    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • fredo6F
      NEW RELEASE: LibFredo6 v12.0b - 30 Sep 21
      LibFredo6 12.0a includes
      • Bug fixing for calculation of volumes in several plugins
      • Other fixes
      • fredo6F
        NEW RELEASE: LibFredo6 v12.1a - 23 Oct 21
        LibFredo6 12.1a is mainly dedicated to the new plugin MoveAlignMe
        • jgbJ
          jgb
          I need some help. I am running SU 15.3.330 32 bit for now.
          I'm getting a new 64 bit PC in a month or so and will upgrade to SU latest.
          Why is irrelevant at this time, but if you need to know, ask me.
          I ran SU 15 from my old installation but the Fredo Lib was partially corrupted and many tools do not work. I lived with it till now when a tool I really needed was not working.
          I want to reload Fredo Lib but the only one I can find is for SU 17+.
          Where can I find a copy of Fredo Lib for SU 15 32 bit?
          jgb
            If you'd search in the Sketchucation PluginStore--link at the top right of the forum page--you could find the older version for pre-2017 versions of SketchUp. Same with other extensions that Fredo6 offers for the older versions of SketchUp.
            SketchUp Plugins | PluginStore | SketchUcation
            SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
            (sketchucation.com)
            • I
              ia enstera
              Would you please update the installation video? Some changes have taken place between that and SketchUp2021, and I am unable to follow the instructions as given...and am still stuck and unable to install and use your plugins. Thank you.
              • fredo6F
                NEW RELEASE: LibFredo6 v12.2a - 01 Nov 21
                LibFredo6 12.2a includes
                • Evolutions for FredoSpline v2.3a
                • Technical adjustments
                • L
                  Leroydonald
                  Bonjour je n'arrive pas à télécharger libfredo6 pouvez m'aider ?
                  • fredo6F
                    Télécharger ou installer ?
                    • fredo6F
                      NEW RELEASE: LibFredo6 v12.3a - 27 Dec 21
                      LibFredo6 12.3a includes
                      • Evolutions for LOTT v1.6a
                      • Technical adjustments for future compatibility
                      • fredo6F
                        NEW RELEASE: LibFredo6 v12.4a - 09 Jan 22
                        LibFredo6 12.4a includes
                        • Evolutions for LOTT v1.7a
                        • P
                          PVTech
                          I have installed free Fredo6 V12.4a in SketchUp Pro 2018 on a Macbook. However, there are no toolbars. How does it work without toolbars? Is it because I use a free version? which version of Fredo6 can provide toolbars of animation on a Macbook?
                            LibFredo is a shared dependency/library that many tools Fredo publishes use. On its own it does nothing. Without it any tools that depend on it will not work.
                              LibFredo6 is mainly support files for many of Fredo6's extensions. It doesn't need a toolbar. This has nothing to do with your using a free version.
                                As explained, the Lib is merely a collection of support files needed by many of Fredo's other extensions.
                                On its own it does nothing...
                                In your post you mention
                                Fredo's extensions do include an animation toolset - you'll need to get and install that, AND remember you'll need the Fredo Lib as well...
                                Search the PluginStore for it...
                                • fredo6F
                                  NEW RELEASE: LibFredo6 v12.5a - 21 Feb 22
                                  • Bug fixing, technical adjustments and support for future plugins
                                    ArmorBearer
                                    Fredo, I downloaded the 12.5a rbz from sketchUcation, but it does not install into SketchUp. I have SU 17.2.2555 64-bit. After I click Install Extension from the Extension Manager, I select the downloaded rbz (7.15MB) and click Open. My Extension Manager flickers a bit and then disappears. After reopening Extension Manager, I look at the LibFredo6 plugin information, and it still says the previous version.
                                    So I uninstalled the previous version and tried to install 12.5a again. This time, after reopening Extension Manager, I look and there is no LibFredo6 in the list.
                                    Is LibFredo6 no longer compatible with SU 2017? Or is there some other problem?
                                    • fredo6F
                                      LibFredo6 v12.5 is compatible with SU2017 (I use it on my Windows laptop and Mac). So, it must be something else...
                                        Shridhar
                                        How i can get v7.6 of this plugin
                                          MACIEJka
                                          Hello,
                                          Probably my problem is an obvious thing, but every time I try to launch Fredo Corner, I got this messege: 'This version of Fredo Corner has expired. Please upgrade to the latest version'. I use paid licence of this plugin and before it worked without any problem. What should I do to fix it? Thank You for any help.
                                          MF
                                            Have you installed the latest SketchUcation Toolset, then restarted SketchUp ?
                                            The licensing system was updated...
                                            • 88
                                            • 89
                                            • 90
                                            • 91
                                            • 92
                                            • 115
                                            • 116
                                            • 90 / 116
