    [Plugin][$] ThruPaint - v2.9a - 21 Apr 26
    195 Posts 55 Posters 90.1k Views 55 Watching
    • JQLJ
      JQL
      Hi Fredo,
      I'm having an issue with Thrupaint where I can't use the gizmo to move textures around.
      Here's a gif:
      https://media.giphy.com/media/3yUT06FBclTVW1aHPw/giphy.gif
      www.casca.pt
      Visit us on facebook!
      • fredo6F
        Can you open the Ruby Console to see if there are errors
        • JQLJ
          JQL
          Nothing showing in the console
          www.casca.pt
          • fredo6F
            Does the Gizmo works on other faces?
              jkoll66
              I'm having an issue where the Paint Face toolbar won't load. I've attached a screenshot and the console log. Thanks in advance for any help.
              Console Log
              Screenshot
              • fredo6F
                I think you probably need to reboot your PC and tell me if this make it work.
                • JQLJ
                  JQL
                  Hi Fredo,
                  The gizmo works sometimes but not on others. I can't seem to find a pattern.
                  I also have an issue that I didn't have with the prior version of thrupaint.
                  When I try to paint a texture continually on surfaces I can't see the red/green axis anymore, as I used to be able with Thrupaint 1.
                  I notice that things are working, but that visual cue isn't there.
                  Thanks,
                  João
                  www.casca.pt
                  • fredo6F
                    With ThruPaint 2, the axes are now triggered when you are close to an edge. Otherwise, if you are in the middle of a face, the direction of axes is the one that the Paint Bucket would take.
                    • JQLJ
                      JQL
                      Even so, this is also very random. Sometimes I see it, but most of the times I don't. Do you think this might be related to dpi?
                      www.casca.pt
                      • fredo6F
                        Can you keep the Ruby console opened to check for errors.
                        • JQLJ
                          JQL
                          I will.
                          www.casca.pt
                          • JQLJ
                            JQL
                            I got one but things were actually working:
                            Error; #<TypeError; nil can't be coerced into Integer>
                            c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;1336;in `-'
                            c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;1336;in `handle_move'
                            c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;4200;in `onMouseMove'
                            www.casca.pt
                            • JQLJ
                              JQL
                              Hi Fredo, I'd like that the axis, that show up when you want to repaint a texture, would appear as they used to be in Thrupaint 1. Many times it's really difficult to paint a face by making the mouse pointer close to the correct edge. It might be hidden or in a position where it's hard to get right and Thrupaint one was perfect in this regard.
                              Do you think that would be possible to revert? Maybe give us the option again?
                              www.casca.pt
                              • fredo6F
                                The No-Axis option allows painting with UV direction taken from model axes (as the Paint Bucket tool), which is not possible with the old ThruPaint.
                                I can certainly introduce a Default Parameter setting to disable this behavior.
                                However, I don't understand why you have difficulty getting close to edges.
                                • JQLJ
                                  JQL
                                  It requires more accuracy and some times the edge is hidden. Before I would simply point to a face and when the gizmo was closer to a corner than the others the red and green axis immediately popped up. It was much faster and predictable.
                                  www.casca.pt
                                    jejo303
                                    Same problem for me. Any solution?
                                    • fredo6F
                                      Could you check that you have installed LibFredo6 v13.6.
                                        jejo303
                                        After rebooting it works! Thanks.
                                          rajab0v
                                          How to buy this plugin as im not able to use it now and I cant find the page for buying it
                                            al2430 Newcomers
                                            Hello,
                                            i cant Purchase License, have anybody the same issue?
                                            iam using the link in Sketchup while installed Thrupaint:
                                            SketchUcation | Cart
                                            (sketchucation.com)
                                            thanks.
                                            • 3 / 10
