    [Plugin][$] ThruPaint - v2.9a - 21 Apr 26
    195 Posts 55 Posters 79.7k Views 55 Watching
      markcavey
      Not sure why i'm now getting this error
        Martuszka001
        Hi! I have a problem with the new version of ThruPaint. It doesn't work.
        I updated LibFredo6 to v13.4a, Sketchucation ExtensionStore to v4.2.9 and still shows me that "the version of ThruPaint v2.1b has expired. Please upgrade to the latest version."
        Whan can I do with that?
        • N
          NadinA2022
          I can`t start the plagin from today 31.10.2022. It asks to upgrade? but its up to date.
          Whats the problem may be and How fix it. Thanks.
          • fredo6F
            NEW RELEASE: ThruPaint v2.2a - 31 Oct 22
            ThruPaint 2.2a is for extension of validity.
            Home Page of ThruPaint for information and Download.
            Main post of this thread.
            • G
              Grey24601
              Hi Fredo,
              I love this tool and couldn't work without it. However, it takes a very long time to load the materials. Is there a way to speed it up or revert back to the old way using the Sketchup selected material?
                jsinmichael
                This is a great tool. Thank you. Any chance of being able to pick colors from the default "Materials" color wheel or incorporate one of your own? Will the color picker only select color from the canvas?
                J
                • fredo6F
                  Normally, if you create a material in the Sketchup native material browser, it should appear in the ThruPaint browser under the Model tab.
                  This is why ThruPaint has not material creation and edition capability.
                  • N
                    NadinA2022
                    Good afternoon, I faced a problem: when start the plugin, the button lights up in blue, saying that the plugin is active, but the window for working as usual does not appear, how to fix it?Thanks.
                    • kdewinterK
                      kdewinter
                      Any update to have NCS colors implemented?
                      • fredo6F
                        NCS is included.
                        kdewinterK 1 Reply Last reply
                        • JQLJ
                          JQL
                          Hi Fredo,
                          I'm having an issue with Thrupaint where I can't use the gizmo to move textures around.
                          Here's a gif:
                          https://media.giphy.com/media/3yUT06FBclTVW1aHPw/giphy.gif
                          www.casca.pt
                          Visit us on facebook!
                          • fredo6F
                            Can you open the Ruby Console to see if there are errors
                            • JQLJ
                              JQL
                              Nothing showing in the console
                              www.casca.pt
                              • fredo6F
                                Does the Gizmo works on other faces?
                                  jkoll66
                                  I'm having an issue where the Paint Face toolbar won't load. I've attached a screenshot and the console log. Thanks in advance for any help.
                                  Console Log
                                  Screenshot
                                  • fredo6F
                                    I think you probably need to reboot your PC and tell me if this make it work.
                                    • JQLJ
                                      JQL
                                      Hi Fredo,
                                      The gizmo works sometimes but not on others. I can't seem to find a pattern.
                                      I also have an issue that I didn't have with the prior version of thrupaint.
                                      When I try to paint a texture continually on surfaces I can't see the red/green axis anymore, as I used to be able with Thrupaint 1.
                                      I notice that things are working, but that visual cue isn't there.
                                      Thanks,
                                      João
                                      www.casca.pt
                                      • fredo6F
                                        With ThruPaint 2, the axes are now triggered when you are close to an edge. Otherwise, if you are in the middle of a face, the direction of axes is the one that the Paint Bucket would take.
                                        • JQLJ
                                          JQL
                                          Even so, this is also very random. Sometimes I see it, but most of the times I don't. Do you think this might be related to dpi?
                                          www.casca.pt
                                          • fredo6F
                                            Can you keep the Ruby console opened to check for errors.
                                            • 3 / 10
