    Catamaran
    156 Posts 12 Posters 12.1k Views 12 Watching
    • Bryan KB Offline
      Going to be a lot of adjusting before I skin. The hull profile slopes from the top middle down to the ends.
      I had to pick this one, didn't I? πŸ˜† Oh well, it will look more interesting this way.
        Following with great interest πŸ‘
        • Bryan KB Offline
          Most of the bulkheads placed and now to just refine their profiles and set up the final aft bulkhead, then find the true hull curve.
          • tuna1957T Offline
            tuna1957
            Great progress πŸ‘ Boats can be a real pain to model…..
            • Bryan KB Offline
              Gonna hold off for a while. Local weather has had 30 degree (F, 15 degrees C) swings over the last few days and my head hurts.
              • Bryan KB Offline
                How I'm preparing the hull for skinning.
                • Bryan KB Offline
                  Sigh.
                  Crazy busy with the day job the last two weeks and no end in sight. That's why I've just been doing easy renders.
                  I'm getting impatient to get back to this.
                  • Bryan KB Offline
                    How I'm doing this:
                    I made three copies. The first one on the right is my baseline. As I make corrections, it becomes the new baseline and replaces the previous model.
                    The middle one is where I make corrections, based on:
                    The one on the far left where I test and find the problems.
                    Current issues are getting the bulkhead heights to line up exactly with the hull profile.
                    I intend to use Soap Bubble or Curviloft to skin the hull. At worst, hand connect all the lines to make the hull surface, like I did with the Nadesico.
                    • Bryan KB Offline
                      Yep. Non-connected lines and endpoint alignments were the problem.
                      I ended up using Curviloft for each compartment.
                      After making sure the bulkheads were the exact height of the corresponding point on the hull profile, I erased the hull profile lines between each compartment one at a time and made a new line to ensure the endpoints were connected, then used Curviloft to skin. One section at a time.
                      The bow was tricky and required a lot of small arcs for Curviloft work. The tail still needs some fiddling, but it's nothing major at this point. I'll fix it pretty quickly.
                      The hull curve is not perfect, but if you didn't know, you can't tell. I'm good with this.... this time.
                      • Bryan KB Offline
                        Oops. Forget the main shot.
                        • tuna1957T Offline
                          tuna1957
                          Looking good so far πŸ‘ πŸ‘
                          • Bryan KB Offline
                            Thanks tuna!
                            • Bryan KB Offline
                              Aft fixed. It looks a little off because of the visible lines, but it is correct. (later edit: it was not ) I have not ungrouped the Curviloft sections yet, but when they are ungrouped and merged, it will look better. I will wait until I am absolutely sure it is correct. I'm only 98% sure at the moment.
                              On to the main cabin in the meantime.
                              • ntxdaveN Offline
                                ntxdave
                                Coming along nicely. πŸ‘
                                • Bryan KB Offline
                                  • Bryan KB Offline
                                    Resetting my workflow.
                                      Definitely proceeding nicely mate. πŸ‘
                                      • Bryan KB Offline
                                        • Bryan KB Offline
                                          OK, going to check all lines before I got further.
                                          • Bryan KB Offline
                                            Stern fixed! (again it was not ) Took some fiddling and finessing even with Curviloft.
                                            • 2 / 8
