    2.1k Posts 465 Posters 655.0k Views 470 Watching
      maschinengott
      @gábor said:
      I too have the
      "msg_validation_error
      Request to Sketchucation = ERRORA04" problem.
      I cant validate my copy of FredoCorner (and I cant download/install from the SketchUcation Store plugin).The problems seem to be conncected.
      So far I have tried:
      -SketchUp 21 &22
      -fresh new installs of SketchUp as admin (right click, install as admin etc)
      -deleting the files in the License file loacation (as other people have been instructed to do when asking for help with this problem)
      -reinstalling plugins
      -deleting caches (Internet explorer etc), disabling proxy on my pc
      SketchUcation plugin is the 4.2.5 and Fredo is the current one as well 😞
      The problem only exists on this machine (work pc) and all is fine on my home pc. I have no idea what to do at this point and neither what to google to fix this in my own.
      So far I have found out that its very likely a problem with Sketchucation store plugin not being able to reach the servers, but not even completely deactivating my firewall has helped so far, neither have countless reinstalls and it has cost me days of work now trying to fix this. I would greatly appreciate any help. 😢
      ERROR_A04 indicates some problem with your signature file. Please try to erase your signature file at C:\Users\username\AppData\Local\SCF Licenses\SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt (on windows) and try to re-activate your license.
      If after this you are still getting the same error message, please send your signature file by PM to me for further analysis.
      Will send it to you later after work. I have tried the deletion trick several times before, also in tandem with different combinations of system restart, new SketchUp install before, after, firewall/no firewall and basically everything else that I could find in this thread! Thanks for the help in advance!!!!
        Gábor
        Thank you. Waiting for the signature file.
          brksnr
          Hey Fredo,
          I'm wondering if there is a way to release the license even if we cannot reach our device anymore, it would be a major problem unless it is possible.
            Gábor
            @brksnr said:
            Hey Fredo,
            We are working on a solution to enable online release but it will take probably a few more weeks until we introduce this to the public. Until then you can PM Fredo6 with the details of your license (Plugin name, license ID, etc) and the reason why you are asking for this or write to our support at support [at] sketchucation.com . After evaluating your request they might or might not release a seat for your license.
              brksnr
              @gábor said:
              We are working on a solution to enable online release but it will take probably a few more weeks until we introduce this to the public. Until that you can PM Fredo6 with the details of your license (Plugin name, license ID, etc) and the reason why you are asking for this or write to our support at support [at] sketchucation.com . After evaluating your request they might or might not release a seat for your license.
              Thanks for the reply, right now I don't have any needs for those kind of problems, I was just asking this to prevent any future problems.
                maschinengott
                FIXED, maybe this solution helps someone else:
                My computers name contained non ASCII letters that prevented SketchUcation from proper communication with the servers (thats at least how I understood it).
                In my case these letters were Umlaute (Ä,Ü,Ö).
                If you cant download from the store plugin anymore + your license gives out an A04 error then check if you have recently changed your machines name (especially for the Germans that thougt it would be a good idea to name their PCs "Bürorechner").
                I too have the
                -SketchUp 21 &22
                • DougJosephD Offline
                  DougJoseph
                  Hello. While trying to validate paid-for license for FredoCorner on SketchUp Make 2017, I get the following error popup dialogue box:
                  Request to Sketchucation = ERROR_F09
                  https://i.imgur.com/fiu70kU.png
                  UPDATE:
                  I had done quite a bit of searching, but not enough. I just read (above) where the plugin author answered a similar question with...
                  FredoCorner and RoundCorner are different plugins, functionally and for licensing:
                  • RoundCorner is part of the bundle pack
                  • FredoCorner is licensed separately (it has been so for more than a year)
                  I sent you by email the license file for RoundCorner just in case.
                  I was not aware of the difference, and I apparently installed FredoCorner instead of RoundCorner. I have no idea what the difference is between the two, and the license I bought says it is for RoundCorner. Working on this some more...
                  UPDATE 2:
                  Got RoundCorner license validated.
                    The error F09 shows a mismatch between the license and the extension...
                    I guess you've now resolved it having realized that there are two extensions with somewhat similar names and they need licensing separately... The FredoCorner is the newer one, [licensed separately], and RoundCorner is the older [in the bundle]... they each have slightly different functions - both are powerful...
                    Am I right in my assumption that this is now resolved to your satisfaction ? ...
                      Snuk
                      Hello from Turkey.
                      There is only PayPal as license payment fee, but PayPal is not available in Turkey. How else can I make the purchase?
                      • Rich O BrienR Online
                        @snuk said:
                        Hello from Turkey.
                        There's no other way at the moment. But we are working on adding more payment processors in the future.
                          Architure
                          Hi There,
                          My license just switched off, it happens time to time
                          Bu since then there's no way to validate the license back again
                          When I click on the "validate" button, and try to find the scflicense from the download page, I see no compatible file to appear
                          Any help would be appreciated
                            @architure said:
                            Hi There,
                            What version of SketchUp? Your profile says "Pre-2013". Is that correct?
                            Do you have the latest version of the SCF Extension Store installed?
                              Gábor
                              @architure said:
                              Hi There,
                              .... try to find the scflicense from the download page, ....
                              Which download page are you referring to? You should have received your license by email and it should have been saved to your harddrive.
                                diegovargas_r
                                I want to buy the package with the 8 plugins, in it this writing is available for 3 places. Can I buy and share the license with a friend? Are there plans for student leave?
                                  craigcclick
                                  Fredo Corner says my trial expired a week ago. I now wish to purchase Although when I go to'My Licenses', it says it's perpetual. OK. I don't see where on https://sketchucation.com/plugin/2120-fredocorner there is a purchase button. What am I missing?
                                  • fredo6F Offline
                                    @craigcclick,
                                    Unless I am wrong, you purchased a license of FredoCorner in July 21, which you never activated.
                                    It should be visible in your MyLicenses page on Sketchucation, where you can download the license file and then activate it on your computer via the License dialog (menu entry Tools > Fredo6 Collection > FredoCorner > License....).
                                    • khantuK Offline
                                      khantu
                                      Hello. After reinstalling Windows OS, I cannot license the FredoCorner plugin, writes that all license places are occupied. Please help me solve this problem. Thanks.
                                        tomkuc74
                                        I have the same problem with FredoScale Perpetual License. After reinstaling W10 all seats are taken.
                                          tomkuc74
                                          Release all of them please. /I coudn't answer in PM/
                                          • fredo6F Offline
                                            Done.
                                            • 105
                                            • 106
                                            • 5 / 106
