    [Plugin][$] ThruPaint - v2.9a - 21 Apr 26
    188 Posts 53 Posters 45.6k Views 53 Watching
      Grey24601
      Hi Fredo,
      I love this tool and couldn't work without it. However, it takes a very long time to load the materials. Is there a way to speed it up or revert back to the old way using the Sketchup selected material?
        jsinmichael
        This is a great tool. Thank you. Any chance of being able to pick colors from the default "Materials" color wheel or incorporate one of your own? Will the color picker only select color from the canvas?
        J
        • fredo6F Offline
          Normally, if you create a material in the Sketchup native material browser, it should appear in the ThruPaint browser under the Model tab.
          This is why ThruPaint has not material creation and edition capability.
          • N Offline
            NadinA2022
            Good afternoon, I faced a problem: when start the plugin, the button lights up in blue, saying that the plugin is active, but the window for working as usual does not appear, how to fix it?Thanks.
            • kdewinterK Offline
              kdewinter
              Any update to have NCS colors implemented?
              • fredo6F Offline
                NCS is included.
                kdewinterK 1 Reply Last reply Reply Quote 0
                • JQLJ Offline
                  JQL
                  Hi Fredo,
                  I'm having an issue with Thrupaint where I can't use the gizmo to move textures around.
                  Here's a gif:
                  https://media.giphy.com/media/3yUT06FBclTVW1aHPw/giphy.gif
                  www.casca.pt
                  Visit us on facebook!
                  • fredo6F Offline
                    Can you open the Ruby Console to see if there are errors
                    • JQLJ Offline
                      JQL
                      Nothing showing in the console
                      www.casca.pt
                      • fredo6F Offline
                        Does the Gizmo works on other faces?
                          jkoll66
                          I'm having an issue where the Paint Face toolbar won't load. I've attached a screenshot and the console log. Thanks in advance for any help.
                          Console Log
                          Screenshot
                          • fredo6F Offline
                            I think you probably need to reboot your PC and tell me if this make it work.
                            • JQLJ Offline
                              JQL
                              Hi Fredo,
                              The gizmo works sometimes but not on others. I can't seem to find a pattern.
                              I also have an issue that I didn't have with the prior version of thrupaint.
                              When I try to paint a texture continually on surfaces I can't see the red/green axis anymore, as I used to be able with Thrupaint 1.
                              I notice that things are working, but that visual cue isn't there.
                              Thanks,
                              JoĂŁo
                              www.casca.pt
                              • fredo6F Offline
                                With ThruPaint 2, the axes are now triggered when you are close to an edge. Otherwise, if you are in the middle of a face, the direction of axes is the one that the Paint Bucket would take.
                                • JQLJ Offline
                                  JQL
                                  Even so, this is also very random. Sometimes I see it, but most of the times I don't. Do you think this might be related to dpi?
                                  www.casca.pt
                                  • fredo6F Offline
                                    Can you keep the Ruby console opened to check for errors.
                                    • JQLJ Offline
                                      JQL
                                      I will.
                                      www.casca.pt
                                      • JQLJ Offline
                                        JQL
                                        I got one but things were actually working:
                                        Error; #<TypeError; nil can't be coerced into Integer>
                                        c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;1336;in `-'
                                        c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;1336;in `handle_move'
                                        c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;4200;in `onMouseMove'
                                        www.casca.pt
                                        • JQLJ Offline
                                          JQL
                                          Hi Fredo, I'd like that the axis, that show up when you want to repaint a texture, would appear as they used to be in Thrupaint 1. Many times it's really difficult to paint a face by making the mouse pointer close to the correct edge. It might be hidden or in a position where it's hard to get right and Thrupaint one was perfect in this regard.
                                          Do you think that would be possible to revert? Maybe give us the option again?
                                          www.casca.pt
                                          • fredo6F Offline
                                            The No-Axis option allows painting with UV direction taken from model axes (as the Paint Bucket tool), which is not possible with the old ThruPaint.
                                            I can certainly introduce a Default Parameter setting to disable this behavior.
                                            However, I don't understand why you have difficulty getting close to edges.
                                            • 3 / 10
