    [Plugin][$] TopoShaper - v2.7a - 01 Apr 24
    455 Posts 144 Posters 694.8k Views 143 Watching
      duventdesvagues
      where can i repor tan issue with the plugin toposhaper, please?
      thank you
        Post it here. Please also correct your profile. It says you are using SketchUp 2022 Free/Make but there is no such version. That information is important as it helps us help you.
          RhayaderNL
          Hey, i'm new to creating terrain in Sketchup, but following instructions using Fredotools and Toposhaper went relatively well, until the second step in Toposhaper: creating the mesh from isocontours. Toposhaper generates an error and the operation is fully aborted.
          I am using Toposhaper v2.6a in Sketchup Pro 2021 in Windows 10 Pro 64bit
          Date: 06-Jul-22 09:36:34
          An error occurred in CLEANSING
          The operation is fully aborted
          cannot hide layer that is a part of the active path
          body_lib6tool.rbe: 2538 -- visible=
          body_lib6tool.rbe: 2538 -- block in switch_to_temp_layer
          body_lib6tool.rbe: 2537 -- each
          body_lib6tool.rbe: 2537 -- switch_to_temp_layer
          toposhapertool.rbe: 1391 -- change_view
          toposhapertool.rbe: 1358 -- set_preview_working
          toposhapertool.rbe: 544 -- cleansing_processing
          toposhapertool.rbe: 523 -- after_selection
          toposhapertool.rbe: 493 -- notify_edge_picked
          body_lib6edgepicker.rbe: 539 -- call
          body_lib6edgepicker.rbe: 539 -- notify_action
          body_lib6edgepicker.rbe: 595 -- terminate_current_selection
          toposhapertool.rbe: 658 -- execute_validate
          toposhapertool.rbe: 387 -- handle_initial_selection
          toposhapertool.rbe: 319 -- activate
          toposhapertool.rbe: 133 -- select_tool
          toposhapertool.rbe: 133 -- action__mapping
          lib6plugin.rbe: 142 -- call
          lib6plugin.rbe: 142 -- launch_action
          lib6plugin.rbe: 244 -- launch_action
          bootstrap_toposhaper.rbe: 83 -- launch_action
          bootstrap_toposhaper.rbe: 149 -- block in startup
          lib6plugin.rbe: 1461 -- command_invoke
          lib6plugin.rbe: 1441 -- block (2 levels) in build_config_commands
          lib6traductor.rbe: 1378 -- block in add_command
          I would be happy to see a solution to this!
          • fredo6F Offline
            I think the problem is that you are inside the group of contours, and the group has itself a layer assigned.
            In TopoShaper, you can select the group of isocontours and process it, rather than entering the group.
              tofix1991
              Hi, I can't use toposhaper anymore because of trial period has expired, where i can find the free license.., πŸ˜„
              • Rich O BrienR Online
                It's next to the free beer πŸ‘
                  makover
                  Trying to use Toposhaper but none of the dialog boxes open when attempting to generate from contours. Goes through "cleansing contours" progress bar and then a large yellow square appears. Is this due to using the trial version?
                    Probably not. Might be an outdated LibFredo6 install, might be incorrect model setup. Share the .skp file so we can see what you are working with.
                      Andres8659 Newcomers
                      Hello Fredo Master! I have the same issue as somebody before:
                      I'm running SU2021 on my Windows OS 11
                      Helpp!! πŸ˜ƒ
                      • fredo6F Offline
                        It looks like you selected the curves directly and they have some assigned layer.
                        Can you try by selecting the group enclosing the curves (or create this group).
                          makover
                          Thanks! Attaching the modelled contours
                          00.10_NW_DWG Contours.skp
                            You've got several groups nested with the loose geometry of the countours in the model. Explode the group representing the perimeter of the contours and cut the other stuff down at the bottom of the group out so the group only contains the geometry for your terrain. There's a lot of edges to deal with in the contours so be patient when you run TopoShaper. Might not hurt to simplify the contours first.
                              titusbiao Newcomers
                              Hello,
                              I am now using Sketchup Pro 2021, with TopoShaper v2.6a. Following the instructions to TopoShaper::IsoContours, when I try to generate terrain as Step 4, SketchUp crashed! No matter the grid set as default 50x48, or 200x198, crashed all the same!
                              I don't know why, and could anyone tell me if there is anything wrong?
                              My file Topo.skp is here (uploaded to Microsoft OneDrive for download):
                              https://1drv.ms/u/s!AvaTfkcj2ZSTijSdm9cz1fsnQNFr?e=gUdSXs
                              Please help and many thanks!
                                Try tidying up the border to help Toposhaper create a mesh...
                                https://i.imgur.com/8s0IPHU.png
                                Topo-sk8.skp
                                I removed your outline and some pointless small edges and the BugSplat stops.
                                I also moved your raw geometry onto the default layer rather than your major/minor layers
                                  titusbiao Newcomers
                                  Hello Rich O Brien,
                                  Many thanks for your help.
                                  The Topo-sk8.skp works well with toposhaper v2.6a in SketchUp 2021 (Win10).
                                  I have tried some other skp files and find that if the geometry is rectangle, no errors will occur.
                                  So I guess that there might be 2 situations for toposhaper smoothly running without errors:
                                  1. the geometry is better in rectangle --- at least not too much acute or obtuse angles;
                                  2. Not too much tiny contour lines near the edge of the geometry.
                                    Is that true?
                                  Many thanks again!
                                  [attachment=0:3akutcq8]<!-- ia0 -->Topo-sk8.skp<!-- ia0 -->[/attachment:3akutcq8]
                                  • fredo6F Offline
                                      Is that true?
                                    Correct. You do not need too many contours, or too detailed contours, because TopoShaper is interpolating.
                                    When the terrain has an irregular contour, you may also get artefacts, because TopoShaper is based on quads.
                                    • volpino170790V Offline
                                      volpino170790
                                      Hi !
                                      I have a problem with TopoShaper
                                      Buttons don't appear and if the terrain geometry is not at the top level, it crashes.
                                      I've had this problem before with other files.
                                      Lib Fredo6 13.4a
                                      Toposhaper 2.6a
                                      I send a picture and a file
                                      https://i.goopics.net/800/ck230g.jpg
                                      Thank's !
                                      2.1878.skp
                                        Works fine for me...
                                        https://i.imgur.com/iw9dhgV.png
                                        • fredo6F Offline
                                          It works for me too.
                                          Could you open the Ruby Console before launching TopoShaper to see if there are error messages displayed.
                                            volpino170790
                                            Hi !
                                            Here a link for a video
                                            https://e1.pcloud.link/publink/show?code=XZ44gQZpMbvTD07lPfKUOGY0zFTHRPYK5Ey
                                            Error in console
                                            https://i.goopics.net/800/pj3gjq.jpg
                                            • 11
                                            • 22
                                            • 23
                                            • 9 / 23
