    [Plugin][$] ThruPaint - v2.9a - 21 Apr 26
    195 Posts 55 Posters 79.7k Views 55 Watching
    • JQLJ
      JQL
      Hi Fredo,
      The gizmo works sometimes but not on others. I can't seem to find a pattern.
      I also have an issue that I didn't have with the prior version of thrupaint.
      When I try to paint a texture continually on surfaces I can't see the red/green axis anymore, as I used to be able with Thrupaint 1.
      I notice that things are working, but that visual cue isn't there.
      Thanks,
      João
      www.casca.pt
      Visit us on facebook!
      • fredo6F
        With ThruPaint 2, the axes are now triggered when you are close to an edge. Otherwise, if you are in the middle of a face, the direction of axes is the one that the Paint Bucket would take.
        • JQLJ
          JQL
          Even so, this is also very random. Sometimes I see it, but most of the times I don't. Do you think this might be related to dpi?
          www.casca.pt
          • fredo6F
            Can you keep the Ruby console opened to check for errors.
            • JQLJ
              JQL
              I will.
              www.casca.pt
              • JQLJ
                JQL
                I got one but things were actually working:
                Error; #<TypeError; nil can't be coerced into Integer>
                c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;1336;in `-'
                c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;1336;in `handle_move'
                c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;4200;in `onMouseMove'
                www.casca.pt
                • JQLJ
                  JQL
                  Hi Fredo, I'd like that the axis, that show up when you want to repaint a texture, would appear as they used to be in Thrupaint 1. Many times it's really difficult to paint a face by making the mouse pointer close to the correct edge. It might be hidden or in a position where it's hard to get right and Thrupaint one was perfect in this regard.
                  Do you think that would be possible to revert? Maybe give us the option again?
                  www.casca.pt
                  • fredo6F
                    The No-Axis option allows painting with UV direction taken from model axes (as the Paint Bucket tool), which is not possible with the old ThruPaint.
                    I can certainly introduce a Default Parameter setting to disable this behavior.
                    However, I don't understand why you have difficulty getting close to edges.
                    • JQLJ
                      JQL
                      It requires more accuracy and some times the edge is hidden. Before I would simply point to a face and when the gizmo was closer to a corner than the others the red and green axis immediately popped up. It was much faster and predictable.
                      www.casca.pt
                        jejo303
                        @jkoll66 said:
                        I'm having an issue where the Paint Face toolbar won't load. I've attached a screenshot and the console log. Thanks in advance for any help.
                        Same problem for me. Any solution?
                        • fredo6F
                          Could you check that you have installed LibFredo6 v13.6.
                            jejo303
                            After rebooting it works! Thanks.
                              rajab0v
                              How to buy this plugin as im not able to use it now and I cant find the page for buying it
                                al2430 Newcomers
                                Hello,
                                i cant Purchase License, have anybody the same issue?
                                iam using the link in Sketchup while installed Thrupaint:
                                SketchUcation | Cart
                                (sketchucation.com)
                                thanks.
                                  al2430 Newcomers
                                  @rajab0v said:
                                  How to buy this plugin as im not able to use it now and I can't find the page for buying it, when I go to obtain license, it says on page: ERROR: Unknown plugin identifyer.
                                  I have the same issue. Please Help.
                                  • fredo6F
                                    ThruPaint is free for the time being. NO license needed.
                                    However, make sure you upgrade to the latest version of LibFredo6.
                                      al2430 Newcomers
                                      i have upgradet LibFredo6 and Thrupaint. It seems that they changed it and now it cost money. Her a picture with the License. But however it doesnt work with Purchase License..
                                      • fredo6F
                                        Could you migrate to LibFredo6 v13.8a.
                                        I normally fixed the problem.
                                        Sorry for inconvenience.
                                        • K
                                          km1035
                                          Hello
                                          When I press the buy button, I get this link
                                          is the link correct?
                                          https://sketchucation.com/purchase-smart.php?plugin=ThruPaint
                                          • fredo6F
                                            @km1035 said:
                                            Hello
                                            Could you upgrade to LibFredo6 v13.9a. This has been fixed.
                                            • 4 / 10
