    [Tips] Animator Tips and Tricks
    renderpluginsextensions
    74 Posts 18 Posters 279.8k Views 18 Watching
    • BoxB
      Yeah, it seems like the natural next step, hopefully it's something the grandmaster is working on.
      πŸ’š
        It was animated crowds I was thinking of...
        • BoxB
          Well, you can do that within the same file no problem, but the hidden door file I posted I created and then thought of the Robot only after doing it all. I had animated the robot in another file but couldn't get it into the hidden door file with animation intact. And by then it was late and I didn't have the energy to reanimate the robot. He really should walk into the space and then exit through the roof.
            shelburneplanner
            Anyone have tips for animating speech using Fredo6 Animator and a model in SketchUp? I'm working with SU 2017 (Make).
            thanks in advance for suggestions!
            • fredo6F
              What do you mean by 'animating speech'?
              • ntxdaveN
                ntxdave
                [attachment=0:3irjohc4]<!-- ia0 -->dummy-test.gif<!-- ia0 -->[/attachment:3irjohc4]
                Fredo, is there a way to save this animation, or any animation created with Animator, in a format that could then be used in PowerPoint?
                As a reference, here are two videos that show animated 3D models being used in PPT:
                https://www.youtube.com/watch?v=2-9g6fVL7uQ
                https://www.youtube.com/watch?v=3Qo_Hx21KUc
                BTW, PPT will allow you to import an skip file so maybe the native skip file with your animations will work. My laptop died so I do not have the capability to try it myself. 😞
                Press F1...thank me later
                • fredo6F
                  I don't think you can insert a skp model with Animator data, because Animator data are totally custom.
                  However, I see that PPT accepts several 3D formats, but apparently none with Animation (like gLTF).
                  Worth exploring however....
                  • ntxdaveN
                    ntxdave
                    Here is some information I found about the type of 3D model files that PPT will accept:
                    As of now, PowerPoint can insert 3D models in these formats:
                    Filmbox Format – *.fbx files
                    Object Format – *.obj files
                    3D Manufacturing Format – *.3mf files
                    Polygon Format – *.ply files
                    StereoLithography Format – *.stl files
                    Binary GL Transmission Format – *.glb files
                    I am not sure how old this info is. I have seen a video that does show it accepting a .skp file as well. Also I have seen some places where this (allowing you to insert a 3D model) might be limited to PPT 365. So I am not sure about any of this. It would also be neat if this type of facility was available in the presentation feature of LayOut.
                    • ntxdaveN
                      ntxdave
                      Another vey interesting video that confirms the ability to use .skp files in PPT
                      • fredo6F
                        Importing a static 3D model is ok. This is more about the problem of importing the animation. I guess that it is only the gLTF format that will do that.
                        • ntxdaveN
                          ntxdave
                          Can that be done with Animator? If it can, it would be neat to see an example.
                          Maybe it is time for me to quit bringing up topics like this.
                            I think the missing info in your thinking is what a 3D file format natively is capable of.
                            SKP cannot store animation readable to other apps. So you would need a means to bake the animator data into the model and then export that into a format that supports animation. FBX, USDS, GTLF, Alembic all store animation data that other apps can read.
                            Animator does store animation data in a .skp file but in a way that only Animator is able to read.
                            Its the same as calling over to your mates house with an Atari Pong cartridge and trying to play it on a Nintendo.
                            Microsoft wouldn't know anything about the animation stored in a skp in the same way.
                            • ntxdaveN
                              ntxdave
                              Yes Rick, I understand. I was trying to see if Fredo might be able to come up with a way to generate a GLTF file with Animator.
                              Maybe I am just being a PITA and it is time for me to just back off. ❗
                              • faBcnF
                                faBcn
                                Hi there!
                                When dealing with kinematics, it's very useful to be able to graphically manage speeds instead of positions (slope of positions law)
                                I see that a lot of non-linear laws are availables during a movement, but as far I understand, it's only useful between 2 keyframes.
                                When dealing with more keyframes within a same general movement, I didn't manage to have some smooth transitions...
                                Here is a simple case:
                                Let's say we want to animate a car, constant speed (100km/h) between KF#1 and KF#2.
                                Then it decelerates between KF#2 and KF#3 so that it reaches another constant speed (50km/h) from KF#3 up to KF#4.
                                I didn't manage smooth transitions without generating some weird stuff...
                                Is there some kind of tricks using available non-linear laws?
                                • Rich O BrienR Rich O Brien pinned this topic on
                                • 4 / 4
