    Catamaran
    156 Posts 12 Posters 32.6k Views 12 Watching
    • Bryan KB Offline
      Yep. Non-connected lines and endpoint alignments were the problem.
      I ended up using Curviloft for each compartment.
      After making sure the bulkheads were the exact height of the corresponding point on the hull profile, I erased the hull profile lines between each compartment one at a time and made a new line to ensure the endpoints were connected, then used Curviloft to skin. One section at a time.
      The bow was tricky and required a lot of small arcs for Curviloft work. The tail still needs some fiddling, but it's nothing major at this point. I'll fix it pretty quickly.
      The hull curve is not perfect, but if you didn't know, you can't tell. I'm good with this.... this time.
      • Bryan KB Offline
        Oops. Forget the main shot.
        • tuna1957T Offline
          tuna1957
          Looking good so far πŸ‘ πŸ‘
          • Bryan KB Offline
            Thanks tuna!
            • Bryan KB Offline
              Aft fixed. It looks a little off because of the visible lines, but it is correct. (later edit: it was not ) I have not ungrouped the Curviloft sections yet, but when they are ungrouped and merged, it will look better. I will wait until I am absolutely sure it is correct. I'm only 98% sure at the moment.
              On to the main cabin in the meantime.
              • ntxdaveN Offline
                ntxdave
                Coming along nicely. πŸ‘
                Press F1...thank me later
                • Bryan KB Offline
                  • Bryan KB Offline
                    Resetting my workflow.
                      Definitely proceeding nicely mate. πŸ‘
                      • Bryan KB Offline
                        • Bryan KB Offline
                          OK, going to check all lines before I got further.
                          • Bryan KB Offline
                            Stern fixed! (again it was not ) Took some fiddling and finessing even with Curviloft.
                            • Bryan KB Offline
                              And dang it, it's still off by just a hair.
                              But I see how to fix it.
                              • Bryan KB Offline
                                Fixed. The curve and slope are now correct
                                • marked001M Offline
                                  marked001
                                  Nice..this is coming along!
                                  http://www.revision21vis.com
                                  instagram: revi21on
                                  • Bryan KB Offline
                                    Thanks marked001.
                                    I've been a little under the weather, so I've just been doing easy renders. Can't focus on the hard stuff right now.
                                    The weather swings in my region are making me... groggy? We are seeing 40F swings in very short periods.
                                    • ntxdaveN Offline
                                      ntxdave
                                      Yep, one day you need a parka and the next you need a t-shirt πŸ˜„
                                      • tuna1957T Offline
                                        tuna1957
                                        Excellent progress πŸ‘ πŸ‘
                                        Side note…. I get the feel bads from the weather swings also. It’s been jumping around pretty bad lately here in north Texas
                                        • Bryan KB Offline
                                          Thanks tuna. πŸ‘
                                          Yeah, it's too much for me.
                                          Anyway, roughing in the lower central deck hull. Next step will be to rough-in the aft deck.
                                          • Bryan KB Offline
                                            Roughing in the aft deck. I will be taking some liberties with the aft deck as I do not have very good references of it.
                                            • 2 / 8
