    Catamaran
    156 Posts 12 Posters 32.6k Views 12 Watching
    • Bryan KB Offline
      Thanks tuna!
      • Bryan KB Offline
        Aft fixed. It looks a little off because of the visible lines, but it is correct. (later edit: it was not ) I have not ungrouped the Curviloft sections yet, but when they are ungrouped and merged, it will look better. I will wait until I am absolutely sure it is correct. I'm only 98% sure at the moment.
        On to the main cabin in the meantime.
        • ntxdaveN Offline
          ntxdave
          Coming along nicely. πŸ‘
          Press F1...thank me later
          • Bryan KB Offline
            • Bryan KB Offline
              Resetting my workflow.
                Definitely proceeding nicely mate. πŸ‘
                • Bryan KB Offline
                  • Bryan KB Offline
                    OK, going to check all lines before I got further.
                    • Bryan KB Offline
                      Stern fixed! (again it was not ) Took some fiddling and finessing even with Curviloft.
                      • Bryan KB Offline
                        And dang it, it's still off by just a hair.
                        But I see how to fix it.
                        • Bryan KB Offline
                          Fixed. The curve and slope are now correct
                          • marked001M Offline
                            marked001
                            Nice..this is coming along!
                            http://www.revision21vis.com
                            instagram: revi21on
                            • Bryan KB Offline
                              Thanks marked001.
                              I've been a little under the weather, so I've just been doing easy renders. Can't focus on the hard stuff right now.
                              The weather swings in my region are making me... groggy? We are seeing 40F swings in very short periods.
                              • ntxdaveN Offline
                                ntxdave
                                Yep, one day you need a parka and the next you need a t-shirt πŸ˜„
                                • tuna1957T Offline
                                  tuna1957
                                  Excellent progress πŸ‘ πŸ‘
                                  Side note…. I get the feel bads from the weather swings also. It’s been jumping around pretty bad lately here in north Texas
                                  • Bryan KB Offline
                                    Thanks tuna. πŸ‘
                                    Yeah, it's too much for me.
                                    Anyway, roughing in the lower central deck hull. Next step will be to rough-in the aft deck.
                                    • Bryan KB Offline
                                      Roughing in the aft deck. I will be taking some liberties with the aft deck as I do not have very good references of it.
                                        Looking great Bryan, nice progress. πŸ‘
                                        • Bryan KB Offline
                                          Thanks Mike!
                                          • Bryan KB Offline
                                            I had to rebuild all of the middle cabin deck. The end points did line up with the hull contact points on the first build. Why, I have no idea. But it is all tight and correct now.
                                            I also had the lower deck profile wrong. Now fixed as well.
                                            I have a better handle on the aft deck as well.
                                            The windows on the front were not easy, even with tools on surface. It took me several hours figuring out how to get the curve to line up with the side windows.
                                            This is proving as challenging as the Nadesico. Still going faster, though. Much fiddling and cursing, but going faster. πŸ˜†
                                            • 3 / 8
