rutpin
                          I downloaded the most updated version ExtensionStore v4.3.0, and it still doesn't allow me to download extensions from there, I get a message like this
                            You shouldn't be putting extensions into Program Data. The extensions you add should be going into User/App Data/Roaming/SketchUp/.../Plugins. Program Data should have security settings to prevent you from putting files into it.
                              @rutpin said:
                              Hello, thanks for the help, I don't understand what I should do - when I ask to download the file I have 2 options where to save it, and in both it doesn't let me, what should I do? Can you tell me more?
                              Thank you.
                              First, make sure you've installed SketchUp correctly. That requires right clicking on the downloaded installer and choosing Run as administrator. If you didn't do that, or don't know, do it now and when presented with the options, choose Repair.
                              When you are installing extensions, choose the User/App Data location. If SketchUp was installed correctly you should have permission to install into that folder.
                              FWIW, you don't want to add anything to any Program Data folders. There is a huge potential to lose anything you add if you need to reinstall the program because the folders can be overwritten.
                                @rutpin said:
                                I did that, and it still doesn't give me the option to install in a folder, is there anything else that can be done?
                                Go to the User/AppData/.../Plugins folder and delete the Sketchucation plugin file and the associated folder. Download the extension from Resources at the top of this page. Reboot your computer and then open SketchUp and use Extension Manager to install the Sketchucation Tool.
                                @rutpin said:
                                Hope I'm not bothering you...
                                No. You aren't but there's no need to be sending me PMs. That's limiting your options for help.
                                • I Offline
                                  intara
                                  sorry I will activate license and this pop up is appear."Sorry-An error occured in the communication with Sketchucation " How can i fixed it.
                                    Do you have the latest version of the Sketchucation Tool? Do you have a firewall that might be blocking the connection? What version of SketchUp are you actually using? Your profile says 2020 Free/Make which is impossible as there is no such version.
                                      You need the latest version of the SketchUcation toolset installing, and the extension itself, and in the case of Fredo's extensions Libfredo6...
                                      After the installation restart SketchUp to sync everything.
                                      Save the license files to somewhere safe on your computer.
                                      Try SCF license validation again...
                                        We just published v4.3.1 with some small but important changes.
                                        • License improvements for releasing seats
                                        • Tooltip fixes
                                        • Link pasting (Experimental)
                                        The licensing part is important for those encountering issue when going offline. So please try testing if this resolves your issues. Especially the need to revalidate.
                                        Link pasting, while experimental, is a new way to install extensions using a URL. So if your browsing around https://sketchucation.com/pluginstore and see something you like just right click > copy link
                                        https://i.imgur.com/qLOdyS1.png
                                        Now in SketchUp use the Paste icon in the footer to prompt for a link...
                                        https://i.imgur.com/zjKMsnq.png
                                        Paste in your link i.e https://sketchucation.com/pluginstore?pln=HoleEditor and hit Enter/OK
                                        Or if your lazy pln=HoleEditor will also work
                                        It's experimental at the moment and untested on Mac. So expect funky behaviour.
                                        If you don't see a Paste icon in the footer press CTRL + F5 with the ExtensionStore dialog active to force a hard reload.
                                          The install from link got a little more polish server side. No need to update extension. But a CTRL + F5 maybe needed to refresh cache in the dialog.
                                          • N Offline
                                            NL71HSMS
                                            REQUEST TO THE DEVELOPER: Tackle this issue, it has not been solved by reinstalling neither SU (to 2023) nor removing and reinstalling a freshly downloaded Sketchucation Tools v4.3.1.
                                            Every time I startup Sketchup, the ExtensionStore v4.3.1 from SketchUcation starts up as well and asks for its credentials, very annoying. Is there a way to stop this? Filling in the credentials doesn't help, every time the window is closed your credentials are lost and you can start from scratch...
                                            Furthermore, the menu item on the right side is grayed out, and when clicking the settings button, you get a "Webpage cannot be found error". Please improve the tool.
                                            ExtensionStore startup screen
                                            • 11
                                            • 12
                                            • 13
                                            • 19
                                            • 20
                                            • 11 / 20
