    [Plugin] QuadFaceTools
    680 Posts 116 Posters 713.8k Views 116 Watching
      rv1974
      hmm its strange why TT turned off this icon
      • panixiaP Offline
        panixia
        As far as I remenber, this was intentional, because that's a bit of a beta/buggy tools and you should "use at your own risk".
        However, I have to say that I use it a lot as it is and that works perfect in 95% of cases for me.
        • O Offline
          optimaforever
          Hi thom!
          Is it possible to have 4K screen compliant icons?
          On my laptop it's nearly impossible to see the values of the connect edges tools window...
            chapalee
            Hi Tom, how are you?
            Thanks for your help as always.
            I want to show you some examples of meshes that I use.
            I never manage to convert them completely to quadface.
            I don't know if I'm doing something wrong.
            Or is there some way to do it completely.
            When there are many meshes, it is a very laborious job.
            Thank you.
            Convert.skp
              Looks like your mesh was generated with SSB. The border polygon's is too much to ask QFT.
              QFT expects a certain mesh input. SSB doesn't generated a compliant mesh. More planning, or manual fixing, is needed on your end I'm afraid.
              • V Offline
                Vizan
                @thomthom said:
                I'm not sure what I'm looking at there...
                I sounds like this is an issue that relate particularly to rizomUV. Though I can't really tell exactly what is going on. But I can verify that QFT exports OBJs in such a manner that the faces share vertices.
                If you could find out more what is happening on the rizomUV side then I could look into whether there are some tweaks that can be done on the side of QFT.
                Perhaps, do you have a model where exported from another app into OBJ works fine for rizomUV - but doesn't work when exported from QFT?
                You have done a good export to obj format, but it is not perfect, it needs some work...
                https://youtu.be/MkuSQ3oERcg
                https://youtu.be/-IMeyyvWEEc
                • O Offline
                  optimaforever
                  Hello Thom
                  I have a bug I think.
                  When I try to remove loops QFT leaves hidden vertex that produces unwanted ngons when Subded.
                    chrisprattguys
                    The last couple of times I've used this plugin I have been unable to key in numbers using the Connect Edges Tool. It had worked perfectly until recently, so I'm not sure what to do. It is stuck on 2/0 respectively. I have uninstalled and reinstalled the plugin, and have made sure my Sketchup and Windows are up to date. I'm using Sketchup Pro 21.1.332 64 Bit. Any help would be appreciated, as I use this function often in my workflow.
                      Just click in the input box then type
                        patricia108 Newcomers
                        can someone help me please im having this error on quad face tools plugin sketchup pro 2019 C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_Lib2/debug.rb:36:in debug' C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/core.rb:1866:in selection_grow'
                        C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/core.rb:124:in block in <module:QuadFaceTools>' C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/command.rb:25:in block in new'
                        C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_Lib2/debug.rb:36:in debug' C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/core.rb:1902:in selection_shrink'
                        C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/core.rb:132:in block in <module:QuadFaceTools>' C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/command.rb:25:in block in new'
                        2019/SketchUp/Plugins/TT_Lib2/debug.rb:36:in debug' C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/core.rb:1704:in select_rings'
                        C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/core.rb:140:in block in <module:QuadFaceTools>' C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_QuadFaceTools/command.rb:25:in block in new'
                        please how do I fix this 😢 😢 😢 😢
                        • O Offline
                          optimaforever
                          The first culprit would be update TTlib to the latest version.
                          You can do it via Extension Manager & update or via Sketchucation Tools, update on th small icon above.
                          Next would be update of QFT itself. If there's no update sign, try to force the update and see if you still have the error after close and reload SU.
                          Sometimes I have this kind of error when I launch SU too soon after the PC boot. Just wait 1-2 min after the boot and fire SU. I guess some background routines need to be loaded and in place before launching SU as the plugins rely on these routines?
                          • O Offline
                            optimaforever
                            Hello Thomthom
                            Just an idea for the LINE tool of QFT:
                            Is it possible to have a LINE tool that always generate quads with NORMALS unified towards the camera?
                            I don't know how you define the normal orientation for generating quads when you close a quad surface with the line tool. Usually it's pinpoint but sometimes I get reversed normals and with complex mesh the Su genuine "orient surfaces" tool fails.
                              maxnathan Newcomers
                              I downloaded Quadface and it show's up in my manager but not in the SketchUp homepage what am i missing?
                                Install TTLib too its a dependency library used by many on Thom's stuff.
                                • alsomarA Offline
                                  alsomar Extension Creator
                                  I think I've figured out what is wrong with the OBJ files generated by the OBJ Exporter from QFT and why sometimes they don't work properly in other software such as RizomUV or Substance Painter.
                                  I have reported this issue on the GitHub page for QFT, but I believe it could be helpful to someone if I also post it here, especially since a solution to the problem is provided at the end of the post.
                                  I've been struggling with this issue for quite some time, but since I didn't fully understand what was happening, I couldn't provide useful feedback. Recently, however, I've been able to clearly identify the problem and even managed to resolve it using Meshlab, a free software to clean and improve 3D models.
                                  The Issue
                                  The OBJ files generated with the OBJ exporter from QuadFaceTools have duplicated faces in those quads that have been triangulated in SketchUp.
                                  When you open an OBJ file created with this exporter, software like Blender automatically resolves this issue. However, other software such as Substance Painter or RizomUV may struggle to handle these duplicates correctly.
