    Catamaran
    156 Posts 12 Posters 20.0k Views 12 Watching
    • Bryan KB Offline
      How I'm preparing the hull for skinning.
      • Bryan KB Offline
        Sigh.
        Crazy busy with the day job the last two weeks and no end in sight. That's why I've just been doing easy renders.
        I'm getting impatient to get back to this.
        • Bryan KB Offline
          How I'm doing this:
          I made three copies. The first one on the right is my baseline. As I make corrections, it becomes the new baseline and replaces the previous model.
          The middle one is where I make corrections, based on:
          The one on the far left where I test and find the problems.
          Current issues are getting the bulkhead heights to line up exactly with the hull profile.
          I intend to use Soap Bubble or Curviloft to skin the hull. At worst, hand connect all the lines to make the hull surface, like I did with the Nadesico.
          • Bryan KB Offline
            Yep. Non-connected lines and endpoint alignments were the problem.
            I ended up using Curviloft for each compartment.
            After making sure the bulkheads were the exact height of the corresponding point on the hull profile, I erased the hull profile lines between each compartment one at a time and made a new line to ensure the endpoints were connected, then used Curviloft to skin. One section at a time.
            The bow was tricky and required a lot of small arcs for Curviloft work. The tail still needs some fiddling, but it's nothing major at this point. I'll fix it pretty quickly.
            The hull curve is not perfect, but if you didn't know, you can't tell. I'm good with this.... this time.
            • Bryan KB Offline
              Oops. Forget the main shot.
              • tuna1957T Offline
                tuna1957
                Looking good so far πŸ‘ πŸ‘
                • Bryan KB Offline
                  Thanks tuna!
                  • Bryan KB Offline
                    Aft fixed. It looks a little off because of the visible lines, but it is correct. (later edit: it was not ) I have not ungrouped the Curviloft sections yet, but when they are ungrouped and merged, it will look better. I will wait until I am absolutely sure it is correct. I'm only 98% sure at the moment.
                    On to the main cabin in the meantime.
                    • ntxdaveN Offline
                      ntxdave
                      Coming along nicely. πŸ‘
                      Press F1...thank me later
                      • Bryan KB Offline
                        • Bryan KB Offline
                          Resetting my workflow.
                            Definitely proceeding nicely mate. πŸ‘
                            • Bryan KB Offline
                              • Bryan KB Offline
                                OK, going to check all lines before I got further.
                                • Bryan KB Offline
                                  Stern fixed! (again it was not ) Took some fiddling and finessing even with Curviloft.
                                  • Bryan KB Offline
                                    And dang it, it's still off by just a hair.
                                    But I see how to fix it.
                                    • Bryan KB Offline
                                      Fixed. The curve and slope are now correct
                                      • marked001M Offline
                                        marked001
                                        Nice..this is coming along!
                                        http://www.revision21vis.com
                                        instagram: revi21on
                                        • Bryan KB Offline
                                          Thanks marked001.
                                          I've been a little under the weather, so I've just been doing easy renders. Can't focus on the hard stuff right now.
                                          The weather swings in my region are making me... groggy? We are seeing 40F swings in very short periods.
                                          • ntxdaveN Offline
                                            ntxdave
                                            Yep, one day you need a parka and the next you need a t-shirt πŸ˜„
                                            • 2 / 8
