[Plugin] QuadFaceTools
@rv1974 said:
hmm its strange why TT turned off this icon
As far as I remenber, this was intentional, because that's a bit of a beta/buggy tools and you should "use at your own risk".
However, I have to say that I use it a lot as it is and that works perfect in 95% of cases for me. -
Hi thom!
Is it possible to have 4K screen compliant icons?
On my laptop it's nearly impossible to see the values of the connect edges tools window... -
Hi Tom, how are you?
Thanks for your help as always.
I want to show you some examples of meshes that I use.
I never manage to convert them completely to quadface.
I don't know if I'm doing something wrong.
Or is there some way to do it completely.
When there are many meshes, it is a very laborious job.
Thank you.
Looks like your mesh was generated with SSB. The border polygon's is too much to ask QFT.
QFT expects a certain mesh input. SSB doesn't generated a compliant mesh. More planning, or manual fixing, is needed on your end I'm afraid.
@thomthom said:
I'm not sure what I'm looking at there...
I sounds like this is an issue that relate particularly to rizomUV. Though I can't really tell exactly what is going on. But I can verify that QFT exports OBJs in such a manner that the faces share vertices.
If you could find out more what is happening on the rizomUV side then I could look into whether there are some tweaks that can be done on the side of QFT.Perhaps, do you have a model where exported from another app into OBJ works fine for rizomUV - but doesn't work when exported from QFT?
You have done a good export to obj format, but it is not perfect, it needs some work...
https://youtu.be/MkuSQ3oERcg
Youtube Video -
Hello Thom
I have a bug I think.
When I try to remove loops QFT leaves hidden vertex that produces unwanted ngons when Subded.
The last couple of times I've used this plugin I have been unable to key in numbers using the Connect Edges Tool. It had worked perfectly until recently, so I'm not sure what to do. It is stuck on 2/0 respectively. I have uninstalled and reinstalled the plugin, and have made sure my Sketchup and Windows are up to date. I'm using Sketchup Pro 21.1.332 64 Bit. Any help would be appreciated, as I use this function often in my workflow.
Just click in the input box then type
can someone help me please im having this error on quad face tools plugin sketchup pro 2019 C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_Lib2/debug.rb:36:in
debug' C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/core.rb:1866:in
selection_grow'
C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/core.rb:124:inblock in <module:QuadFaceTools>' C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/command.rb:25:in
block in new'
C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_Lib2/debug.rb:36:indebug' C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/core.rb:1902:in
selection_shrink'
C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/core.rb:132:inblock in <module:QuadFaceTools>' C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/command.rb:25:in
block in new'
2019/SketchUp/Plugins/TT_Lib2/debug.rb:36:indebug' C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/core.rb:1704:in
select_rings'
C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/core.rb:140:inblock in <module:QuadFaceTools>' C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/command.rb:25:in
block in new'
select_rings'
block in new'
please how do I fix this -
The first culprit would be update TTlib to the latest version.
You can do it via Extension Manager & update or via Sketchucation Tools, update on th small icon above.
Next would be update of QFT itself. If there's no update sign, try to force the update and see if you still have the error after close and reload SU.Sometimes I have this kind of error when I launch SU too soon after the PC boot. Just wait 1-2 min after the boot and fire SU. I guess some background routines need to be loaded and in place before launching SU as the plugins rely on these routines?
Hello Thomthom
Just an idea for the LINE tool of QFT:
Is it possible to have a LINE tool that always generate quads with NORMALS unified towards the camera?
I don't know how you define the normal orientation for generating quads when you close a quad surface with the line tool. Usually it's pinpoint but sometimes I get reversed normals and with complex mesh the Su genuine "orient surfaces" tool fails. -
I downloaded Quadface and it show's up in my manager but not in the SketchUp homepage what am i missing?
Install TTLib too its a dependency library used by many on Thom's stuff.
