    Catamaran
    156 Posts 12 Posters 22.3k Views 12 Watching
    • Bryan KB Offline
      Resetting my workflow.
        Definitely proceeding nicely mate. πŸ‘
        • Bryan KB Offline
          • Bryan KB Offline
            OK, going to check all lines before I got further.
            • Bryan KB Offline
              Stern fixed! (again it was not ) Took some fiddling and finessing even with Curviloft.
              • Bryan KB Offline
                And dang it, it's still off by just a hair.
                But I see how to fix it.
                • Bryan KB Offline
                  Fixed. The curve and slope are now correct
                  • marked001M Offline
                    marked001
                    Nice..this is coming along!
                    http://www.revision21vis.com
                    instagram: revi21on
                    • Bryan KB Offline
                      Thanks marked001.
                      I've been a little under the weather, so I've just been doing easy renders. Can't focus on the hard stuff right now.
                      The weather swings in my region are making me... groggy? We are seeing 40F swings in very short periods.
                      • ntxdaveN Offline
                        ntxdave
                        Yep, one day you need a parka and the next you need a t-shirt πŸ˜„
                        Press F1...thank me later
                        • tuna1957T Offline
                          tuna1957
                          Excellent progress πŸ‘ πŸ‘
                          Side note…. I get the feel bads from the weather swings also. It’s been jumping around pretty bad lately here in north Texas
                          • Bryan KB Offline
                            Thanks tuna. πŸ‘
                            Yeah, it's too much for me.
                            Anyway, roughing in the lower central deck hull. Next step will be to rough-in the aft deck.
                            • Bryan KB Offline
                              Roughing in the aft deck. I will be taking some liberties with the aft deck as I do not have very good references of it.
                                Looking great Bryan, nice progress. πŸ‘
                                • Bryan KB Offline
                                  Thanks Mike!
                                  • Bryan KB Offline
                                    I had to rebuild all of the middle cabin deck. The end points did line up with the hull contact points on the first build. Why, I have no idea. But it is all tight and correct now.
                                    I also had the lower deck profile wrong. Now fixed as well.
                                    I have a better handle on the aft deck as well.
                                    The windows on the front were not easy, even with tools on surface. It took me several hours figuring out how to get the curve to line up with the side windows.
                                    This is proving as challenging as the Nadesico. Still going faster, though. Much fiddling and cursing, but going faster. πŸ˜†
                                    • Bryan KB Offline
                                      Experimenting with the aft deck cover. It's close but not right.
                                      • Bryan KB Offline
                                        Close enough. Lots of Curviloft and Tools On Surface and Joint Push Pull. ...and fiddling and cursing
                                        JPP mangled some of the inside geometry, but I'm going with it as you can't really see it on the underside of the roof except as slightly thick lines and not at all if I turns lines off. I'll do better on the next one.
                                          I was watching a travel documentry the other day and I saw a craft that looked very familiar to me. It was the craft you are building. A beutifull craft indeed πŸ‘
                                          • Bryan KB Offline
                                            Thanks L I am.
                                            I'm still not quite satisfied with with the aft deck cover and thinking about the geometry tells me it really is not right yet.
                                            • 3 / 8
