    Shortcut key for explode?
    28 Posts 8 Posters 9.6k Views 8 Watching
      On a MAC some key presses and/or combos are preserved for system use.
      Try another key ??
        Scozzarella
        I tried a lot of keys, but nothing to do.
        Could someone use Mac give me an advice, please?
          What keys are failing ?
          On a MAC you can't combine them with some 'modifier' keys... which are system-reserved...
          You need to give us some clues as otherwise we are guessing.
            Scozzarella
            Thank you.
            I tried all single key and all shift or control combinations, but they don't work.
            Do you have a Mac or a friend with a Mac?
              You aren't pressing Enter after typing the key stroke you want to set are you?
                Scozzarella
                No, I don't press Enter. From the Keyboard I hit a key and then close the window.
                  rv1974
                  it's a windowless command. Are you sure you use Sketchup?
                    Scozzarella
                    Of course, Sketchup for Mac
                      rv1974
                      What window do you close? There are no windows accomponing explode command
                      • Gus RG
                        Gus R
                        Something is buggy with the shortcuts in preferences because I can sometimes search for "explode" and find it and apply a shortcut and then when I restart SU it can't find "explode." Scrolling to Edit/Item/Explode will show up sporadically.
                        Make sure you click the "+" sign to the right of the shortcut and then click OK.
                        www.instagram.com/gusrobatto/
                        www.facebook.com/gusrobatto
                        • BoxB
                          As mentioned above You must have something explodable selected for the native explode to appear in the shortcuts.
                          • BoxB
                            I'll just add this to help people understand that the shortcuts list in preferences is context specific.
                            You can see when I filter by edit with nothing in the model selected the list is quite short but when I select a simple group the list of possible shortcuts grows considerably.
                              Scozzarella
                              Thank you but I select a group and in the list the explode appears. In Mac version there isn't + button.
                              When I select the command on the shortcut list and assign a shortcut, then close, the shortcut doesn't work.
                              • BoxB
                                Sorry, my comments were not really addressed to you Scozzarella, they were more of a general thing because people often get confused by the contextual shortcuts.
                                Your issue is something else and as I'm not a Mac user I can add nothing more than has already been said.
                                  What is the shortcut you are trying to assign?
                                    Scozzarella
                                    I tried a lot of keys.
                                      We're trying to help here. Could you be specific?
                                      Have you actually installed SketchUp or are you running it from the .dmg?
                                        Scozzarella
                                        Thank you very much.
                                        I have installed Sketchup on my Mac and all works perfectly. But the shortcut for Explode doesn’t work.
                                        Maybe the Preferences json file?
                                          Why won't you answer my question? Exactly what keyboard shortcut are you trying to use for Explode?
                                            slbaumgartner
                                            The others who have replied are not Mac users, but I am so I can base this on actual experience.
                                            First of all, the command to which you want a shortcut is Edit/Context Menu Flyout/Explode. As the word "Flyout" implies, this choice only appears in the Shortcuts preferences when a Group or ComponentInstance is selected in the model or if you have already assigned a shortcut to it.
                                            Second, you can assign a shortcut to this action when it is listed, as proved by the attached screenshot where I assigned shift-U. I also tested, and this shortcut works as expected.
                                            You aren't perchance attempting to assign a command key keychord shortcut are you? That is not permitted on Mac, because Command keychords are reserved for the compiled-in menu items. Sometimes you can get a command keychord to work for a single session, but they won't be remembered the next time you start SketchUp. Have you succeeded in assigning shortcuts for other actions?
