    2.2k Posts 482 Posters 857.6k Views 487 Watching
    • F Offline
      fm63110
      to the attention of Fredo6
      I sent a message yesterday to tell you that the documents attached to the license purchase confirmation email are not working. In fact, it's RoundCorner's that doesn't work. I have the sketchup 2022 version. Is RoundCorner compatible with this version of sketchup.
      If so, please send me a working license.
        I'm sure Fredo will reply.
        But some points that might help in the interim...
        Are you confusing Fredo's RoundCorner and his FredoCorner extensions and licenses - they are separate tools and licensed separately too...
        Everything works fine in v2022...
        Have you installed the latest versions of the SketchUcation Toolset [v4.2.8] which contains the latest SCFlicensing codes ?
        Have you also installed the latest Lib Fredo ?
          genlin1992
          Downloaded Fredo for jointpushpull 20 minutes for the first time. Initially had a problem loading LibFredo6 extension after getting jointpushpull.
          When LibFredo6 finally loaded, it came up with the expired license message - expired 31 mar 2022. But I only loaded it for the first time!!! It seems harsh to pay for the license when I don't even know whether this thing will work for me (not fredo itself but using joint push pull in my situation...
            This kind of error suggests that you do not have the latest SCFlicensing system installed.
            Install the latest SketchUcation toolset from the PluginStore.
            This will also include the newest SCFlicensing software.
            Restart SketchUp to ensure everything gets synced...
            Try again and the error should have been resolved ?
              risenknight
              Hi fredo, great plug in as always!
              i've got a problem with releasing the licensing, though. i've already released the licensing on one computer, as i'm planning to change my computer to a new one, but the seats' still taken... please see attachment
              just to note, i was just releasing the license, so maybe it will take time to see the changes. will be updating if the seat number is updated later on, thank you in advance
              • I Offline
                inji jeong
                Hi again.
                I bought bundle. and I want to activate but It doesn't work.
                whenever I click ' Validate License', there is an Error like below.
                Error in the License Validation
                Request to Sketchucation : ERROR_A04
                Wrong Signature File - You nay have changed the computer name
                It is advised to erase the signature file and revalidate
                Do you want to open the folder containing the signature file?
                I've tried deleting (SCFLicenseSignature - DO NOT MODIFY OR DELETE) file as I read in some posts, with no results.
                and It makes 'B03' error......
                Please help me how to solve it . Thanks.
                  The initial error shows it could not decode the signature file.
                  Did you install the newest version of the SketchUcation Toolset [v4.2.9], which also includes the current licensing code ?
                  Have you installed the latest Lib Fredo ?
                  Have you restarted SketchUp after the installations to sync everything ?
                  It might be having issues with your computer's name ?
                  Does it contain any characters that are not simple ASCII letters and numbers ?
                  This goes against Microsoft's guidance and can cause other apps issues...
                  Have you tried repairing the Windows installation - it will affect nothing you might have customized...
                  Close SketchUp etc.
                  Find the SketchUp installer's exe file - usually in your Downloads folder...
                  Select the installer's exe file's icon, right-click > context-menu > "Run as administrator"
                  When prompted choose "Repair"
                  This should reset all permissions properly...
                  I'm sure Fredo will also have some ideas and reply too...
                  • fredo6F Offline
                    Most likely, you have a COMPUTER NAME with some diacritic charcaters (i.e. non-ascii), which creates many problems (and not just to my plugins). Could you change the COMPUTER NAME, erase the signature file and try again.
                      r4tm
                      Hey Fredo,
                      I've been having computer issues and had to facotry reset a few times, each time reinstalling fredo corner. Im now up to my seat limit and cant release them because ive reset the computer.
                      Could you clear all the seats so I can reinstall please.
                      Thanks in advance.
                        SakinaBhuriwala
                        I have just downloaded round corner but its say license is required. What is wrong ?
                          RoundCorner requires a license. See: https://sketchucation.com/forums/viewtopic.php?f=323&t=20485
                          You'll also need the current version of LibFredo6 and the Sketchucation Extension Store.
                            clausgs
                            HI
                            After using this plugin for some time, this morning its stopped working.
                            I tried to delete the signature file, but still the same problem.
                            And i do not want to change my device name,,, I have other stuff that is depending on this.
                            So what to do now ?
                              Gábor
                              Hi Clausgs,
                              Could you please PM me your signature file for further analysis and also your computer's name?
                              • E Offline
                                EyeBall
                                The payment system is not working. Trying for 2 days now... 😍
                                  The system is PayPal. Can you give us a bit more info other than 'not working' ?
                                  • E Offline
                                    EyeBall
                                    On my end there is an option to pay with Debit Card, and that's what I did. I paid and nothing happened. A friend of mine tried too and didn't work.
                                    Thank you for the reply! I believe it will be fixed soon.
                                      matt_bln
                                      Hi, is-it possible to have a receipt for the purchase of the license or a way to find the receipt for the purchase?
                                      Thank you
                                        If your purchase was in the last few weeks then invoices are available at https://sketchucation.com/webshop/my-licences.php
                                        Otherwise send an email to support@sketchucation.com and we can lookup your purchase
                                        • Bryan KB Offline
                                          @einstein said:
                                          The instruction PDF is not very clear at the beginning. It says:
                                          "Licensed extensions have a License... menu."
                                          but it's not explained where the menu is. I finally figured out that I have to go to Tools > Fredo6 Collection > Fredo Corner (or other plugin) > License, but this could be stated in the doc. That's my little suggestion.
                                          Thanks. I could not figure this out either.
                                          This works.
                                            Mrkay
                                            Hi, I purchased the Fredo6Bundle2022 but seems I have problem in validate the licenses. What file should I look for and where do I can get it? Please advise. Thank you
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 109
                                            • 110
                                            • 19 / 110
