    [Plugin][$] ThruPaint - v2.9a - 21 Apr 26
    195 Posts 55 Posters 90.1k Views 55 Watching
    • fredo6F
      @jsinmichael said:
      This is a great tool. Thank you. Any chance of being able to pick colors from the default "Materials" color wheel or incorporate one of your own? Will the color picker only select color from the canvas?
      Normally, if you create a material in the Sketchup native material browser, it should appear in the ThruPaint browser under the Model tab.
      This is why ThruPaint has not material creation and edition capability.
      • N
        NadinA2022
        Good afternoon, I faced a problem: when start the plugin, the button lights up in blue, saying that the plugin is active, but the window for working as usual does not appear, how to fix it?Thanks.
        • kdewinterK
          kdewinter
          Any update to have NCS colors implemented?
          • fredo6F
            NCS is included.
            kdewinterK 1 Reply Last reply
            • JQLJ
              JQL
              Hi Fredo,
              I'm having an issue with Thrupaint where I can't use the gizmo to move textures around.
              Here's a gif:
              https://media.giphy.com/media/3yUT06FBclTVW1aHPw/giphy.gif
              www.casca.pt
              Visit us on facebook!
              • fredo6F
                Can you open the Ruby Console to see if there are errors
                • JQLJ
                  JQL
                  Nothing showing in the console
                  www.casca.pt
                  • fredo6F
                    Does the Gizmo works on other faces?
                      jkoll66
                      I'm having an issue where the Paint Face toolbar won't load. I've attached a screenshot and the console log. Thanks in advance for any help.
                      Console Log
                      Screenshot
                      • fredo6F
                        I think you probably need to reboot your PC and tell me if this make it work.
                        • JQLJ
                          JQL
                          Hi Fredo,
                          The gizmo works sometimes but not on others. I can't seem to find a pattern.
                          I also have an issue that I didn't have with the prior version of thrupaint.
                          When I try to paint a texture continually on surfaces I can't see the red/green axis anymore, as I used to be able with Thrupaint 1.
                          I notice that things are working, but that visual cue isn't there.
                          Thanks,
                          JoĂŁo
                          www.casca.pt
                          • fredo6F
                            With ThruPaint 2, the axes are now triggered when you are close to an edge. Otherwise, if you are in the middle of a face, the direction of axes is the one that the Paint Bucket would take.
                            • JQLJ
                              JQL
                              Even so, this is also very random. Sometimes I see it, but most of the times I don't. Do you think this might be related to dpi?
                              www.casca.pt
                              • fredo6F
                                Can you keep the Ruby console opened to check for errors.
                                • JQLJ
                                  JQL
                                  I will.
                                  www.casca.pt
                                  • JQLJ
                                    JQL
                                    I got one but things were actually working:
                                    Error; #<TypeError; nil can't be coerced into Integer>
                                    c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;1336;in `-'
                                    c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;1336;in `handle_move'
                                    c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;4200;in `onMouseMove'
                                    www.casca.pt
                                    • JQLJ
                                      JQL
                                      Hi Fredo, I'd like that the axis, that show up when you want to repaint a texture, would appear as they used to be in Thrupaint 1. Many times it's really difficult to paint a face by making the mouse pointer close to the correct edge. It might be hidden or in a position where it's hard to get right and Thrupaint one was perfect in this regard.
                                      Do you think that would be possible to revert? Maybe give us the option again?
                                      www.casca.pt
                                      • fredo6F
                                        The No-Axis option allows painting with UV direction taken from model axes (as the Paint Bucket tool), which is not possible with the old ThruPaint.
                                        I can certainly introduce a Default Parameter setting to disable this behavior.
                                        However, I don't understand why you have difficulty getting close to edges.
                                        • JQLJ
                                          JQL
                                          It requires more accuracy and some times the edge is hidden. Before I would simply point to a face and when the gizmo was closer to a corner than the others the red and green axis immediately popped up. It was much faster and predictable.
                                          www.casca.pt
                                            jejo303
                                            Same problem for me. Any solution?
