    2.2k Posts 482 Posters 856.4k Views 487 Watching
      This kind of error suggests that you do not have the latest SCFlicensing system installed.
      Install the latest SketchUcation toolset from the PluginStore.
      This will also include the newest SCFlicensing software.
      Restart SketchUp to ensure everything gets synced...
      Try again and the error should have been resolved ?
        risenknight
        Hi fredo, great plug in as always!
        i've got a problem with releasing the licensing, though. i've already released the licensing on one computer, as i'm planning to change my computer to a new one, but the seats' still taken... please see attachment
        just to note, i was just releasing the license, so maybe it will take time to see the changes. will be updating if the seat number is updated later on, thank you in advance
        • I Offline
          inji jeong
          Hi again.
          I bought bundle. and I want to activate but It doesn't work.
          whenever I click ' Validate License', there is an Error like below.
          Error in the License Validation
          Request to Sketchucation : ERROR_A04
          Wrong Signature File - You nay have changed the computer name
          It is advised to erase the signature file and revalidate
          Do you want to open the folder containing the signature file?
          I've tried deleting (SCFLicenseSignature - DO NOT MODIFY OR DELETE) file as I read in some posts, with no results.
          and It makes 'B03' error......
          Please help me how to solve it . Thanks.
            The initial error shows it could not decode the signature file.
            Did you install the newest version of the SketchUcation Toolset [v4.2.9], which also includes the current licensing code ?
            Have you installed the latest Lib Fredo ?
            Have you restarted SketchUp after the installations to sync everything ?
            It might be having issues with your computer's name ?
            Does it contain any characters that are not simple ASCII letters and numbers ?
            This goes against Microsoft's guidance and can cause other apps issues...
            Have you tried repairing the Windows installation - it will affect nothing you might have customized...
            Close SketchUp etc.
            Find the SketchUp installer's exe file - usually in your Downloads folder...
            Select the installer's exe file's icon, right-click > context-menu > "Run as administrator"
            When prompted choose "Repair"
            This should reset all permissions properly...
            I'm sure Fredo will also have some ideas and reply too...
            • fredo6F Offline
              Most likely, you have a COMPUTER NAME with some diacritic charcaters (i.e. non-ascii), which creates many problems (and not just to my plugins). Could you change the COMPUTER NAME, erase the signature file and try again.
                r4tm
                Hey Fredo,
                I've been having computer issues and had to facotry reset a few times, each time reinstalling fredo corner. Im now up to my seat limit and cant release them because ive reset the computer.
                Could you clear all the seats so I can reinstall please.
                Thanks in advance.
                  SakinaBhuriwala
                  I have just downloaded round corner but its say license is required. What is wrong ?
                    RoundCorner requires a license. See: https://sketchucation.com/forums/viewtopic.php?f=323&t=20485
                    You'll also need the current version of LibFredo6 and the Sketchucation Extension Store.
                      clausgs
                      HI
                      After using this plugin for some time, this morning its stopped working.
                      I tried to delete the signature file, but still the same problem.
                      And i do not want to change my device name,,, I have other stuff that is depending on this.
                      So what to do now ?
                        Gábor
                        Hi Clausgs,
                        Could you please PM me your signature file for further analysis and also your computer's name?
                        • E Offline
                          EyeBall
                          The payment system is not working. Trying for 2 days now... 😍
                            The system is PayPal. Can you give us a bit more info other than 'not working' ?
                            • E Offline
                              EyeBall
                              On my end there is an option to pay with Debit Card, and that's what I did. I paid and nothing happened. A friend of mine tried too and didn't work.
                              Thank you for the reply! I believe it will be fixed soon.
                                matt_bln
                                Hi, is-it possible to have a receipt for the purchase of the license or a way to find the receipt for the purchase?
                                Thank you
                                  If your purchase was in the last few weeks then invoices are available at https://sketchucation.com/webshop/my-licences.php
                                  Otherwise send an email to support@sketchucation.com and we can lookup your purchase
                                  • Bryan KB Offline
                                    @einstein said:
                                    The instruction PDF is not very clear at the beginning. It says:
                                    "Licensed extensions have a License... menu."
                                    but it's not explained where the menu is. I finally figured out that I have to go to Tools > Fredo6 Collection > Fredo Corner (or other plugin) > License, but this could be stated in the doc. That's my little suggestion.
                                    Thanks. I could not figure this out either.
                                    This works.
                                      Mrkay
                                      Hi, I purchased the Fredo6Bundle2022 but seems I have problem in validate the licenses. What file should I look for and where do I can get it? Please advise. Thank you
                                      • fredo6F Offline
                                        Firts, you should make sure you have installed the latest version of Sketchucation ExtensionStore and of LibFredo6.
                                        You should also read the instructions in the first post of this thread.
                                        What kind of 'problems' do you have?
                                          Mrkay
                                          Hi, I purchased the Fredo6Bundle2022 but unfortunately Curviloft is expired, Tools On Surface doesn't run at all. Please advice.
                                          • fredo6F Offline
                                            You just need to purchase a license now.
                                            Go to menu Tools > Fredo6 Collection > Curviloft > License.... and click on the button "Obtain License". You can purchase individual license for each plugin, or the bundle for 8 plugins.
                                            You can also use the following link for accessing directly the Purchase page of Curviloft.
                                            SketchUcation | Cart
                                            (sketchucation.com)
                                            • 109
                                            • 110
                                            • 7 / 110
