    [Tips] Animator Tips and Tricks
    renderpluginsextensions
    74 Posts 18 Posters 277.6k Views 18 Watching
    • fredo6F Offline
      @hornoxx said:
      Is it possible to assign the same kind of movement already assigned to one group to one or more other groups later on? - in some kind of "animator-properties-copy-paste"?
      There is a Copy button in the sequence editor. It copies the sequence parameters and let you change the selected object(s).
      @hornoxx said:
      even if I delete movments which I often do as I am still learning, the list so far made moves is growing and growing - is there an intention or a benefit associated with this list which I don't recognise?
      You can manage and cleanup the sequences with the Maintenance dialog (click on the button in the main palette).
      This dialog shows all sequences, where they are used, and which one are no longere referenced in animation clips (so you can purge them).
      • HornOxxH Offline
        HornOxx
        πŸ‘ πŸ‘ thank you for these helpful screenshots! (no idea why I didn't find these options!).
        never trust a skinny cook
        • HornOxxH Offline
          HornOxx
          @fredo6 said:
          ...There is a Copy button in the sequence editor. It copies the sequence parameters and let you change the selected object(s).
          ... sorry, I still need a little help here please πŸ˜„ πŸ˜‰ ok, I managed to find and ckick this Copy-button πŸ˜„ but I am not able to figure out the procedure of linking (pasting) this onto another group now.
          • fredo6F Offline
            Just remove the selection (with button) and select other object(s)
            • ntxdaveN Offline
              ntxdave
              Perhaps you could create an example and post it here. I would try it myself but my laptop died and my iPad is all I have to work with right now.
              Press F1...thank me later
                Dorjiw
                I have recently installed the Fredo6 Animator and as per the information, its validity will expire end of this month. So does it mean that this animator cannot be used after March 2022? Or will there be a new version of this animator that needs to be purchased?
                • fredo6F Offline
                  I will publish an updated version by then.
                  I keep expiration dates for some plugin to maintain a reasonable support to recent versions.
                    Dorjiw
                    I have a further inquiry on animation using the Animator. If I make a streetscape with cars on the street in the animation, how do I group the sequence and clip? The Animation of a car ( car motion and wheels turning) will be in a group and then another car animation in another group. I have a bit of confusion about how to create several cars animation using the animator.
                      Dorjiw
                      I have been using animator for the last few weeks for streetscape with cars movement. I have a few queries in this regard as I have not been able to move forward efficiently due to issues.
                      I created car motion animation and set everything ( such as positioner and motion using 'on path tool') and works fine initially and then save the file.
                      Then every time I open the files, the cars would have moved from their initial positions or the car would have rotated. I keep adjusting this and have not been able to move forward.
                      I may be missing some steps. Does this issue occur with other users as well?
                      The second query is about the 'Tools on surface' plugin that I have installed to create car animation on the path. This plugin will have to be purchased as per the comments I saw earlier. So if I buy the latest plugin, will this affect the car animation created?
                      • fredo6F Offline
                        In general, it is a good idea to save the initial position of all objects with the SAVE POSITIONNER (last button in the toolbar), so that you can restore it whenever something becomes messy.
                        It should not. The licensing is independent from the plugin functionality.
                          Dorjiw
                          Thank you so much for the prompt reply.
                          It seems like the new version of animator is out.If I update the old version, I just hope that the work that I have done is not affected.
                          If you could please recommend comprehensive tutorial videos on using animator.i have watched most of your tutorials on animation.
                          As for the tool on surface plugin, when is the last date for purchase? And will the process for installation be same like the intial one.
                          • fredo6F Offline
                            it should not
                            I posted a few videos in the Tutorial thread, but nothing comprehensive yet.
                            You could also have a look at a good video by TutorialsUp.
                            @dorjiw said:
                            As for the tool on surface plugin, when is the last date for purchase? And will the process for installation be same like the initial one.
                            The licensing is independent from the downloading and upgrading.
                            • BoxB Offline
                              Fredo, I haven't looked too hard yet, but is there an option to add animated geometry from one model to another?
                              For example you have created a walking figure in one model and a forklift in another model, can you combine the two models without having to start from scratch with the one you insert into the other?
                              • Rich O BrienR Online
                                @Box
                                There's no way I know of nesting a .skp with animation data into another .skp file and have that file 'see' the animation data.
                                • BoxB Offline
                                  Thanks for letting me know Rich, I can stop looking for it.
                                  Have to prod Fredo with it as a feature request.
                                  I often work with things in multiple files and it would be nice to be able to combine them, and build up a collection of insertable components with predefined animation properties.
                                    Yeah, I once made a series of animated files I wanted to merge. I thought the [filename].animator file that is saved with the .skp would contain something I could import but no luck.
                                    • BoxB Offline
                                      Yeah, it seems like the natural next step, hopefully it's something the grandmaster is working on.
                                      πŸ’š
                                        It was animated crowds I was thinking of...
                                        • BoxB Offline
                                          Well, you can do that within the same file no problem, but the hidden door file I posted I created and then thought of the Robot only after doing it all. I had animated the robot in another file but couldn't get it into the hidden door file with animation intact. And by then it was late and I didn't have the energy to reanimate the robot. He really should walk into the space and then exit through the roof.
                                            shelburneplanner
                                            Anyone have tips for animating speech using Fredo6 Animator and a model in SketchUp? I'm working with SU 2017 (Make).
                                            thanks in advance for suggestions!
                                            • 3 / 4
