    More Fredo6 plugins becoming paid extensions
    165 Posts 56 Posters 82.0k Views 56 Watching
      jsinmichael
      Is there a reason that RoundCorner is included in the bundle instead of FredoCorner? While RoundCorner still works, it hasn't been updated in 4 years. Is this at risk of becoming "legacy".
      Thanks,
      J
      • fredo6F Offline
        RoundCorner is not legacy. Simply, it uses a different algorithm compared with FredoCorner.
          JohnButler222
          If someone provides something for free and then at a later date says to you that you need to pay for what was given for free, I would suspect that person might also assure you it's a one off purchase and then at a later date change their mind again and demand regular subscription payments.
            @johnbutler222 said:
            ...I would suspect that person might also assure you it's a one off purchase and then at a later date change their mind again and demand regular subscription payments.
            They might do so. The might not. If that's what you expect will happen you could choose not to upgrade to the current version and forego any upgrades, or use alternative extensions, or write your own extensions.
            According to your forum profile you are stillusing SketchUp 2016. If that's the case you can use the old legacy versions of Fredo6's extensions. They are still available at no charge.
              per·​pet·​u·​al
              a: continuing forever : EVERLASTING
              b: valid for all time
              That is the term Fredo applies to his licenses. Also the archived versions remain free just not maintained.
              Maintaining extensions to work across many versions of SketchUp is time-consuming and in some cases impossible.
                JohnButler222
                They might do so. The might not. If that's what you expect will happen you could choose not to upgrade to the current version and forego any future upgrades, or use alternative extensions, or write your own extensions.
                Thanks for the suggestion but I am using SketchUp 2017. I looked at the legacy version of Round Corner and it says I should not use it for Sketchup 2017.
                  JohnButler222
                  per·​pet·​u·​al
                  The issue is not the maintenance of extensions because I am talking about older extensions.
                  For example, Round Corner was free in 2017. That same version is now no longer free. And the archived version says it cannot be used on Sketchup 2017.
                    Not sure how I can help you if I'm honest. Are you looking for help? Or just venting?
                      Your profile says you are using SketchUp 2016 Pro. Evidently you need to update your profile.
                      If you aren't interested in compensating Fredo6 for his hard work at keeping his extensions current, a very small investment, don't update. Keep using the older free version. It's your choice.
                        JohnButler222
                        Thanks for your suggestion. However, as I said the free version of the plugin is now asking for money. I am not in need of a maintained plugin that works with current versions of Sketchup, I only need the original plugin that was offered for free to keep functioning.
                          JohnButler222
                          Yes, help would certainly be appreciated. Do you know of a way to ensure the free version of Round Corner remains functional in Sketchup 2017? Thanks.
                            The old free version of Round Corner won't change and neither will SketchUp 2017 so it you don't update the extension there's no reason to expect it to stop functioning. Your profile indicates you are using a Mac. Since you aren't insterested in updating SketchUp you'd best not update the Mac OS. Many users are reporting that older versions of SketchUp don't work on the newer Mac OS versions.
                            Fix your profile already.
                              JohnButler222
                              Unfortunately in my case the old free version of Round Corner has decided it is no longer free. Other users have reported the same. Perhaps it is to do with updating the shared library the plugins use. As for Sketchup, the 2017 version works fine on Catalina thankfully and I do not plan to upgrade further. And no need to "fix my profile" since I have another machine with Sketchup 2016, but thanks for the suggestion.
                                Well, sorry, I guess we can't do anything further for you.
                                I guess you shouldn't have done that.
                                  JohnButler222
                                  I guess not. Clever Fredo.
                                    As I wrote before, you are certainly welcome to find other extensions to use instead of Fredo's or write your own. Fredo has put in a lot of work to make and improve his extensions. You've benefitted from that work, too. The price of the Round Corner extension license is a trivial amount. If your time is worth anything at all, I'm sure Round Corner has saved you enough time already to have more than paid for it.
                                      JohnButler222
                                      Absolutely. Fredo's extensions have helped masses of people and he deserves to make money from his new and updated extensions now that he has decided to charge. But I'm not alone in thinking old extensions for old versions of Sketchup that were offered for free at the time should not have their functionality removed.
                                        It's what it is. Write your own extensions and then you won't have to deal with it.
                                          JohnButler222
                                          Great idea Dave, hadn't thought of that. Should I charge or offer them for free?
                                          Well I guess I can always change my mind down the road.
                                            Should I charge or offer them for free? Well I guess I can always change my mind down the road.
                                            It doesn't matter to me. If you write an extension that saves me substantial amount of time I would be willing to pay for it. I'm not against paying others for their good work. I guess you do your work for free and think others should do the same.
                                            • 6 / 9