                                  I believe this issue is the root cause of these issues:
                                  • https://github.com/thomthom/quadface-tools/issues/127
                                  • https://github.com/thomthom/quadface-tools/issues/124
                                  • https://github.com/thomthom/quadface-tools/issues/120
                                  Reproducing the Issue
                                  I created a simple SketchUp model with just two cubes:
                                  240622_skp_cubes
                                  Each cube have 24 quads. The triangulated one (on the left) is a component called 'cube_t', and the other one (on the right) is also a component called 'cube_q'. I exported them separately using the OBJ exporter from QFT to identify the problem, using the following settings:
                                  QFT_settings
                                  After exporting, I obtained these two files: cube_q.obj and cube_t.obj.
                                  Next, I used the free open-source software Meshlab to check the number of faces in each OBJ file. After opening Meshlab, navigate to File > Import Mesh and select cube_q.obj.
                                  For the first mesh ('0'), you can see there are 48 faces (24 front + 24 back), as expected. However, when I added cube_t.obj using File > Import Mesh, for the second mesh ('1'), there were 96 faces, TWICE (!) the expected number for the same number of quads.
                                  This issue causes Substance Painter to struggle with generating proper automated UVs, while RizomUV fails to correctly utilize OBJ files exported from QFT's OBJ exporter.
                                  Fixing these OBJ Files using Meshlab
                                  Until a potential solution is considered within QFT's OBJ exporter itself, here's a simple and practical solution using MeshLab:
                                  1. Select the problematic mesh from the Layer Dialog.
                                  2. Go to Filters > Cleaning and Repairing > Remove Duplicated Faces.
                                    Step 2 Screenshot
                                  3. After completing the previous step, verify that the number of faces in cube_t.obj is 48. If correct, proceed to File > Export Mesh and save the corrected file as new_cube_t.obj (or a similar name).
                                  If you try to open this corrected file in RizomUV or Substance Painter (using the auto-UV features), it should work smoothly.
                                  Alejandro Soriano Visuals · All my links
                                  panixiaP 1 Reply Last reply Reply Quote 0
                                  • panixiaP Offline
                                    panixia @alsomar
                                    @alsomar said in [Plugin] QuadFaceTools:
                                    Hi Alejandro, I have no problem at all in Substance with QFT obj files (I can even bake hipoly objs into low poly objs with no issue).
                                    BTW it's a known problem and has been there forever.
                                    There's also a problem with unwelded UV islands (the UV are in the right places but actually each quad has cuts/seams at all edges).
                                    I shared a few info and workarounds about this problem years ago, but unfortunately Thom is really busy and apparently doesn't have time to fix it for now, so we still have to use workarounds.
                                    @summerson1990 said: @pilou said: Why not export from Max only unwelded quads? (separated) I have found that it's probably best of all to export from max ...
                                    sketchucation (community.sketchucation.com)
                                    The workaround in 3dsMax I mentioned in that post is outdated.
                                    Now I just filter the selection for polygons with 3 sides (in the selection tab) and erase all of them.
                                    In some cases I also export from QFT to Blender and then export an FBX to 3dsMax.
                                    alsomarA 2 Replies Last reply Reply Quote 0
                                    • panixiaP panixia referenced this topic on
                                    • alsomarA Offline
                                      alsomar Extension Creator @panixia
                                      @panixia said in [Plugin] QuadFaceTools:
                                      It's not another problem; it's the same one. The triangulated quads in SketchUp are being exported with duplicated faces. These duplicated faces are the ones you see unwelded in RizomUV. Blender usually fixes this problem just by opening the OBJ files.
                                      • alsomarA Offline
                                        @panixia I made a fix for the OBJ export issue in QuadFace Tools and submitted a pull request to the main branch. You can find the RBZ file from my fork here:
                                        Release Version 1.0.0-1 (obj export fix) · alsomar/quadface-tools
                                        Suite of tools for manipulating quad faces in SketchUp. - Release Version 1.0.0-1 (obj export fix) · alsomar/quadface-tools
                                        GitHub (github.com)
                                        Hope it helps.
                                        panixiaP 1 Reply Last reply Reply Quote 1
                                        • panixiaP Offline
                                          panixia @alsomar
                                          @alsomar Thanks Alejandro, I'll try this as soon as possible.
                                          Where do you tested the fix?
                                          Rizom? 3dsMax?
                                          Which modules sre involved? The exporter_obj.rb only?
                                          I myself have a slightly "hacked" version of QFT (mainly to use png icons which are better on my laptop with Sketchup 2021 rather than the new svg ones) so I would probably prefer to merge only the strictly necessary modules.
                                          alsomarA 1 Reply Last reply Reply Quote 0
                                          • alsomarA Offline
                                            @panixia Tested with RizomUV and Substance Painter. Works fine on my side, no unwelded UV islands.
                                            The modified file is entities.rb. At the end of this file, there's a method called get_entity. You have to delete there these three lines (1729 - 1731):
                                            if add_to_cache && @types[ Sketchup::Face ][ entity ].nil?
                                                cache_entity( quad )
                                            And replace them with this one:
                                            cache_entity( quad ) if add_to_cache
                                            Here's the full explanation why this works:
                                            https://github.com/thomthom/quadface-tools/pull/135
                                            panixiaP 2 Replies Last reply Reply Quote 0
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 34 / 34
